New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Nov 18, 2016 at 12:53 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've heard mixed reviews on using a sock for snow / salt. The problem is, they're not actually water-tight so anything that does work it's way in there is now trapped in there in a nice, warm climate to eat away at your coilovers. So, unless you remove it frequently for cleaning, it's sort of counter-productive.
    Boston10Taco[QUOTED] likes this.
  2. Nov 18, 2016 at 12:54 PM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    I just hit the car was a lot in the winter.
  3. Nov 18, 2016 at 1:29 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    From what I read, he sells out instantly. I ended up getting mine from ebay because I didn't want to wait.
  4. Nov 18, 2016 at 2:47 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Honestly.. There is no real way to protect your coilovers in this region. I have had coilovers on three of my past cars and on my current evo. I have tried the socks, wax and fluid film type material to even plastidipping them. The problem isn't the housing it's the threaded section on the coilover that you should be concerned about. Rocks/salt/sand that get in there makes it a nightmare to adjust in the future. I actually load my evo up with a dry lubricant then a handful of thick grease around the threaded parts every fall and hand cleaned it all off in the spring time. Then I just stopped driving it in the winter.
    Boston10Taco likes this.
  5. Nov 18, 2016 at 3:39 PM
    Pugga
    Massachusetts
    Have you tried heavily waxing the threads, or cosmoline? I would think a thick coat of wax would do the trick.
  6. Nov 18, 2016 at 3:41 PM
    Bruce988jl
    Southern NH
    I used a rim wax that I used to use when I did detailing.
  7. Nov 18, 2016 at 5:05 PM
    Pugga
    Massachusetts
    No, screw that crap, I mean like ski wax. A big ole block of wax rubbed against the threads so you end up with like 1/8-1/4" build up.
  8. Nov 18, 2016 at 5:13 PM
    Bruce988jl
    Southern NH
    Never thought about that, I would imagine it would be a bitch to clean up when you go to adjust it unless you melt it off... But then again if you just set it and forget it I guess this would be a good solution.
  9. Nov 18, 2016 at 6:08 PM
    Pugga
    Massachusetts
    Exactly, you just melt if off or take a pressure washer to it. Ski wax would melt off with just a hair drier, it has a relatively low melting point. It's also soft, so I'm sure you could just spin the seat right through it, it wouldn't gunk up the threads.
  10. Nov 18, 2016 at 6:24 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Duct Tape the threads. A friend used to do that with some good luck.
  11. Nov 18, 2016 at 6:41 PM
    Bruce988jl
    Southern NH
    Anyone here with an ARB Compressor? Is it really worth the $200+?
  12. Nov 18, 2016 at 7:29 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Denis @64Wildcat and Scott @ERMB both have them
    ERMB likes this.
  13. Nov 18, 2016 at 7:38 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Can always take a harbor freight special and port it.
  14. Nov 18, 2016 at 8:22 PM
    D34thMoogle
    D34thMoogle Well-Known Member
    Sean
    Concord, NH
    '15 White TRD-Offroad
    Toytec BOSS 3" lift DBCustomz Grille Prinsu Designs roof-rack Hood/Bed lights
    Hey all, my wife and I are driving up to NH tomorrow (and Sunday) from Dallas. We are aiming to avoid NYC by 84 to Hartford then getting on 91. Anyone aware of any major construction or anything up that way that would make that un-advisable?
  15. Nov 18, 2016 at 8:52 PM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    I'd recommend 287 around ny
    colin_j1, Pugga and Sloth like this.
  16. Nov 18, 2016 at 11:31 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    What about some Sex Wax?
  17. Nov 19, 2016 at 4:13 AM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Its a night and day difference. That's exactly the upgrade I went from. The HF is great for bike tires and small things, but literally took ten minutes to add 3 lbs of pressure to my truck tire. The ARB functions as advertised, 10lbs to 35 lbs in about 2 minutes.
    I do think there are other brands bout there that will do the job for less, Viair, the red one that Cam has, and there's another brand called volt air. Those all hook up to the battery.
    I liked the idea of having it mounted and wanted a little project to work on.:D
  18. Nov 19, 2016 at 4:27 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Not sure where you'll be picking up 84 but if you are getting on it in PA from I380, there's some construction in the Poconos which moves along ok and then in Waterbury CT - typically a 10-20 min delay there. If you coming up from Jersey area, I'd take 287 as 'RR2' noted then to I684 to I84. You'll still hit Waterbury CT construction area.
  19. Nov 19, 2016 at 4:33 AM
    Bruce988jl
    Southern NH
    Thanks for the feedback which arb did you go with the dualie or single? I'm on the fence about the arb pump or one of the viair 450 with automatic shutoff.
  20. Nov 19, 2016 at 4:49 AM
    Pugga
    Massachusetts
    Depending on how you're coming up, you could always jump on 88 out of PA, thru Central NY and then hop on 90. You'd avoid anything even resembling NYC.
