New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Apr 25, 2014 at 4:58 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    My hot water comes off my boiler. The heat is off but I'm still burning K1 :facepalm:
    I'm seriously considering installing an on-demand water heater for the domestic water and converting the boiler to a cold-start unit for the heat.
  2. Apr 25, 2014 at 5:08 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That's sort of counter productive...
    Morning all
  3. Apr 25, 2014 at 5:38 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Ya, like 3/4 of a tank.
    Very tue
    Mine too, we have a furnace/ tankless hot water heater. Saves electricity, but i'm not convinced of an overall savings. When you haven't used the hot water in a while it can take a long to to flush the cool water out of the pipes and get the hot water to the shower head/ sink etc..
    That's what I want too. From my research it's the only good solution to the hot water taking forever sometimes. Then if the t-stat tells the furnace it needs to heat one of the floors, the hot water temp goes down substantially. Annoying.
  4. Apr 25, 2014 at 5:49 AM
    Noelie84
    Noel
    Wales, Maine
    That's weird. I actually have better water temperature when the boiler's heating a room and I'm taking a shower.
  5. Apr 25, 2014 at 6:14 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Ya, not sure what's up with it. They've been out multiple times to look at it. I also suspect a shitty insulating job, if any in the hot water tube corridors. I've found other area's where the builders did s half ass job insulating, and I suspect this is also one of them. I say this because in the kitchen which is on the first floor if you open any of the cabinets that are under the sink or immediatly adjacent to it it's freezing. You can feel the cold air coming up the holes where the hot/ cold lines enter cabinets for the sink
  6. Apr 25, 2014 at 6:30 AM
    Pugga
    Massachusetts
    That shouldn't happen. If you have one boiler that heats the domestic hot water and the heating pipes, they should be separate coils in the boiler. If there is a call for heat, the boiler should fire up and, if anything, you should have warmer water for your domestic water (the domestic water coil is generally smaller and heats up quicker than the heating coil).
    Aside from a point of use hot water heater, the only other option I'm aware of to get hot water to the point of use quickly is a recirculating pump. The downside to that is it requires twice the amount of piping and an added pump.
  7. Apr 25, 2014 at 7:00 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    You can do a stand alone electric hot water heater inline with the hot water from the furnace. Not sure what's up with the domestic hot water portion, they've been out multiple times. Like I said above, I suspect crappy insulation in the hot water conduit corridor up tot he second floor to be a big part of it. Unfortunately, not really any way to check it out without cutting a bunch of holes in my walls.
  8. Apr 25, 2014 at 7:05 AM
    eborgie
    eborgie No Yotas Here
    Erik
    Bellingham, MA
    2023 Bronco Sasquatch
    Do not put in electric heat if you can avoid it. Electric heat is horribly inefficient.
  9. Apr 25, 2014 at 7:11 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    No electirc heat, but considering doing a supplemental hot water heater inline with the current hot water on demand furnace.
  10. Apr 25, 2014 at 7:17 AM
    eborgie
    Erik
    Bellingham, MA
    How long do you have to wait for hot water? Is the piping ridiculously long?
  11. Apr 25, 2014 at 7:22 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Can be around 10 minutes or more sometimes on the second floor. The first floor is at most a minute, not long at all. We only have one shower, and it's on the second floor. Up there it can be 10+ minutes, sometimes longer in the winter. I don't think they are that long, the furnace is offset maybe 30-35' laterally from the upstairs shower, and then 2 floors down in the basement.
  12. Apr 25, 2014 at 8:30 AM
    eborgie
    Erik
    Bellingham, MA
    I would go on http://www.masssave.com/ and get an energy audit. They may hook you up with some insulation for that pipe. I would recommend that site for anybody who owns a house and is serviced by one of the providers shown. It is funded by your electric, oil, and/or gas bills.
  13. Apr 25, 2014 at 8:58 AM
    NBFJCruz
    NBFJCruz Well-Known Member
    Brian
    Saint John, New Brunswick, Canada
    2007 FJ Cruiser 5AT, lifted, 285's, black-out
    lifted, 285s, black out, Defiant lightbar, triple Hella 100w
    Woke up today to snow on the ground.....APRIL 25th!!!!!! It's gone already but man oh man I am tired of this crud
    10 minutes running a tap is alot of water to put down the drain while you wait for hot.
    Is it an old house? Copper and other heavier metal pipe will dissipate the heat quickly on a long (uninsulated) run for sure. I have alot of plastic pipe due to the house only being two years old. 1300sq/ft Bungalow and even the furthest tap has hot in under 30sec. My only complaint is my water pressure. I need to pump up my tank and see if that cures it.
  14. Apr 25, 2014 at 9:03 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Nope, relatively new. Built in 2004, all plastic pipe except at the furnace itself.
  15. Apr 25, 2014 at 9:23 AM
    Pugga
    Massachusetts
    My wife has been trying to get me to do that energy audit and I absolutely refuse. Call it a tin foil theory but I can see them building up data of homes that aren't up to a certain specification and the next step would be forcing all homes to meet a certain spec. Now they have a comprehensive list of everyone that is outstanding. I borrowed a thermal camera from work and did my own assessment and have been making insulation upgrades as I go.
  16. Apr 25, 2014 at 9:33 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    You should see all the new residential building codes for energy efficiency, some of them are outrageous.
  17. Apr 25, 2014 at 9:38 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    This..and definitely insulation, cheap fix for a few issues.
  18. Apr 25, 2014 at 9:40 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Looks like it was going to start without me :(
  19. Apr 25, 2014 at 9:42 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I'd bet the control isn't set for hot water priority. If you have a Honeywell control that has hot water priority, it will not allow the baseboard circulator to come on if your pulling hot water. Water on demand off of the boiler work great for the first few years until the coil starts go get clogged and is then less efficient in transfer. Then you wind up with the drop in water temp over time issue and the ladies start complaining that the water goes cold when shaving the legs... I had the same issue about 5 years ago on a boiler that was maybe 6 years old. I looked at a few options. Gas fired on demand systems work really good if you don't over draw the capacity that the system has. I went with an indirect fired water heater which is basically another zone with it's own circulator and storage tank. I found my oil consumption went down with this set up as the furnace wouldn't kick on everytime you opened the hot water tap. If you have the access and room, you could install a water heater (tankless gas, indirect, or whatever) closer to the bath on the second floor - trying to split the distance between the baths and kitchen. Pipe insulation really helps too.
  20. Apr 25, 2014 at 9:47 AM
    Noelie84
    Noel
    Wales, Maine
    Do you own your home, Sloth? Or do you guys rent?
