New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jul 18, 2013 at 7:49 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    What did you get?
  2. Jul 18, 2013 at 8:29 AM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    So glad I have a dealer plate and demo this week. New car AC and speed.
  3. Jul 18, 2013 at 8:36 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    $95 per shock, springs are $93 each. So theres $400, shipping both ways probably close to $100, i paid $550 shipped for them. Brand new i think they are around $1200. So im saving a little money on them at least. I was thinking about custom valving mainly because it would convenient to do it now. Or i can send then to icon and add the CDC for about $800 for the pair :cool:
  4. Jul 18, 2013 at 8:40 AM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    You should of just installed them and see if you liked they way they rode. Then change them . How many miles were on them ? I wouldn't waste your money on that CDC . I talked with icon about the valving before ill try and find the email .
  5. Jul 18, 2013 at 8:46 AM
    johnnym
    john
    NH
    From icon
    You will want to charge them to 240-250psi. The increased spring rate is ideal when adding 250+ lbs over stock. If that is the case no valving change should be necessary. If you are not adding enough weight you would need to make a change and changing the spring rate might not be necessary.
    Oh and my question to them was .
    Is there a special valve to fill them with nitrogen ? What pressure do they get filled to ? Also I will be replacing the spring with a 700lb 14" coil to compensate for a winch and plate bumper weight . Do you recommend changing the valving or keep them same ?
  6. Jul 18, 2013 at 8:53 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    The only reason i haven't done that is because i dont want to have to get an alignment. In theory if i put them on for a few days, then go back to the OME my ride height should be the same so alignment should be good as long as i mark out my camber setting on the UCAs and dont touch the LCA cams, but my guess is i would need an alignment if i pull out the coilovers. The icons have 35,000 miles, i have read they typically need a rebuild between 40-50,000 miles. They arnt leaking or anything, so they don't need it now, but it would suck to put them on then need to rebuild them in 6 months to a year.
  7. Jul 18, 2013 at 9:08 AM
    johnnym
    john
    NH
    Ya I hear you . Mine have around 40k ish . I'm just going to run them until I sell them and let the next guy rebuild them . The rebuild kit is only $35 and the fill port needle is like $25 or something . So if they start leaking or whatever ill go that route . Cheaper and I don't have to wait for someone else to do the work . I could do both in a day . DD truck so no down time is good .
  8. Jul 18, 2013 at 9:09 AM
    johnnym
    john
    NH
    I need fucking ac in my garage . It's way to hot to be working on this shitbox .:mad:
  9. Jul 18, 2013 at 9:22 AM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    I need a fucking garage!:p
  10. Jul 18, 2013 at 9:37 AM
    johnnym
    john
    NH
    :brianr:
  11. Jul 18, 2013 at 9:45 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I need one that has enough room all around my truck so I can work on it in there. And one with more than one bay because right now my 92 is taking up the garage
  12. Jul 18, 2013 at 9:46 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Also, that awkward moment when you are taking a dump at work while trolling the internets on your phone and the lights shut off...just happened
  13. Jul 18, 2013 at 9:50 AM
    johnnym
    john
    NH
    X2 bigger garage is needed .
    Co worker making sure your not sleeping . :D
  14. Jul 18, 2013 at 9:55 AM
    64Wildcat
    Denis
    New Hampshire
    2015 Rubicon
    Tightening all your shit down?
    I put the spacers on the 886's last Sunday(got the inch i lost back),grounded the cb antenna and rewired the rear bumper license plate lights.
    This coming Sunday,install extended brake lines and bleed them,waterproof winch electronics,i was hoping to install the gas tank skid(they still haven't shipped the straps out),tighten all my shit down and a few other things.
    I can't wait to get on the trails next week!:D
  15. Jul 18, 2013 at 9:57 AM
    johnnym
    john
    NH
    Supercharger install :D
  16. Jul 18, 2013 at 10:05 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Is that your truck?
  17. Jul 18, 2013 at 10:09 AM
    johnnym
    john
    NH
    Yes sir
  18. Jul 18, 2013 at 10:16 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    So jealous
  19. Jul 18, 2013 at 10:37 AM
    johnnym
    john
    NH
    I'm just kidding . I can't afford a supercharger . Fan clutch and washing all the mud out of my radiator/ engine bay .
  20. Jul 18, 2013 at 11:22 AM
    johnnym
    john
    NH
