New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 14, 2016 at 6:12 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Wow that sucks. I liked him too
  2. Jan 14, 2016 at 7:25 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
  3. Jan 14, 2016 at 7:53 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Fuck that guy. That's like jumping in a gator infested swamp and expecting the park rangers to come save you.
    Make your bed and sleep in it, like a fucking man.
  4. Jan 14, 2016 at 7:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  5. Jan 14, 2016 at 10:48 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Hello
    The story is I have a Curtis snow plow that I use for home use.
    This weighs in around 500lbs.
    This season I noticed how low the front end is when I put the plow on.
    I've only 270,000 in my Taco . yup stock front end.
    I did replace the rear springs. No shocks
    I would like to replace the springs and shocks up front .. shocks in the rear also.
    I'm not looking to raise it just bring it back to stock height.
    Is there some one that sells a combination for what I'm looking for?
    Would they be stronger than stock springs?
    Any info would be welcomed! :wave:
    Thanks
    Sean
  6. Jan 14, 2016 at 11:08 AM
    Pugga
    Massachusetts
    Do you want the front end at stock height with the 500 lbs on the front or unloaded? Would you be willing to go a little taller than stock unloaded?
    You might want to look into just a fresh set of springs and shocks (buy someone's new take offs) and something like Superbumps or Timbren bump stops. They are basically just a taller, load carrying bump stop so they'd help support the front end when loaded, but you'd maintain stock height and ride when unloaded.
    YOTA LOVER likes this.
  7. Jan 14, 2016 at 11:47 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I think the lowest lift with the highest spring rated coils would be the Eibachs. Do those with a set of 5100's set at 0" and a AAL in the so it was level would be a good bet if you want to add some resistance to sagging with the suspension. Mike's idea with the Superbumps and Timbren's is very good as well and wouldn't effect the everyday ride either
  8. Jan 14, 2016 at 12:20 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
  9. Jan 14, 2016 at 12:32 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Only 500lbs? I'm jealous, lol. My fisher's up around 750 or better. Squats the front end about 2-3 inches when I lift it.
    I'd also vote for the Timbren stops, but keep in mind that they can act like a pogo stick on the bumps and may cause some plow jumping, so make sure your chain's in good shape and well-secured.
  10. Jan 14, 2016 at 1:04 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I just use a USB stick full of mp3s (nearly 11k). Once in a while I may use Pandora or the radio.
  11. Jan 14, 2016 at 1:06 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Not only while plowing but any time they get hit because they are designed to push back a bit. If it was me I'd do the suspension (which is not expensive) because his is well used and needs to at least be refressed so why not update a little bit. Then if more is needed I'd add the Superbumps because they are less invasive
  12. Jan 14, 2016 at 1:09 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    If he's just going to do the bumpstops I'd say then do the Timberens because he probably needs all the help he can get
  13. Jan 14, 2016 at 1:51 PM
    Noelie84
    Noel
    Wales, Maine
    Right, that's what I was talking about. It'd be more of a risk while he wasn't plowing because the suspension would be squatted more. If he hit a bump that bounced off the Timbrens he'd have some epic plow slam (which sounds terrible when it happens) and if his chain's not secured his plow can drop down and damage itself on the road surface. I was having that problem with the Dodge a couple of years ago, before I replaced the front leaves.
  14. Jan 14, 2016 at 3:35 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I just listen to the old school..CD.
  15. Jan 14, 2016 at 4:28 PM
    replica9000
    2019 T4R ORP
    I still buy them. Seems I'm going to have to buy online now, since stores like FYE and Newbury Comics seem to be shrinking the CD sections in their stores.
  16. Jan 14, 2016 at 5:18 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Sean
    I have a bunch of springs and shocks . From my Tacoma hoarding days .
    Trd offroad front springs
    Trd Sport front springs
    Struts that were taken off at 20k miles
    Rear 3 leaf pack .
    Let me know if you are interested in anything . I'm in Boston a few days a week .
  17. Jan 14, 2016 at 9:55 PM
    ABA180
    East Bridgewater MA
    I own 2 burned discs, and that is only b/c at the time they weren't released in a physical. I burn my rare stuff and use those as well, but otherwise I hate the sound quality loss with MP3.
    Fkn hate FYE. No, I don't want replacement plans on my discs..I own discs i bought when I was 16 that still play fine. No, I don't want your damn free magazines. And no I don't want a membership. I'm just buying a fucking CD.
    Newbury is my favorite, but the store 15 min away from me closed a year ago so sadly FYE is closer for me now unless I'm near the Kingston or Norwood area.
  18. Jan 15, 2016 at 2:36 AM
    johnnym
    john
    NH
    There is a newbury on the Avon / stoughton line.
  19. Jan 15, 2016 at 7:10 AM
    ABA180
    East Bridgewater MA
    Was. That's the one that closed.
  20. Jan 15, 2016 at 7:23 AM
    smcgill
    Sean
