New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 5, 2017 at 5:04 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I passed a few Jeeps with headlights that look like yours and the light was always in the upper part. Most headlights have the light in the upper half because that's the side that reflects light toward the ground. You sure you have them up side down and not just poorly adjusted?
    Me too, just curious what other people use. I've had great luck with Startron for years now.
  2. Jan 5, 2017 at 5:48 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I run ethanol free in my small engines. Can go over the border to NY and get it at Stewart's. Fortunately, NY is only 15 minutes away. Truck likes ethanol free too.
    I think MA must have some law against using it in automotive applications because you can't get it here other than at a marina or a lawn equipment dealer.
  3. Jan 5, 2017 at 6:21 PM
    gugman
    gugman analog
    bob
    Vermont
    I use Pri-G fuel stabilizer for both my small engines and vehicles .
  4. Jan 5, 2017 at 6:59 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I use the Husqvarna XP in my backpack blower / string trimmer and it definitely runs stronger. I lost a bit of juice on the blower using stabilized older two stroke fuel but it seems to be coming back a bit with the XP stuff going through it.
  5. Jan 5, 2017 at 7:17 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Google it but there are ethanol free stations in MA..may not be near you though
  6. Jan 5, 2017 at 10:16 PM
    cjrodriguez31
    cjrodriguez31 Well-Known Member
    Corey
    RI
    04’ Ram 2500, 21’ Mach E GT
    As soon as I got home tonight from work I took them apart and flipped them around but they wouldn't fit properly with the notches. So yes, turns out I put them in the right way, I just needed to angle them down. With a torx15 and a couple of turns later they are properly pointed down.
    I liked how the light looked though when i had my high beams on because they shinned in the air. LED light bar is next on the list of to gets:
  7. Jan 6, 2017 at 3:05 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    @cjrodriguez31 happen to have a link to the lights? I could use an upgrade on the lighting for my 63 Falcon. Still has sealed beams and those small yellow spots aren't cutting it for my eyes... I assume they fit in a standard 7" round???
    Edit: BTW, morning all. Just a coating of snow here...
  8. Jan 6, 2017 at 3:36 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning. Too dark out to see how much snow we got, but can't be much/bad since there isn't a school delay. Also, been up since about 2:30 because of the kids. Fun times ahead for the rest of the day. I see short temper (more than usual since I'm already short tempered as it is) and frustration in my day today.
  9. Jan 6, 2017 at 3:48 AM
    Pugga
    Massachusetts
    Damn, expensive gas! NY is usually $0.20/gal more than MA anyways, is ethanol free even more?
    I have a 30" combo light bar I'd part with if you're interested. Shoot me a PM if you want some details on it. Used but in good shape.
    Check out The Retrofit Source, they have JW Speaker 7" round lights. Pricey but really good lights.
  10. Jan 6, 2017 at 4:42 AM
    js312
    Joe
    New England
    I do see a couple normal stations with ethanol free. All 2-3 hours away. Anything close to here is just an airport/tractor dealer. There are a total of 20 ethanol free stations in MA, compared to 72 in VT and 721 in NY.
    Seems like there must be something discouraging more.
    Stewart's prices Ethanol-free 91 about the same as what 10% ethanol 91 or 93 would be. I'd say it averages 25 cents more than here. I only fill the truck with it if I'm going out there to fill a can or two for the small engines.
    The only place I will not get gas is New Jersey. I will deliberately stop in Pennsylvania or New York if I think there's any chance at all of running low in NJ. I avoid full service stations here and I think the idea of it being a state law there is ridiculous.
  11. Jan 6, 2017 at 5:05 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Morning all!
    That is one niggle that I have with the '69, is its speed-sensitive headlights. The faster I go, the faster the alternator spins, so the brighter the lights are. But at low rpms, like cruising through downtown or at a stoplight, they are weak.
  12. Jan 6, 2017 at 5:07 AM
    Pugga
    Massachusetts
    Not bad. Plus, you can grab a box of those chocolate chip cookies while you're there :hungry:
    And add that to the list of things to hate about NJ.
  13. Jan 6, 2017 at 5:23 AM
    js312
    Joe
    New England
    I really like their hamburgers. I can't explain why since they're probably made from the cheapest buns and ground beef they can find. Maybe it's because whenever I buy one it's because I'm nearly starving.
  14. Jan 6, 2017 at 5:24 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    1st off where are the stations in Mass with ethanol free gas? 2nd, I deliberately stop for gas every time I'm in NJ, have you seen the gas prices there? They are cheap
  15. Jan 6, 2017 at 5:30 AM
    js312
    Joe
    New England
    http://pure-gas.org/index.jsp?stateprov=MA
    There's that, but I hate people touching my truck for any reason. Maybe paranoia.
    And I hate a state that tells me I can't do something myself that I've done as long as I've been driving.
  16. Jan 6, 2017 at 5:33 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Yeah, I assumed there was a risk of that. But it would be constant off and on, I tow like 3 times a week minimum. Sometimes twice that.
    That's what I use in the sled and the boat. Every tank actually. Corn gas sucks.
  17. Jan 6, 2017 at 5:42 AM
    gugman
    gugman analog
    bob
    Vermont
    Last time I got fuel in NJ. I asked for regular gave me the bill and it was much more then I had figured out in my head. looked and he had but hi test in. after a discussion the manager came over asked what happened. told him he paid me the difference with out any hesitation. I think they do it a lot just by the way they where acting.
  18. Jan 6, 2017 at 5:45 AM
    Noelie84
    Noel
    Wales, Maine
    Plus, pretty much every Tacoma I've seen get rear-ended has been totaled anyway. So I'd say that taking the hitch ball in & out every time isn't really going to improve your odds. :notsure:
  19. Jan 6, 2017 at 6:01 AM
    Pugga
    Massachusetts
    I miss having Stewarts near by. I grew up in upstate NY, that place is like a staple. Do they still sell Damn Good Beef Jerky? If so, pick up a bag, it's awesome stuff. It's made one town over from where I grew up.
    js beat me to it, none really close to us.
    Agreed, I hate full service stations for that reason alone. I don't like people touching my truck.
    You're almost better off with a ball mount on if you get rear ended so it does actually bend the frame. I would rather have insurance total the vehicle than have 'minor' frame damage and have it pulled. Something about trying to straighten a truck frame just doesn't sit well with me.
  20. Jan 6, 2017 at 6:14 AM
    Noelie84
    Noel
    Wales, Maine
    This is true. Seems like straightened frames are almost never actually 'straight'
    So, leaving the hitch in DOES improve your odds!
