New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Aug 25, 2013 at 11:18 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Lowest vulnerable point is the rear differential. The breather for that is right on top of the diff which is why lots of people relocate it a bit higher. That's not real trouble though if you're careful. Any of the breathers, if you're careful, won't cause any trouble and shouldn't suck in water. Even if you completely submarine your rear diff, it shouldn't suck in water unless it's plunged straight into cold water when it's nice and hot. When you start going over that, you subject other parts to early failure such as your starter, pulleys, etc. Deeper water still can actually cause your fan blades to break when they hit the water and finally if you get in deep enough, hydrolock.
    Also, if you get water up higher than the bottom of the cab, and water starts coming into the cab, even though the truck's intake is high enough so as not to cause engine damage, the truck's ECU is low on the floor, just something to keep in mind if you're trying to really waterproof your truck
  2. Aug 25, 2013 at 11:21 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    I have an aftermarket headunit, so it may be slightly different if you have the stock Toyota one. But, on mine I have to set the radio to the setting I would use to stream Pandora to my headunit (Bluetooth rear input on my radio). I think it would be the same for you. So you can't listen to anything else besides streaming music off of your phone, and when it's time for the voice directions they will cut in and play through the speakers. Not sure if that helped at all, or made any sense.
  3. Aug 25, 2013 at 11:21 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I believe I've been in water up just above the bottom of the doors, weather seals seem to be doing their job.
  4. Aug 25, 2013 at 11:26 AM
    Pugga
    Massachusetts
    The weather seals might do well but if you go too much higher, there are open holes in the cab that will let water in. Have you inspected your diff fluid since that water crossing? If it looks like a chocolate milk shake, time to change it out.
    The other breathers are pretty high in the engine compartment and I believe the transmission breather is on top of the tranny so you have a ways to go before those submerge. If you do manage to submerge your other breathers, chances are the parts will be cooled by the time the breather goes under anyways so it's not as great of a concern. Search for the SCUBA mod, someone went through and showed how to relocate all the truck's breathers to a higher location.
  5. Aug 25, 2013 at 11:31 AM
    replica9000
    2019 T4R ORP
    I need to get around to swapping the fluids in the diffs and gearbox anyways. Maybe I'll gets the fluids and swap them after the next run. The only hole I can think of at the moment is where the shifter is.
  6. Aug 25, 2013 at 11:41 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    The way mine works is I just open bluetooth on my phone and it pairs so any phone calls come thru speakers. The google maps wont give commands thru the speakers while it is on bluetooth or thru its own speaker on the phone. If I take it off bluetooth it will use the phone speaker. I haven't tried it while using Pandora cause I dont use that as much.
  7. Aug 25, 2013 at 11:47 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I think it has to be on whatever setting (if there is one) that you would normally stream internet radio/ music off of your phone to. The phone audio is a different "protocol" or some tech nonsense than the normal audio/ google maps voice, etc.. which is why it won't just play. My headunit is the same way, it automatically pairs, if a phone call comes through it will play through the speakers, but if it's not specifically on the "bluetooth" input, it wont play the google maps voice.
    Which is annoying because if I am listening to XM, but have my phone paired so I can use hands free calling and am also using google maps to navigate there won't be any voice directions, similar to what you are talking about.
  8. Aug 25, 2013 at 12:01 PM
    BostonBilly
    Easton
    That is the exact issue. I will try in the am for my ride to work. If that is the case that sucks cause I bet you wont be able to listen to anything but google maps
  9. Aug 25, 2013 at 12:36 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    If i'm streaming pandora, intune, or just music from my phone to the headunit it will play that as well, and google maps voice will play over the speakers. But ya, unless you are streaming music off your phone via bluetooth, you can't listen to anything else. It is lame. I did some research once on it, and it has to do with the communication protocols normal audio and the phone audio use.
  10. Aug 25, 2013 at 1:00 PM
    UrPebkac
    UrPebkac Well-Known Member
    David
    RI
    2016 GMC SIERRA
    So I think this depends on the phone and the head unit working together.
    I have the 2013 toyota touchscreen. With Bluetooth connected to my iPhone and the dock connector to the head unit to charge. I can play the radio/cd on the head unit and when Google maps needs to chime in it mutes the radio and sends the directions to the head unit as if I was receiving a phone call via Bluetooth. I have only ever got it to work with both the Bluetooth and Dock connector connected. I have not really tried with only Bluetooth.
    I also have IOS 7 but it did work with IOS 6 the same way.
    I am sure I am dif setup and you both are likely using aftermarket head units. I honestly just read the last post. I dunno maybe that helps?
  11. Aug 25, 2013 at 1:37 PM
    BostonBilly
    Easton
    So I just tried to have my stock head unit on mode "BT" while using google maps and yes it does work thru speakers. So if I want music and directions I have to use pandora. That sucks :(
  12. Aug 25, 2013 at 1:39 PM
    BostonBilly
    Easton
    I think the difference is the dock. I just ordered a dock for my S3 and will see what happens when that comes in
  13. Aug 25, 2013 at 1:53 PM
    replica9000
    2019 T4R ORP
    Wasn't there yesterday. Almost a foot in diameter. Glad I saw it now instead of walking in to it later on...
  14. Aug 25, 2013 at 1:57 PM
    BostonBilly
    Easton
    Close up of constructor
  15. Aug 25, 2013 at 3:03 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Yeah I was surprised! Great snag!
    I plan to bring some tools and parts. My tail light is LED so I'm good. I need an extra headlight bulb because I only have a single bulb for hi/lo
  16. Aug 25, 2013 at 3:09 PM
    emelianenkov
    Alex
    NORTH POLE
    Sooooo I found this in my storage unit. Forgot I had this, brand new in the box!
    Decided I wanted to make an off road rig out of it lol
    Added spacers and longer bolts
    Working on the ifs up front! I have to get pretty clever but I think I figured something out!
    I want to put this shell on a real RC chassis so I can actually flex this thing
  17. Aug 25, 2013 at 4:28 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Not sure WHY but when I saw this .......:confused: Alex popped into my head...:p
  18. Aug 25, 2013 at 4:30 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    :rofl: That isn't Alex?
  19. Aug 25, 2013 at 4:34 PM
    replica9000
    2019 T4R ORP
    Doesn't quite pull of the AMC Eagle look...
  20. Aug 25, 2013 at 4:35 PM
    BostonBilly
    Easton
    If you are running the controls you better put it in a watertight ziplock bag :D
