New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Dec 23, 2016 at 11:29 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    And deal you in on the commission
    Cativelense[QUOTED] likes this.
  2. Dec 23, 2016 at 11:29 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Exactly.
  3. Dec 23, 2016 at 11:50 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    :rofl::rofl::rofl:
    I don't get any of that pie.
    But, typically a Rep will treat with a nice lunch or a bottle of booze
  4. Dec 23, 2016 at 12:39 PM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    Feeler: leather interior for your taco $1k installed
    Last winter I installed my OEM leather. I'm looking to see if anyone else is interested in getting this done. Time and materials would cost $1k. Price is for access our double cab.
    Let me know if you are interested and I'll get you a lead time on materials/ color options. You would drop off your truck for the weekend. I would remove each seat and bring it into my heated basement to do the work. This requires me to fully remove original fabric and hog ring the new material on. Your original material will be returned to you.
    This would give me a fun project and you leather interior atless than half the cost from Toyota
  5. Dec 23, 2016 at 3:39 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    That's a good deal. Would you put the heat at the same time? I could wire it in
  6. Dec 23, 2016 at 4:33 PM
    surfandturf
    CT
    2014 TRD DCLB
    Yes, if you supply the heating kit I'll fit it in
  7. Dec 23, 2016 at 4:36 PM
    SMSmithy
    SMSmithy Liberty Or Death
    Sam
    New Hampshire
    2016 TRD Off Road
    Black Painted Grill
    New to New England, moved to New Hampshire in March of this year. VA had a pretty good Tacoma community, I hoping NE will to! IMG_0738-1.jpg
  8. Dec 23, 2016 at 4:40 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Welcome. Where in NH did you move to?
  9. Dec 23, 2016 at 4:41 PM
    SMSmithy
    Sam
    New Hampshire
    2016 TRD Off Road
    Black Painted Grill
    Newmarket
  10. Dec 23, 2016 at 5:27 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Looks good. Got the same model/grille combo.
  11. Dec 23, 2016 at 8:20 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Welcome to New England!
    Got the fuse panel installed today and carefully and stressfully hooked it up to the new battery. Surprisingly everything worked mint and I didn't have any shorts... Except for accidentally grounding a positive terminal on the Pelfreybilt battery cage... That sucked and semi welded a socket rack holder to it for a minute. If anyone needs help or tips I can assist, I drew up a few wiring diagrams for the setup I made. I need to figure out why my cb gets static when I turn on my ditch lights, might need a high frequency filter on it or something...
    Also anyone know of any rocker switches like the ottrattw switches that fit in the driverside small blank spots?
  12. Dec 23, 2016 at 9:23 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Cool
    Welcome
    Air on board makes the smaller switches that fit under the center console. Is that the area you were talking about? Also is your CB set up to go to ignition switched along with the rest of your setup? I would wire it with no switch and always hot, just fused off of the battery. Least chance of getting any interference.
  13. Dec 23, 2016 at 9:57 PM
    Bruce988jl
    Southern NH
    My cb is wired direct to the battery... :/
    I'll check out AOB!
  14. Dec 23, 2016 at 10:05 PM
    Bruce988jl
    Southern NH
    Scratch AOB... Their switch descriptions/pictures look horrible. Guess I'll mill out the space to fit the ottrattw switches.
  15. Dec 24, 2016 at 5:31 AM
    SMSmithy
    Sam
    New Hampshire
    2016 TRD Off Road
    Black Painted Grill
    I ordered Switches from CH4x4.com they have rocker and Factory toyota switches with special / custom engravings. They have the large and small push button switches too. You can also choose the back lighting color. white, amber, blue, green, and red.
    Screen Shot 2016-12-24 at 8.30.00 AM.jpg Screen Shot 2016-12-24 at 8.29.09 AM.jpg
    Bruce988jl[QUOTED] likes this.
  16. Dec 24, 2016 at 5:37 AM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    Hey screw you that's what I have
  17. Dec 24, 2016 at 6:32 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I have an ARB "tray lights" switch for my bed lights. You can tell it isn't OEM, but it is close enough so I'm happy.:notsure:
    mach1man001[OP] likes this.
  18. Dec 24, 2016 at 6:48 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    That's about as close of a match as your gonna find
    Bruce988jl likes this.
  19. Dec 24, 2016 at 6:50 AM
    Cativelense
    Nuno
    CT
    Greetings everyone from wild and wonderful WV.
    Down in Teays Valley, Hurricane WV.
    Merry Christmas eve everyone!
    Pardon my stupidity... been looking around the site and can't seem to find it, and I think I've seen this. Isn't there someone here that makes switches for light bars, etc?
  20. Dec 24, 2016 at 6:52 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Here you go. If you don't see what you like these guys will make the switches say whatever you want
    https://www.otrattw.net/
    ABA180 and Cativelense[QUOTED] like this.
