New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Sep 16, 2014 at 1:58 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I did the oil in the gearbox and tcase today. Even after 60K. the original oil in the tcase still looked like new. Also, a 15/16" socket seems to fit slightly better than a 24mm socket on the drain/fill plugs. So far with the MT-90, there's less of a notchy feeling when shifting between 1 > 2 and 2 > 3.
  2. Sep 16, 2014 at 2:49 PM
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
  3. Sep 16, 2014 at 4:41 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    I'm gonna go ahead and assume that Sons of Guns is canceled...
  4. Sep 16, 2014 at 4:57 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Just realized you had an MT. Have you ever hear a clank noise when slowing down soon after a takeoff? I've noticed for awhile I go 1st to 2nd then slow to stop then there's been a clank type noise. For the life of me can't figure it out.
  5. Sep 16, 2014 at 5:01 PM
    emelianenkov
    Alex
    NORTH POLE
    Where does the clank seem to be coming from?
  6. Sep 16, 2014 at 5:06 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Most likely it's your driveshaft. The autos do it a little bit to. Actually most of the newish trucks that use a 2 piece driveshaft do it as well. I hear other people complain about it at work.
  7. Sep 16, 2014 at 5:08 PM
    ERMB
    2002 Land Cruiser
    Not a clue, it doesn't happen all the time but usually when it does it when I'm slowing down after not going very fast. Most times i hear it when I shift into neutral as I coast into a stop. It sounds external though.
  8. Sep 16, 2014 at 5:18 PM
    ERMB
    2002 Land Cruiser
    Interesting, I guess that makes sense. Wish I was more mechanically inclined when it comes to vehicles.
  9. Sep 16, 2014 at 5:30 PM
    replica9000
    2019 T4R ORP
    It could also be the gas sloshing around in the tank. I used to hear the noise when pulling into my driveway at night.
  10. Sep 16, 2014 at 5:41 PM
    ERMB
    2002 Land Cruiser
    I've noticed that before but, It's definitely a metallic clank noise. I think the suggestion about the drive shafts sounds like a viable culprit.
  11. Sep 16, 2014 at 5:56 PM
    emelianenkov
    Alex
    NORTH POLE
    COULD be the lockout on first gear opening back up once you go under a certain speed?
  12. Sep 16, 2014 at 5:56 PM
    replica9000
    2019 T4R ORP
    Gremlins
  13. Sep 16, 2014 at 6:07 PM
    ERMB
    2002 Land Cruiser
    Lol, I guess there's always something. Thanks for the help and suggestions guys!
  14. Sep 16, 2014 at 6:31 PM
    UrPebkac
    UrPebkac Well-Known Member
    David
    RI
    2016 GMC SIERRA
    X2 on the driveshaft! I get it on my auto I believe it to be the slip joint compressing with the rebound of the center support bearing(carrier bearing) when forces transfer from a load to a non load state.
  15. Sep 16, 2014 at 6:41 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I saw one article where he allegedly told her she'd better not tell anyone because he was all she had in this world. If it really started when she was 11 or 12, that could have really done some damaged mentally.
    Make sure your u joints don't have play in them. Otherwise, I agree with others, probably one of the other common noises and no need to worry.
    On another note, I can finally join the hunting ranks in MA. Just successfully completed the hunter ed course. Look out Bambi :D
  16. Sep 16, 2014 at 6:45 PM
    UrPebkac
    David
    RI
    2016 GMC SIERRA
    Anyone maybe thinking of going to Rausch on the 27-28th? I want to get out and wheel a bit. I know you new fathers likely can't! Congratulations btw!!
  17. Sep 17, 2014 at 4:16 AM
    Tiki Tacoma
    Tiki Tacoma Well-Known Member
    CT
    03 dbl cab trd
    I have a clanking noise in my 03 automatic that has been driving me nuts because i cant figure out where its coming from, and goin to a mechAnic saying "hey i have a noise under my truck" is just asking to get ripped off. Im planning on just greasing everything i cAn see under the truck to see if it gets rid of i
  18. Sep 17, 2014 at 4:33 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Morning folkses. Three more days and I'm on my way to the West Coast!
    :D
  19. Sep 17, 2014 at 5:18 AM
    replica9000
    2019 T4R ORP
  20. Sep 17, 2014 at 5:27 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Good morning bitches!
