New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jul 2, 2014 at 3:57 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I used to be the same way but after using a good combo I will never go back
  2. Jul 2, 2014 at 3:58 PM
    BostonBilly
    Easton
    Good to know. I will try and get it done tomorrow
  3. Jul 2, 2014 at 4:40 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Seth thanks for making the trip over to meet me . This sliders will work out perfect !
    Denis thanks for the radiators . They are smaller then what I have now but I think I can make it work .
  4. Jul 2, 2014 at 5:32 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I'm having a brain fart here...hopefully someone here can help me clear it up.
    I bought some LED lights for a bed light project. I want to be able be able to switch them on via a rocker switch and I want them to turn on when the tailgate is down. I plan on tapping the running light of the tail light with a small inline fuse for protection.
    Now...if I want to do this with a SPDT switch, I'd have to put the switch on the negative side of the circuit, correct?
    Thus it would be as follows:
    +12V LED strip connected directly to +12 of tail lamp running light.
    -12V of light to middle pole (Pole 3) of SPDT switch.
    Pole 1 - directly to chassis ground
    Pole 3 - to door/hood pin
    In theory if the switch is set to "ON", the ground goes through the switch directly to ground and illuminates.
    If the switch is set to "Tailgate", when the tail gate is open the door pin grounds and the light turns on.
    I know it's not preferable to switch the ground, but with a small LED draw with a small inline fuse, am I going to run into any issues?
    The reason I am tapping the tail light power is that I really only plan on needing the lights on when it's dark and typically if I'm loading the truck, I'd have the ignition on (or I can at least turn it on using my remote start) and it greatly condenses the wires that I have running through the chassis of the truck.
    I know that in theory I could just use only the door switch and turn them on every time I drop the tailgate or just have them on a switch so they only turn on when I have the switch on, but I thought this might give me the best flexibility.
    I have an email into OTRATTW in regards to a Carling style switch that's weatherproof. We shall see.
  5. Jul 2, 2014 at 6:17 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
  6. Jul 3, 2014 at 3:15 AM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    Good luck, i hope they work and don't leak!
  7. Jul 3, 2014 at 5:23 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Alex is the the finised product or does something go over the white area?
  8. Jul 3, 2014 at 5:25 AM
    Itspronouncdwatah
    Itspronouncdwatah Well-Known Member
    JJ
    Manchester, NH
    Sooo after many months of searching I think I finally found my Taco not sure on the year but its a SWB access cab. I would prefer a DC but a full size bed is a must and I've had no luck finding a good DCLB I like
  9. Jul 3, 2014 at 5:40 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Just tanked up the truck this morning, and averaged 18.5mpg this tank, over 170 miles. Not bad, considering 140 miles of it was towing a trailer (roughly 70 loaded and 70 empty).
    My '99 was lucky to get 14 towing any kind of weight, and it had a lot harder time pulling away from stoplights.:woot:
  10. Jul 3, 2014 at 5:41 AM
    Noelie84
    Noel
    Wales, Maine
    Just as well. Access cabs look cooler anyhow, and the DCLB is a land yacht.
  11. Jul 3, 2014 at 5:58 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I use braid on all my casting setups except for my stock trout rod. One thing to be aware of, braid is much, much stronger than mono or flouro for the same thickness and you may want to use a 2' leader of flouro. If you fish in heavy cover areas or weedy lakes, bass fishing and dragging your baits, you can lose a lot of line if you get snagged. I tie a small leader of flourocarbon just so I can break it off if I get snagged. My baitcaster has 50lb Power Pro braid on it for the diameter, so if I get snagged I have to cut it off at the boat. That stuff is not cheap and I'd like as little of it as possible to end up in the lake.
  12. Jul 3, 2014 at 6:13 AM
    vjherrera
    vjherrera Well-Known Member
    Vince
    Chicopee,MA
    I use to do the same thing untill I switched over to co-polymer fishing line. It has all the qualities of Braid, Floro and Mono and casts like a dream...like you jetho I had to use a high test when I put it on my bait caster due to its similar diameter as braid.
    here is the stuff I use
    http://www.amazon.com/Hi-Seas-Black-Widow-Co-Polymer-Line/dp/B004UUJZ98
  13. Jul 3, 2014 at 6:25 AM
    jethro
    Geoff
    Southern NH
    I have not used the co-polymer stuff yet. It has no memory at all like braid? That's the only reason I love the braid, zero memory. But the downfall I found, especially on the baitcaster since I have to use the bigger diameter, it doesn't cast as far- I think because of the weight? I will have to try some!
  14. Jul 3, 2014 at 6:35 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Hey I like my yacht!
  15. Jul 3, 2014 at 6:45 AM
    Noelie84
    Noel
    Wales, Maine
    Congrats!
    Now turn that thing around for me on a back road without utilizing the shoulders. :D
  16. Jul 3, 2014 at 6:51 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    NP. How many points do I get to use?
  17. Jul 3, 2014 at 7:02 AM
    johnnym
    john
    NH
    10 points and 2 tree bumps . :p no chainsaw
  18. Jul 3, 2014 at 7:07 AM
    vjherrera
    Vince
    Chicopee,MA
    very little memory, I will tell you this though it took me a while to get the settings right on my black max bait caster to avoid the bird nests...to be honest I think I will go back to floro for that real but on a spinner it works like a charm and casts far. plus you will be surprised how much the line disappears under the water
    these are two i caught before I left VA, both the striper and blue were caught with 8 pound test co polymer line with no leader what so ever, and if you have ever fished for blues or stripers around heavy structures you know what they can do to a line
    and just a tip because it has a really silky feel the best knot to use on it is the palomar knot
  19. Jul 3, 2014 at 7:07 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    :laughing:
  20. Jul 3, 2014 at 7:12 AM
    BostonBilly
    Easton
    Nice fish and everyone is saying the same about the knots
