New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Oct 15, 2015 at 4:34 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    "You know how it makes sense that we get you a family vehicle in the near future for family things...I bought a 3rd vehicle for myself, surprise!"
    You can totally potentially baby an Xtracab, right? Some sturdy ratchet straps, a few pool noodles and some poly fill stuffing and the baby is plenty safe.
    emelianenkov likes this.
  2. Oct 15, 2015 at 4:54 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Hey Mike your ARB and light bar will totally fit a 2015 DBL cab. Get um while you can! Just sayin... :stirthepot:
  3. Oct 15, 2015 at 5:06 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    I thought about it but I'm not too worried right now. I figure we will get a family car and I can always borrow my Mom's Forester in a pinch. My next truck will be a DCSB ultimately but I'm going to rock the AC as long as possible.
    EDIT: My babying comment was about the 91, not my truck.
  4. Oct 15, 2015 at 5:39 PM
    Cable-guy
    Cable-guy Well-Known Member
    Kevin
    Peabody, MA
    2008 DCSB
    First car was a 84 ford exp looked just like this one. I loved that car til it jumped onto its roof while I was driving at " a safe a reasonable speed " while I was supposed to be in school.
  5. Oct 15, 2015 at 8:19 PM
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    Looking for opinions:
    I am considering tweaking my Taco rear suspension ahead of getting my trailer registered. My thoughts are All Pro Expo Leaf pack and/or Firestone Air bags. I'm leaning toward the spring packs 1st...thoughts?
  6. Oct 16, 2015 at 2:05 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
  7. Oct 16, 2015 at 3:30 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I had installed the Firestone bags on my GMC and they worked great. I went with the on board comp with gauges setup to avoid gas station fill ups. I went with Firestone because their bags sat between the axel and frame and not just bolted to the side of the frame like others I saw.
  8. Oct 16, 2015 at 4:14 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Sounds legit... Morning everyone
  9. Oct 16, 2015 at 5:30 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I think expo's are supposed to give 4" of lift unless you keep a couple hundred pounds of weight in the back all the time. The expos are supposed to flex pretty good too so I'm not too sure how they would do with all that weight from a trailer. I think a better spring option in your case would be the Dakars. I myself would probably do the dakars and if they needed help then add the bags. Just my .02C's. GL
  10. Oct 16, 2015 at 6:32 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If the truck isn't really going to be used for off roading any longer, I'd go air bags for the adjustability. Are your leafs shot? If not, Wheelers makes, or used to make a heavy duty version of their 3-leaf AAL that was decent.
    I thought the Expos were supposed to be really stiff. Like maintain 3-4" of lift with several hundred lbs in the bed. The All Pro standard pack sounds like the one you described.
  11. Oct 16, 2015 at 7:31 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Not really stiff only 20% stiffer and no over load spring. The expos (the way I understand it) are designed to carry the load of bed rack, RTT etc for an expedition distributed evenly in the bed but still be able to flex pretty well. The weight of a trailer is on the very back of the truck. The Dakars will still flex well when off roading (though not as good as the expos) but handle the weight of hauling better. IMHO
  12. Oct 16, 2015 at 7:58 AM
    Pugga
    Massachusetts
    From All-Pro's website:
    "All-Pro's Expedition Leaf Springs feature a 20% higher spring rate than their standard leaf springs. They are otherwise identical in dimension and quality, providing the same eye-to-eye measurements and wheel travel. On unloaded Tacomas, they will result in a 1" taller stance than the stated lift height of 3". The stated lift height is maintained with loads of 400-500 lbs of cargo."
    I see what you're saying now though, I misread your original post. The Dakars have the 2 overloads so they won't squat as bad when loaded down.
  13. Oct 16, 2015 at 8:04 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Correct. That's why I say try the Dakars 1st without bags and then add the bags if needed.
  14. Oct 16, 2015 at 9:03 AM
    eborgie
    eborgie No Yotas Here
    Erik
    Bellingham, MA
    2023 Bronco Sasquatch
    After towing a rig with my tacoma, I would recommend air bags. No need for special leafs, they will effect your ride quality too much. Air Bags are more adjustable, so you can have the support when needed and take it off when you dont. Also, invest in a good brake controller and learn how to properly set it up.
    BostonBilly likes this.
  15. Oct 16, 2015 at 9:21 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    :woot:
    Just scored a Savage 111 in 30-06 w/a 3-9X50 Simmons scope for $225 on my lunch break. :bananadance:
    Edit- Used, but the bore and bluing are immaculate.
    johnnym likes this.
  16. Oct 16, 2015 at 9:53 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Yeah but his rig is totally set up for wheeling already. If he is going to keep it like that I think the Dakars are still a little bit better as like Mike said they will be vulnerable to damage as he's taking it off-road.
  17. Oct 16, 2015 at 10:08 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    I don't suppose anyone around the Worcester area has tools to scan ans set new TPMS sensors in our trucks? I picked up a set of factory take-off steel wheels and sensors that I just had snow tires installed on, will need to have the new sensors set up in the truck.
  18. Oct 16, 2015 at 10:12 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    That's a deal and a half
  19. Oct 16, 2015 at 10:30 AM
    Pugga
    Massachusetts
    Do any of you guys know someone who does upholstery? I'm looking to get a motorcycle seat recovered and not sure I want to tackle that myself if I can have a professional do it at a reasonable cost. I can do it myself but I'm sure it will be a very noticeable DIY job in the end.
  20. Oct 16, 2015 at 10:37 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    http://www.newenglandtrim.com/
    I used these guys for a tear in a motorcycle seat a while ago and they did it quick and cheap. Looked better than I expected too, was about $100 or so.
    If I was to do it again, I would tackle it myself for the $30 in materials or so....from what I have found, if you follow the steps correctly, its not a difficult job to make look great.
    Check out this site if you are still unsure on hiring someone to do it for you:
    http://www.diymotorcycleseat.com/modify_4.htm
