New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Sep 23, 2016 at 8:11 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    I fly business class for anything over 12hrs total flight duration - that being said I've been on Luftansa, swiss air, delta, korean air, emirates and etihad. (might be missing some) and etihad/emirates business class was my favorite.
  2. Sep 23, 2016 at 8:12 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I went to China once for work, so I got business for that. Where I am now I won't have to travel again (hopefully).
  3. Sep 23, 2016 at 8:17 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    F150forum.com
  4. Sep 23, 2016 at 8:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    There are a few TW members on there that I came across. I have the same user name over there also. I think the difference with the F150 forum is, a lot of people bought their F150 as a plain work truck and only log on to research something or if they have an issue. The ones modifying their trucks, most of them are Raptor-driving flat brimmers, the rest are pretty cool. Lots of knowledge there but definitely a different atmosphere. I use it primarily for the B/S/T section and research before cutting into wires or if I think something is up with the Ferd.
  5. Sep 23, 2016 at 8:26 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Ya regional planes are junk too. I generally take the commuter jet to DCA or CLT and then its 12 seat prop plane from there. Thank god for bose headphones too, cause the prop planes are like riding in a tin can
  6. Sep 23, 2016 at 8:33 AM
    Noelie84
    Noel
    Wales, Maine
    I have definitely noticed that about the Raptors, and they've got their own forum anyway so even those threads are fairly slow-moving.
    Speaking of wiring mods, though, I ordered up the factory bed light kit and I'm going to be installing that, but for some reason I've seen claims online saying that the dealership will have to activate them in the computer? Seems like BS; from what I can tell they run off of the same harness as the cab-mounted bed light, so once they're plugged in they should have current. :notsure:
    I ended up just installing a set of the Sylvania Silver Star headlights, too. Much better. Had the dealership check the alignment on the headlights, too, and they were pointing low. Said it's not that uncommon from the factory, for some reason. Maybe they're setting the alignment while they're still on the assembly line rather than when the weight of the truck is resting on the suspension.
  7. Sep 23, 2016 at 9:13 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    I helped @Unchained 5150 wire his bed lights up. They tap into your existing cab light circuit and activate/dim with the rest of the interior lights. Nothing needs to be activated.
    Unchained 5150 likes this.
  8. Sep 23, 2016 at 9:17 AM
    Noelie84
    Noel
    Wales, Maine
    About what I figured; didn't make sense that they wouldn't work if you plugged them in and gave them current, lol.
  9. Sep 23, 2016 at 9:19 AM
    Pugga
    Massachusetts
    You need to be careful with some of the electronics on the Ford, some of them go back to the ECU so it might not work like you'd want it to if you just tap into something. That being said, I don't think you'd have an issue with bed lights.
    I'd guess that's all you have to do. I bought new tow mirrors that had puddle lights, just plugged them in and they worked, apparently I was pre-wired for them which was pretty cool.
  10. Sep 23, 2016 at 9:21 AM
    BadDNA
    Eammon
    Cabot, VT
    Now, having said that, Rick's truck is a secon gen. Things MAY be different. I'm following your logic and agree 100% though.
  11. Sep 23, 2016 at 9:21 AM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    I haven't had good luck with the Silver star bulbs. One would blow every year, so I stopped buying them. I think there was actually a class action lawsuit against Sylvania because of their Silverstars.
  12. Sep 23, 2016 at 9:25 AM
    Noelie84
    Noel
    Wales, Maine
    I ran them in the Tacoma; first set burned out inside of 6 months and I warranteed them out, and the replacement set was still in there when I traded it. :notsure:
    Obviously they don't last as long because they burn hotter, but I'm hoping they've worked out the bugs (because changing them on this thing's kind of a pain).
    If not, I'll go back to the GE Nighthawks. Those always lasted really well for me, even if they weren't quite as bright as the Silver Stars.
  13. Sep 23, 2016 at 9:28 AM
    Noelie84
    Noel
    Wales, Maine
    Honestly I think that most of the new trucks are prewired for everything. I've got remote start if I ever want to pick up the key fob and have the dealership activate it (I had them check when they were adjusting my headlights).
    Makes sense, I suppose. It's probably cheaper to buy ONE wiring harness design and use it in all of the trucks rather than a separate harness for every trim level.
  14. Sep 23, 2016 at 12:41 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Everyone sleeping?
  15. Sep 23, 2016 at 12:44 PM
    Edgeplay
    Edgeplay Well-Known Member
    Sean
    Connecticut
    13 DCLB MGM
    -Leather Seats -Weathertechs -LED map and dome -6K HID head lights, -Glove and Center Consol organizer -30" LED bar in lower valence
    Just a little afternoon nap.
  16. Sep 23, 2016 at 12:48 PM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    I was able to sneak off to the gym for a nice 3 mile run mid-day.
  17. Sep 23, 2016 at 12:51 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Can't say I don't blame you
    Um, why?
  18. Sep 23, 2016 at 12:55 PM
    morri89
    Brendan
    Hopedale MA
    2020 Rubicon
    Been sitting at my desk too damn long today. Plus, I stayed up later than normal watching the Pats last night so I decided to take an extra hr of sleep this morning and skip the gym in hopes of going at some point this afternoon
  19. Sep 23, 2016 at 12:57 PM
    bornruffian
    bornruffian Well-Known Member
    Kyle
    Halifax MA
    2011 Silver 4 cyl.
    Fog Light, LED Bar in the lower valence, fumoto oil drain plug replacement, backrack
    Looking into getting new tires, I have the dunlops that came on the truck when I bought it and I am looking to upgrade a bit. I was wondering what you guys/gals have had good/bad experiences with. Im looking to keep a similar style to the dunlops.
    Edit: looking for all seasons that are decent in snow
    (245/75/16)
  20. Sep 23, 2016 at 1:00 PM
    Pugga
    Massachusetts
    I like my Michelins, can't go wrong with either the Michelin MS2 or AT2. Pretty much anything you get will be better than the stock Dunlops.
    Sloth and bornruffian[QUOTED] like this.
