New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Aug 3, 2016 at 6:22 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    I need to do this same thing, how hard was it? Something I can tackle on my own? I want to try to do it before I go back to work next month.
  2. Aug 3, 2016 at 6:39 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Really easy you need the following:
    21mm socket for lugs (assuming stock)
    17mm socket for caliper to knuckle bolts
    12mm socket for abs sensor line bracket
    C-clamp
    Rope/ wire/ zip ties
    Anti sieze
    Obviously rust can make things trickey. Basically remove the wheel, pull cotter pins from caliper slide pins, pull caliper slide pins, remove brake pads, remove abs sensor line bracket, remove 2 caliper to knuckle bolts and tie caliper up/out of way. Remove old rotor, clean hub face and apply liberal anti seize to it. Use c-clamps (or a big ass set of adjustable pliers like I prefer) to compress the caliper pistons. After that just re-assemble.
    ERMB[QUOTED] likes this.
  3. Aug 3, 2016 at 6:40 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    It's easy. Let me know if you want a hand
    ERMB likes this.
  4. Aug 3, 2016 at 7:04 PM
    ERMB
    2002 Land Cruiser
    Thanks, having a set of eyes that know what's what would be a huge help!
    Thanks Seth, That's a huge help, I'm sure it'll all make more sense when I'm all up in there!
  5. Aug 4, 2016 at 4:38 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Plus a reliable set of jack stands, obviously. No working on a vehicle with just the jack, boys and girls.
    vssman and ERMB like this.
  6. Aug 4, 2016 at 4:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Probably shouldn't admit to this, but I do things like tire rotations and I'd do brakes off the jack. Basically, as long as I'm not going under the truck. :anonymous:
    Fishinbum802 and BostonBilly like this.
  7. Aug 4, 2016 at 4:58 AM
    Noelie84
    Noel
    Wales, Maine
    I always slap the jack stands under there. Part of it's from the safety side of things, since I grew up working on cars in a not-completely-level dirt driveway. The other part of it's for the convenience of not having to worry about damaging parts or how I'm going to get the wheels back on if the jack does slip/collapse.
    mach1man001[OP] likes this.
  8. Aug 4, 2016 at 4:59 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Hm... When I bought the truck Acton Toyota told me all four brakes were just done. When I did my wheel bearing they definitely weren't done.... Now I need to pull it all apart to do the rear brakes again.
    For that spray coating stuff I guess I would need to strip off the rust that's on there now? Haha
  9. Aug 4, 2016 at 5:08 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Happy Birthday USCG
    mach1man001[OP] and Pugga like this.
  10. Aug 4, 2016 at 5:11 AM
    Noelie84
    Noel
    Wales, Maine
  11. Aug 4, 2016 at 5:39 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Agreed. When I was a kid I had a car roll off a jack (luckily I was not under there. Ever since then there is always something under there to protect me
    Clean off the rust, treat and paint before you put on that stuff
    Bruce988jl[QUOTED] likes this.
  12. Aug 4, 2016 at 5:47 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Good one, forgot that. Sliders ftw, takes 2 seconds to Jack the truck up with hi lift and pop the jack stands under.
  13. Aug 4, 2016 at 5:55 AM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Or if you have a bunch of 6x6 PT. I block my truck up on that. Trust it more than jack stands.
  14. Aug 4, 2016 at 5:58 AM
    Bruce988jl
    Southern NH
    6x6 ftw.
  15. Aug 4, 2016 at 6:07 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I need to invest in a better(read taller) floor jack and jack stands. Floor jack is.basically useless since it's only a little 2 ton one and it cant even touch my frame without a bunch of cribbing, only the lca or rear diff. Similar for the jack stands, capacity is fine (2ton) but at full extension the front tire is just barely off the ground at full droop (like 0.5"-1"). Having them at max extension is sketchy and.even then I have to use 2 2x4 with an old brake rotor on top for cribbing/so the jack stand doesn't sink into the asphalt.
  16. Aug 4, 2016 at 6:10 AM
    Pugga
    Massachusetts
    My jack does fine, but I do not like having jack stands fully extended. I have 2 - 2x12x12 pieces screwed together to use as a footing for the jack stands. Keeps them from sinking in and takes a few inches of height up so the jack stands can be more compressed. If I don't need to remove the wheels and I need to get under the truck For something else, I prefer to just put the front end on a few planks rather than have it on jack stands.
  17. Aug 4, 2016 at 6:21 AM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    All the above about jacks is very important. I got a little sloppy when I was swapping axles, had a high lift under the receiver hitch, floor jack to support old axle as I took it out, both rear tires under truck, but no jack stands yet o_O....I was overly excited that rusty bolts were actually coming apart that before I knew it I was on my last leaf spring bolt before she was all free......then I felt a weird grown, and then the whole rear of the truck just fell right over :eek: :censored: It went the opposite way from were I was, or I could/would have been crushed. Luckily besides scraping the gas tank with the axle being stuffed into it, a load of grease being blown out the shaft and a bunch of poo in my pants....rig was not injured:anonymous: ....beyond stupid, and very embarrassed
    Please use jack stands boys and girls
    ERMB likes this.
  18. Aug 4, 2016 at 6:24 AM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    Found a few things from my 09 when I was packing up.
    Cab Mount chop plates - free
    Black Sand Pearl touch up paint ( about two-thirds of a can give or take) free
    All Pro t-case cover $20. ( worked well for moderate Wheeling not so much for hard stuff I found that out the hard way)
  19. Aug 4, 2016 at 7:18 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I nearly gave my friend a heart attack Tuesday night..haha. He just picked up his new Jaguar F-Pace this weekend. I may or may not have shut off all my nanny traction shit and laid down a killer rooster tail in the back parking lot of the bar we play at and his new ride may or may not have been parked there.
  20. Aug 4, 2016 at 8:05 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
