New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 19, 2013 at 5:15 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    First time I think I've seen a 4" lift for 2nd gens. But I don't think it's worth installing a DB lift for an extra inch.
  2. May 19, 2013 at 5:21 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    RCD used to (or still might) make a 4" DB lift. I don't think they're all that bad, just depends on what you want to use the truck for I suppose.
  3. May 19, 2013 at 5:26 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I just got an email back from crutchfield. I contacted them cause they never shipped the harness for the speakers. It will ship in am as well as mounts. I took the panels off today to prepare for install
  4. May 19, 2013 at 5:27 PM
    Pugga
    Massachusetts
  5. May 19, 2013 at 5:30 PM
    BostonBilly
    Easton
    That would be cool but I dont do facebook. I see you are #1
  6. May 19, 2013 at 5:31 PM
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    This is a 6"
  7. May 19, 2013 at 5:33 PM
    replica9000
    2019 T4R ORP
    The link above list a 4" and a 6" DB lift. To me, not really worth it to spend all that money for the kit, cut up the cross member, and actually lose clearance between the front tires.
    I'd rather get the 5100's (3") and a top plate spacer (1") to make 4" lift. If the CV joints and other suspension components suffer too much (no down travel), could just turn down the 5100's to 2".
  8. May 19, 2013 at 5:36 PM
    Pugga
    Massachusetts
    Yep, first on the list also :D
    I dunno, everyone always says that about DB lifts but they let you clear larger tires (which is really the only way you actually increase ground clearance). Just the drop bracket lift itself would lower ground clearance but throw some big ass tires on there and I would guess that you'll end up with more ground clearance than you started with. :notsure:
  9. May 19, 2013 at 5:39 PM
    BostonBilly
    Easton
    I guess I walked into that
  10. May 19, 2013 at 5:39 PM
    replica9000
    2019 T4R ORP
    Right now I don't plan on running anything more than 33's
  11. May 19, 2013 at 5:42 PM
    Pugga
    Massachusetts
    Hehe, I couldn't resist :D
  12. May 19, 2013 at 6:16 PM
    Pike Tacoma
    Pike Tacoma Well-Known Member
    Rhode Island
    2010 Double Cab Tacoma
    Thanks Pugga for the heads up on that
  13. May 19, 2013 at 6:19 PM
    Pugga
    Massachusetts
    No problem, if I don't win, hopefully it'll at least be someone local!
  14. May 19, 2013 at 6:22 PM
    Pike Tacoma
    Rhode Island
    haha exactly
  15. May 19, 2013 at 6:43 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    The first part of your statement is not true on IFS. If you measure your lifted truck with a stock truck even with the same size tire you have more ground clearance (at least on the front of the truck). The rear axel will be the same.
    DB's move the truck up but doesn't give any more ground clearance. You have to run larger tires to get a DB truck to have the same ground clearance as a 3" lift on 33's. The larger tires burn more gas and put way more stress on the rest of the components never mind the fact that you cut away the beefiest crossmember on the frame.
    No thank you.
  16. May 19, 2013 at 6:46 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
  17. May 19, 2013 at 6:48 PM
    eborgie
    eborgie No Yotas Here
    Erik
    Bellingham, MA
    2023 Bronco Sasquatch
    So you guys found some mud huh?
  18. May 19, 2013 at 6:53 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    A little. Not to much. Johnny said he hates mud so I asked if he goes on that site too but he had never heard of it so I posted the link. Apparently tons of Toyota stuff over there.
  19. May 19, 2013 at 6:54 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    I would tend to agree. If you want to go over 3" and be trail worthy you need to go long travel or SAS. Either way you pay to play.
  20. May 19, 2013 at 7:06 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    I really like the idea of doing a 3" susp lift and 1 " BL to achieve a nice 4" lift and be trail worthy. PSU taco I believe rocks that combo and the 1" BL isnt bad looking.
