New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Sep 2, 2014 at 10:49 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Wait aren't you supposed to hit the hipsters?
  2. Sep 2, 2014 at 10:51 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I don't think a Mustang will survive hitting that many people.
  3. Sep 2, 2014 at 10:55 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Bigfoot = Brakes
    Hipsters = Gas
    I should see if they'll rent me one with an Interceptor-style push bar :D
  4. Sep 2, 2014 at 10:56 AM
    vjherrera
    vjherrera Well-Known Member
    Vince
    Chicopee,MA
    that's the point...I mean don't hit a 8' bigfoot, that will mess up your day...but a 6' hipster at 120 pounds dripping wet might scratch the paint...and you get an extra 50 points if you save the PBR he has hostage...but you didnt hear that from me....:spy:
  5. Sep 2, 2014 at 10:59 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Make sure to get the extra insurance
  6. Sep 2, 2014 at 11:01 AM
    vjherrera
    Vince
    Chicopee,MA
    yes, bigfoot is a protected species
  7. Sep 2, 2014 at 11:18 AM
    emelianenkov
    Alex
    NORTH POLE
    True... Especially the heavily armored Steam Punks in seattle
  8. Sep 2, 2014 at 11:32 AM
    Noelie84
    Noel
    Wales, Maine
    I'll just rent this one. Problem solved!
  9. Sep 2, 2014 at 12:28 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Mine is 50/5, generally tests out at 55/6. My modem is a DOCSIS 3.0.
    Of course, even at those speeds I'm spoiled by work's connection:
  10. Sep 2, 2014 at 12:34 PM
    vjherrera
    Vince
    Chicopee,MA
    does it come with a free Michael knight cardboard cutout? proof that people with high credit card limits should not be allowed in the accessories isle in autozone
  11. Sep 2, 2014 at 12:43 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    It's probably a V6
  12. Sep 2, 2014 at 5:00 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I'd rather drive a V6 than that monstrosity. KITT is a Trans Am with the voice of Feeny, nothing else is KITT.
  13. Sep 2, 2014 at 5:02 PM
    DrFunker
    DrFunker Well-Known Member
    Anyone ever try a Crabbie's ginger beer?
    I saw them at the store. Got a 6 of Jack's Copper Legend instead.
  14. Sep 2, 2014 at 5:12 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    On a side note, I'm about to throw my ARB fog lamps off a building.
    When ARB designed them, they weren't exactly thinking long term. They use H3 bulbs, but the male spade connector they use extends outside of the small weatherstripping opening for the wiring. Because of this, it's impossible to replace the H3 bulb without either cutting off the spade connector or losing the weatherstripping grommet.
    So I got the brilliant idea when swapping bulbs to use a female metal spade connector at the end of the ARB wiring and tuck the metal spade connector from my new bulb inside the back of the housing, keeping all weatherstripping intact.
    The problem with this is I've now blown my 5th(!) fuse with this setup. I have tried just about everything to keep this from shorting out and it appears only one of the lamps keeps shorting. I have wrapped the metal spade connector in many layers of 3M Super 33 which apparently wears through. Last night I put a layer of heat shrink, more 3M Super 33 and then covered the metal of the housing with 3M Super 33 and heat shrink and i blew the GD fuse again today.
    I haven't taken it apart to see if I've worn through anything, but I'm starting to run out of ideas, short of sucking it up and moving the spade connection outside of the weather stripping and having to go through the hassle of cutting off the male connector of every new bulb, soldering in a new one and then re-wrapping it every time, which basically defeats the purpose of what I wanted, which was to have an easy plug and play setup.
    Blah, I'll figure something out, but any ideas would be helpful right now.
    EDIT: I really don't feel like ripping into it tonight and I'm completely out of fuses to use anyways. This stinks though because of the way my auxiliary fuse panel is wiring removing the fuse box cover in the engine bay is more of a headache than it needs to be.
    DOUBLE EDIT: I said eff it and moved the spade connector outside of the inner place (where the bulb goes) as I noticed the bulb was overheating. The new connection is between the metal housing and the plastic back assembly. The connection is pushed against the plastic backing that screws into the metal, but I have well insulated it as well. I will purchase new fuses once I get paid Friday and go from there.
  15. Sep 3, 2014 at 5:55 AM
    Noelie84
    Noel
    Wales, Maine
    Lol. Good job on that airline thread, Alex.
    Morning all!
    Hey McFly;
    Have you been using dielectric grease on the spade connectors? That'll keep moisture out of the connection and help prevent arcing at the connection, which might be why you're blowing fuses.
  16. Sep 3, 2014 at 6:18 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Morning all. Just got back from camping up upstate NY. Cut it a day short because it was supposed to hail and have heavy rain last night. Good news, the truck gets just over 16 MPG dragging the trailer and with the bed loaded up with all the camping gear and I can set the cruise at 73 and forget about it.
  17. Sep 3, 2014 at 6:20 AM
    Noelie84
    Noel
    Wales, Maine
    Cool. Where'd you go camping? Finger lakes region, or...?
  18. Sep 3, 2014 at 6:28 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Seriously. Where do you come up with that kind of crap? :rolleyes: Time to wake up and get real.
  19. Sep 3, 2014 at 6:35 AM
    Noelie84
    Noel
    Wales, Maine
    Shrug. Sometimes locking a thread is the best thing for it, haha!
    I have to commend the mods for being on top of that one; it never made it past the first page.
  20. Sep 3, 2014 at 6:41 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Fuck I missed more shenanigans
