New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 21, 2014 at 8:07 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    When I pulled my light bar off, I had to use the poor man's impact wrench. Box wrench and a rubber mallet... Worked like a charm albeit a little slow :D
  2. Jan 21, 2014 at 8:10 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Hit it with a torch to heat it up and loosen the bolt before you impact it. They will still shear with an impact gun. I learned that one with my tow hooks I didn't think I would shear a half inch grade 8 bolt. That was not very fun to drill out.
  3. Jan 21, 2014 at 8:13 AM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
  4. Jan 21, 2014 at 8:13 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I'm a Welker fan from back when he was with the Dolphins. I will say though that I don't think that I have ever heard Belichick call out a player for doing a dirty play like he did to Welker. Seriously if Belichick thinks it's a dirty play than I think it is too.
  5. Jan 21, 2014 at 8:18 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Old school...I like it.
    Only time I've ever sheared a bolt using a breaker bar was when I snapped a lug stud trying to get a rim off of my dad's '57 Ford Tractor. It hadn't been off the tractor since the 70's, and I had a 6 foot length of iron pipe slipped over a 24" breaker bar. I was using a different version of the Poor Man's Impact Gun (jumping up and down on the end of the pipe) when it snapped.
    Seen lots of them sheared with impact guns, though.
  6. Jan 21, 2014 at 8:22 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Haha I sheared off the bolts that hold the 2 ebrake cable guides to the axle, and the one that holds the little hard line junction thing to axle. Tried to drill them out but got impatient. I'll likely just have someone drill them out and do my rear extended brake line. Every things all rusty and I don't want to risk breaking one of the hard lines.
  7. Jan 21, 2014 at 8:25 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    How likly am I to screw up my bed bolts doing the extra D-rings? No impact wrench here :(
  8. Jan 21, 2014 at 8:29 AM
    Noelie84
    Noel
    Wales, Maine
    It's always tough trying to mod your DD.
    When I had my '99 I always scheduled any mechanical work I had to do around a stretch of nice weather during the summer, so if I broke something I could ride the motorcycle to work without getting rained on :D
  9. Jan 21, 2014 at 8:29 AM
    Pugga
    Massachusetts
    If you're careful, not likely. They are a large torx head bolt so if you're using the correct size bit, they're difficult to strip.
  10. Jan 21, 2014 at 8:30 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Plastic? I don't think very likely.
    Edit: you have a ford now. That truck is new and clean you should have no problem.
    IIRC those are mounted on a tab with access to the back side. I would just drill them out and if you fuck it up its easy enough to through bolt it with a nut on the backside.
  11. Jan 21, 2014 at 8:33 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    If it was plastic on the back side that would be nice....
    I think the little hard line junction thing has a metal back though. I'll take another look, maybe I can get a thin reciprocating saw blade in there out just break the plastic if it is plastic
  12. Jan 21, 2014 at 8:33 AM
    Pugga
    Massachusetts
    I have the Ford, not Chris. The Ford comes with forward mounted tie downs :stirthepot:
    The Tacoma bed bolts are large torx head that go through the bottom of the bed to the frame. No doubt they'll come out fairly hard but they shouldn't be terrible. I'd only take one out at a time to make sure the bed stays lined up while you work.
  13. Jan 21, 2014 at 8:36 AM
    Noelie84
    Noel
    Wales, Maine
    Pugga traded for a Ford.
    I thought Abba still had a Tacoma...?
    Edit: Yeah, what he said ^
  14. Jan 21, 2014 at 8:39 AM
    Noelie84
    Noel
    Wales, Maine
    Especially on a 2010; the bolts shouldn't be rusted into place yet. Get underneath it and have a peek. If they're rusty, take a wire brush to them to clean the threads up, and then douse them with PB Blaster and let it sit for a while before you try to take them out. If they're not rusty, skip the wire brush and just use the Blaster. They'll come out slicker than snot on a doorknob.
  15. Jan 21, 2014 at 12:17 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Any snow down in ma yet? I'll be leaving freeport for home around 430 or so, hopefully all the retards are off the roads by the time I get to ma
  16. Jan 21, 2014 at 12:28 PM
    Pugga
    Massachusetts
    Not yet (at least not in Cambridge), heard it was snowing in RI already though.
  17. Jan 21, 2014 at 12:31 PM
    wildmank99
    wildmank99 Well-Known Member
    kevin
    Chicopee Mass
    08 sr5 4x4 3"lift with 33's and sounds
    No snow in Chicopee yet
  18. Jan 21, 2014 at 12:51 PM
    Noelie84
    Noel
    Wales, Maine
    Are you working in Freeport or something? seems like you're up there a lot of late. Must be a bitch of a commute, if that's the case...
  19. Jan 21, 2014 at 12:56 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Thanks
  20. Jan 21, 2014 at 12:56 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Its coming down pretty hard here. New lights :D
