New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Nov 15, 2012 at 4:42 AM
    #8721
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Meh i have found my drums never work they get full of mud and then get shreded and stop working in 500 miles. Iv redone my rear brakes 4 times in 2 years and they dont work right now either.
  2. Nov 15, 2012 at 4:57 AM
    #8722
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you end up with a tire like the KM2's, make sure they're siped. Otherwise they will not be good in the snow.
    I know you mentioned the Firestone A/T's were cheaper but I thought they were a pretty decent tire. It's one I'm considering when I need tires next because they offer them in the size I want.
  3. Nov 15, 2012 at 5:09 AM
    #8723
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    235's? lol
  4. Nov 15, 2012 at 5:10 AM
    #8724
    Pugga
    Massachusetts
    Probably 245s. 235s will put me into an E-rated tire. There are some that are rated lower but with a tire that skinny and tall, I'd think you'd want the stiffer sidewall anyways.
  5. Nov 15, 2012 at 5:11 AM
    #8725
    white91formula
    white91formula Well-Known Member
    Boston, MA
    05 6speed TRD OR
    Got the sled in a million pieces right now, needs some attention but it should rip once im done with it
  6. Nov 15, 2012 at 5:12 AM
    #8726
    650H1
    Michael
    VA
    I'd at least get a 265/75 especially since you're lifted
  7. Nov 15, 2012 at 5:14 AM
    #8727
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    When I get some big boy FJ wheels to put them on
  8. Nov 15, 2012 at 5:14 AM
    #8728
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    The one thing I will say is be sure to consider your "actual driving conditions" do you spend more time on road or off road. The reason being, aggressive tires can be very loud and have the tendency to pick up stones and cause vibrations. My opinion is to try and pick a reasonable tire that will serve you best in your real world conditions.
  9. Nov 15, 2012 at 5:25 AM
    #8729
    Pugga
    Massachusetts
    They'll be just as tall, just not as wide (235's would be taller). I'll actually do better in the snow, still get good mileage out of it and, because the height is the same, off road performance shouldn't really be affected for any trails I'll do in the near future. I think it'll look alright. Worst case, I'll shop for a set of wheels like Rob's so they stick out a little further.
  10. Nov 15, 2012 at 5:54 AM
    #8730
    emelianenkov
    Alex
    NORTH POLE
    Such a difference with the new front rotors! No more pulling to the left, no more massive pulsation, my mileage is up and I can coast now.... Pretty sure I had a frozen ebrake, and me breaking the ebrake fixed it.
    I still have damaged rear rotors though :(
  11. Nov 15, 2012 at 5:56 AM
    #8731
    Pugga
    Massachusetts
    Why won't they come off, are they just rusted to the hub?
  12. Nov 15, 2012 at 6:11 AM
    #8732
    emelianenkov
    Alex
    NORTH POLE
    No, it would wiggle and I could get the center of the rotor flush with the end of the lug post thingies by using bolts, but I couldn't remove the tension from the ebrake and tried using bolts to push the rotor up multiple times. No idea if its rusted or what have you, but it sucks! Two pieces fell out on my last attempt. I said fuck it and did the left front (this was at 10pm. I was cold, pissed, and frustrated)
  13. Nov 15, 2012 at 6:17 AM
    #8733
    Pugga
    Massachusetts
    Oooh... sounds like fun. If the rotor is coming off the hub then at least the rotor rusting to your hub isn't the issue. When that happens, it can be a biotch to get the rotors off. Good luck destroying your e-brake! Hopefully it pops off next time you get the wrench to it. When you have the jack bolts pulling the rotor away from the hub, I'd try to stick a straw behind the rotor and drown it with brake clean (you can use PB Blaster but you'll have to clean everything out really really well with Brakleen since you don't want that crap on your brakes).
  14. Nov 15, 2012 at 6:20 AM
    #8734
    emelianenkov
    Alex
    NORTH POLE
    Good call. I was gonna do that but then lost interest and wanted to just drop the tools and go inside. I was rather unhappy haha
  15. Nov 15, 2012 at 6:22 AM
    #8735
    Pugga
    Massachusetts
    I feel your pain. I was breaking down the old grille guard and swapping my wheels and tires at 9:00 last night, it was freaking cold to be working outside. That grille guard is a PITA to get apart when it's not anchored to the truck!
  16. Nov 15, 2012 at 6:34 AM
    #8736
    emelianenkov
    Alex
    NORTH POLE
    Lol I can't wait to take a sawzall to my damn brush guard!!!
    I need a light bar or a steel bumper, cause that Westin brush guard has got to go
  17. Nov 15, 2012 at 6:53 AM
    #8737
    BostonBilly
    Easton
    Stupid question but Did you back off the e-brake so as to clear the drum
  18. Nov 15, 2012 at 6:56 AM
    #8738
    BostonBilly
    Easton
    I just came back from the range this new toy is going to be $$$$ to shoot cause it is one of the easiest, most enjoyable of all my guns to shoot
  19. Nov 15, 2012 at 6:57 AM
    #8739
    Pugga
    Massachusetts
    :jellydance:
    I can't get any new toys for a while... :(
  20. Nov 15, 2012 at 7:00 AM
    #8740
    BostonBilly
    Easton
    I told you I am willing to bring guys out. I just have to check club rules about how many guest one or two at a time
