New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Mar 30, 2017 at 4:37 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    How does one "run out of brakes"? Granted it is a GM product...
    emelianenkov likes this.
  2. Mar 30, 2017 at 4:45 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    4 hours later... Bushing installed.
    Had to top off the fluids I lost a lot of fluid.
    Tried to drain it but whoever did the service before me stripped the torx bit on the drain plug... Not quite sure what to do there.
    mach1man001[OP] and jpereira2 like this.
  3. Mar 30, 2017 at 5:07 PM
    BananaPeelOut
    BananaPeelOut Well-Known Member
    Ben
    NH
    2005 silver access cab TRD Off-Road
    Kenwood Headunit, CB radio setup, wind deflectors.
    Is this the ecgs bushing everyone talks about?
  4. Mar 30, 2017 at 5:19 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Order a new plug. If it's real bad Get a disposable Allen key socket and some JB weld. Jb weld that key in wait awhile then you should be able to back it out.
  5. Mar 30, 2017 at 5:21 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If I recall, the drain plug isn't a torx bit. If it truly is stripped, weld a nut on the plug.
    MY50cal likes this.
  6. Mar 30, 2017 at 5:24 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Fucked up dude. Going through some shit at my job as well. Getting shit for trying to what I thought was me doing a halfway decent job and explaining/pointing things out to people so they could do their job in order for me to do mine. Apparently some people took it as disrespectful and mentioned it to our CEO at a recent sales summit our company had. My boss told me today in a little review type meeting today. We'll, time to look for a new job. Don't want to be at a company where people get offended by you trying to help, and constantly having to walk on eggshells.
    Craziness. Glad you're OK from the accident. And hope your surgery goes well.
  7. Mar 30, 2017 at 5:47 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    You're right . It's a Allen.
  8. Mar 30, 2017 at 6:40 PM
    Bruce988jl
    Southern NH
    Hm... I tried all the Allen's we had at the shop and they were super loose. So it might have been because it was stripped. I found a torx that fit but the moment I applied pressure to it the metal started to give. Might weld an Allen bit in there with a 3/8ths attachment hanging off it and just use it like that. I can't stand these stupid Allen and Torx bits...
  9. Mar 30, 2017 at 6:45 PM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    Torx and hammer hehe
  10. Mar 30, 2017 at 6:46 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I've had to do this on my former truck...
  11. Mar 30, 2017 at 7:05 PM
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    My 1st thought exactly!
    DoubleRGirl[QUOTED] likes this.
  12. Mar 30, 2017 at 9:12 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Don't even get me started about my job...
    @Bruce988jl I had that happen and I was the one who had changed it before but luckily for me it happened at a friends shop. We ended up using a air chisel to put a slit in it then used the air chisel in the line to rotate it loose. I then tightened it back up ordered a new one and changed the fluid once I had the new one in hand
  13. Mar 30, 2017 at 9:16 PM
    Bruce988jl
    Southern NH
    Yea for now I'm going to order a replacement and I'll figure it out from there later. Sucks... I hate mixing oils.
  14. Mar 31, 2017 at 4:07 AM
    Pugga
    Massachusetts
    @Bruce988jl 's example is a prime case of why you ALWAYS remove the fill plug before you take the drain plug out, just in case some people didn't already know that.
    PixelPusher and 64Wildcat like this.
  15. Mar 31, 2017 at 4:11 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Happy Friday everyone!
  16. Mar 31, 2017 at 4:12 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  17. Mar 31, 2017 at 4:21 AM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    Morning! thought this was cool!
  18. Mar 31, 2017 at 4:23 AM
    Pugga
    Massachusetts
    Mornin'
  19. Mar 31, 2017 at 4:25 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    :wave: Was supposed to have a half day today (would have been nice with the snow) but I don't want to leave my coworker by himself. Been fairly busy, and my service manager has been out all week moving.
  20. Mar 31, 2017 at 4:56 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Morning everybody! TGIFFF!!!
    We had a guy in an older Honda (I don't remember if it was a Civic or an Accord) come into the shop and complain that his brakes were vibrating when he stepped on the pedal, and that his car wasn't stopping well. Brake light and ABS lights were on and he said that it was nothing he paid any attention to because the brake light's been on since he bought the car (red flag #1) and that he'd pulled the ABS fuse a couple of years ago because they were pulsing every time he stepped on the brakes (red flag #2).
    So we pull his car into the shop, put it up on the lift, pull the front tires, and find out that he's got zero front pad left, nearly zero backing plate left, and that he's ground ALL THE WAY through the friction surface on the rotors. The reason he was getting vibrations is because he had chewed all of the way down to the cooling fins at the center of the rotors and they were catching what was left of the backing plates on his pads. :eek:
    Guy's lucky he hadn't killed himself or somebody else. When we asked him he said it'd been doing it for a couple of weeks. :facepalm:
    He had definitely run out of brakes, lol.
    Edit- Not the exact brakes on his car, but they looked just like this. (except with 4 lug studs)
    Boston10Taco likes this.
