New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jul 27, 2016 at 9:32 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    How 'bout if she sets up a video feed so we all can see???
  2. Jul 27, 2016 at 9:50 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    A lot of the slag was falling off and for some reason there was a ton of surface rust on it. I also have the maker's finger prints embedded into the steel hahaha.
  3. Jul 27, 2016 at 9:50 AM
    yazmatic
    yazmatic Well-Known Member
    Paul
    2012 DCSB TRD SPORT
    Bilstein 5100's Eibach 620 springs SCS Stealth 6 Matte Bronze BF Goodrich All Terrain TA KO2 265/70/17 SOS Front Bumper Full Hoops Safari AirFlow Snorkel
    hey everyone....
    my question of the day (it wont be the only one):
    Im going to be putting my bilsteins at the .85 setting with the 1.6 eibach coils, which, mathematically, would give 2.45 inches of lift. for the rear, im putting in a 1.5 inch AAL progressive pack. Right now, its currently higher in the back and im guessing its going to be higher after the .85 seting and the AAL install. the question is!
    If i had spacers to get the extra .5 lift up front, are these the ones i should/can use? edit: i have purchased LR UCA's so lifting it will not cause alignment issues. (hopefully)
  4. Jul 27, 2016 at 9:51 AM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    trying to get lifted for this NH trip!!!!!!!!!!!!!!
  5. Jul 27, 2016 at 9:59 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Ya they all come with surface rust.
  6. Jul 27, 2016 at 10:03 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    With the 5100s at 0.85 and the eibachs you'll probably get closer to 3" lift since you don't have any additional weight.
  7. Jul 27, 2016 at 10:13 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Knock off the burrs a wire cup and an angle grinder. Hit the stubborn ones with a hammer and a screw driver to send them flying. Sanding takes forever with steel.
  8. Jul 27, 2016 at 10:26 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Mine had a little splatter here and there. This is exactly what I did before wiping everything down with MEK and priming.
  9. Jul 27, 2016 at 10:39 AM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    That's what I'm going for. Are the 3/8 spacers from wheelers the correct ones for my application?
  10. Jul 27, 2016 at 11:01 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Don't forget to compensate for Tacoma lean. I had the 1/4" in mine and still had it a bit. Are you leaving your overloads in?
    Did you have issues with the front diff rumbling or not with your current lift? It might not be a bad idea to throw in the ECGS bushing.
  11. Jul 27, 2016 at 11:07 AM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    I currently have the 1/4 spacer in, with no visible lean. So would I have to stack another 1/4 on that? As far as rumbling, I do get a vibration when accelerating from 15-25 MPG. But, Ive had that ever since I bought the truck stock so it's nothing new. I would like to leave the overload in because I manage property and I have to load some things from time to time. I'll have to look into the ECGS bushing.
  12. Jul 27, 2016 at 11:21 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I'd leave just the current 1/4" spacer and not use the other ones since you don't have armor. You'd need longer top studs too with the 3/8" spacers
  13. Jul 27, 2016 at 11:34 AM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    These are my current measurements.
    ______________________
    Front left: 21.5
    Front right: 21.5
    Back left: 22
    Back right:22
    When I put the bilsteins at .85, I'll be at roughly 22.35 in the front. With the 1.5 AAL in the rear, I'll be 23.5.
    Ideally I'd like to use the spacers to be a little bit more level instead of having over an inch of rake because of the AAL. Wheelers sells the two spacers with longer studs. How ill-advised is using the spacers?
  14. Jul 27, 2016 at 12:33 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Nothing wrong with the spacers, you can't stack them though. If you want to use them I'd uss 3/8" on the drivers and 1/4" on the passenger side. I'd just be concerned it will ride really stiff.
  15. Jul 27, 2016 at 12:39 PM
    Bruce988jl
    Southern NH
    Anyone here run their CB Antenna to the bed? If so where'd you come out of the cab through?
  16. Jul 27, 2016 at 12:42 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    There should be a grommet at the rear of the cab. Might also have one by the trans, crawl under and you should be able to locate them.
    Bruce988jl[QUOTED] likes this.
  17. Jul 27, 2016 at 12:44 PM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    Ok thanks. So the 1/4 that's already in the driver side, I should move it to the passenger side and throw in a 3/8 in its place?
  18. Jul 27, 2016 at 12:46 PM
    Pugga
    Massachusetts
    If you have an automatic, pull the center consol and come out the grommet used for the E-brake cable. It's convenient since the CB itself is likely going to be mounted in a similar location.
    Bruce988jl[QUOTED] and BadDNA like this.
  19. Jul 27, 2016 at 12:50 PM
    Pugga
    Massachusetts
    Yes, and you will likely need longer studs on the driver's side. When I put mine in, I only used the 1/4" spacer on the driver's side and the threads barely made it.
  20. Jul 27, 2016 at 12:50 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    I ran mine through a grommet behind the drivers side front seat. Its a a good size one i actually have two wires running through it currently power to my bed 12v outlets and my CB cable.
