New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 29, 2016 at 8:12 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    But OME only does shocks for their 3" lift kit for our trucks, right? I didn't think they offered anything for factory ride height.
  2. Feb 29, 2016 at 8:13 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Yeah I think it is because it's the cheapest way to have an adjustable suspension. With the OME stuff the only way to raise or lower your suspension you have change springs. With the billy's you just take them apart adjust and put back together. Nothing is easier to adjust than a set of coilovers but they are big bucks and people get scared of rebuilding them.
    When changing out the suspension each time I did it you could tell it was and upgrade. The stock shocks were very skinny compared to the 5100's that had a lot more diameter to them. That means it would hold more fluid and have less fade. Same thing again when I got the OME, they are a lot beefier than the 5100's
  3. Feb 29, 2016 at 8:16 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Gotcha. Makes sense then.
  4. Feb 29, 2016 at 8:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not necessarily true. OME offers shocks for our truck but the ride height is dictated by the springs. You can go with shorter springs and get less than 3" of lift. I can you can go all the way down to only 1-1.5" of lift with OME 883x springs. You should be able to use OME rear shocks at stock height as they still operate within the same parameters as the stock suspension (still use the same bump stops so you shouldn't bottom the shock out).
  5. Feb 29, 2016 at 8:20 AM
    Noelie84
    Noel
    Wales, Maine
    Hm. I may have to look at the OME's too, then. Definitely need new ones, though. I've got nearly 70k on the Tacoma now and the ride is definitely getting bouncy.
  6. Feb 29, 2016 at 8:23 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Nope they can used for springs from 1" to 3" of lift. Check out all the lift options by using different spings
    OME 883 (16.5mm bar dia)(375mm 14.76in free height)(9.8 #turns)(4.7kg coil weight)(Rate: 590 lb/in 103 N/mm) = 1" Lift on DBL Cab
    OME 884 (16.5mm bar dia)(390mm 15.16in free height )(9.8 #turns)(4.7kg coil weight)(Rate: 590 lb/in 103 N/mm) = 2" Lift on DBL Cab
    OME 885 (16.5mm bar dia)(395mm 15.55in free height)(9.8 #turns)(4.7kg coil weight)(Rate: 590 lb/in 103 N/mm) = 2.5" Lift on DBL Cab
    OME 886 (17.5mm bar dia)(402mm 15.83in free height)(10.6 #turns )(5.9kg coil weight)(Rate: 660 lb/in 115 N/mm) = 2.5" Lift on DBL Cab with as much as +200 weight added
    OME 887 (16.5mm bar dia)(400mm 15.75in free height)(9.8 #turns )(4.7kg coil weight)(Rate: 590 lb/in 103 N/mm) = 3" Lift on DBL Cab
    Sourced from here; http://www.headstrongoffroad.com/st...-__Various_Lift_Heights_Available_(PAIR).html
    EDIT; Looks like Mike beat me to it. I was going to find the average ride height for each spring if you guys wanted
  7. Feb 29, 2016 at 9:47 AM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Got off the phone with Toyota corporate. What a waste of time... I can't decide what is the best way to go now... I can get the under coating from Toyota which is basically throwing a duck a life preserver... They basically told me if there is no hole 10mm or more do to rust, then in their eyes the frame hasn't been structurally compromised... Ergo it passes inspection. Even though my frame is only 1/32 thick in some places... The guy said that is only surface rust... Even though I can pick off chunks with my fingernails. He says only the dealership can make the call, but has to meet these exact criteria, there's no room for other factors, and the dealer says it's out of their hands... Back and forth... Back and forth...
    My dilemma now is do I go through the trouble of fixing it properly, or go against my moral fibers, give up on the truck and trade it in for a newer, rust free vehicle? Or get a Ford raptor... (lol jk)
    fixing the frame is going to be more costly than taking the hit and trading it in for a newer one. If you factor time lost at work, materials... Energy...
    Or trade it in for a v6 sr5 base model and kit the living piss outta it? I've already got all the suspension... Put arb lockers front and rear, re-gear and weld up some new bumpers? Although my truck is great and I don't like the newer models with all the added electronic BS... My gut says stay with what I have, but I'm getting an ulcer thinking about what I should do.
  8. Feb 29, 2016 at 10:00 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    wheel it untill it snaps. Get insurance to buy a new frame.
  9. Feb 29, 2016 at 10:12 AM
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    Jeez that's some serious tap dancing there Cam! Maybe you can make a hole with a bfh on a thin spot?
  10. Feb 29, 2016 at 10:18 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Cam as much as it sucks I would get out of that truck for a new one. That frame is junk just like all of them. It will cost you down time and labor, both of which only you can put a price on. What about material, both stock and welding supplies. Now whether you go Toyota or any other manufacturer is the question. I would sit back and ask what I need and what I want for a vehicle and then start the hunt. Also what about liability? I don't pretend to know anything about the legal issues if something happens but the truck will be on the road not just a trailer queen brought in the woods.
  11. Feb 29, 2016 at 10:21 AM
    Pugga
    Massachusetts
    So after all that BS, you'd still trade for another Taco? I'd be running from Toyota with my middle finger in the air. I think you should trade for an F150 :stirthepot:
  12. Feb 29, 2016 at 10:36 AM
    BostonBilly
    Easton
    Another one joining the outsiders. Nice
    Darth_Yota likes this.
  13. Feb 29, 2016 at 10:43 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I highly doubt that. Everyone in his family drives a Toyota
  14. Feb 29, 2016 at 10:45 AM
    Pugga
    Massachusetts
    Hopefully he told the asshat corporate douche that also. Even if everyone on the family drove a specific brand, there's only so much abuse one will take before jumping ship.
  15. Feb 29, 2016 at 10:46 AM
    Pugga
    Massachusetts
    "One of us" (in my best iRobot voice)
    BostonBilly[QUOTED] likes this.
  16. Feb 29, 2016 at 10:49 AM
    BostonBilly
    Easton
    :p
  17. Feb 29, 2016 at 11:02 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    Just gotta make sure if you get a Ford, you eat beans straight from the can and drink regular budweiser, while saying 'Murica at any opportunity you get.
    Darth_Yota, Noelie84 and BostonBilly like this.
  18. Feb 29, 2016 at 11:07 AM
    Noelie84
    Noel
    Wales, Maine
    I take out my dissatisfaction with Toyota by driving old Mopars instead. After that whatever problems the Tacoma has don't seem that bad :p
  19. Feb 29, 2016 at 11:40 AM
    Pugga
    Massachusetts
    That sounds like a personal problem. I say 'Murica at any opportunity but it would take a lot more than a Ford emblem to make me eat beans and drink Bud.
  20. Feb 29, 2016 at 11:41 AM
    Darth_Yota
    Cam-moron
    Somewhere USA
    I understand why the dealerships hands are tied, they're governed by federal law and company set criteria for what fails a frame... And the Toyota higher ups made the criteria absolutely absurd... If the frame has a hole, it fails... But if a frame is paper thin without a hole but it is deforming because of rotten metal, which is obviously structurally compromised, it passes? My front spring hangers are literally bending in because of how little metal is left on the frame...
    Falmouth Toyota is an awesome dealership. Their service dept rocks. I wouldn't even consider going somewhere else. Let alone switch to another brand.
