New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Apr 6, 2017 at 10:24 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Unless you're using sugar water for your transmission fluid, 175 isn't even up to operating temperature, let alone causing damage. Most transmission fluids have an optimal operating temp of around 190-195 degrees. The fluid itself doesn't start getting 'damaged' until you get above 220-ish, when it can start producing varnish.
    jpereira2[QUOTED] likes this.
  2. Apr 6, 2017 at 10:50 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Aircraft/Naval?
  3. Apr 6, 2017 at 11:07 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Hmm, I may want to check the coding for my Ultragauge then because it doesn't take long to get it from 160 to 130. Minute or so.
    Well that's good, might be all set then with the factory setup. There is a steep hill climb when i go to bring it home from the dealer so ill definitely be watching the temp there. Hopefully i don't get stuck at the light right at the top of that hill.
  4. Apr 6, 2017 at 12:45 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If the temperature is registering on the line from the transmission to the cooler, it will vary quite a bit. It's still useful, you just can't freak out when you start seeing immediate drastic swings in the temperature readings because it's not really telling you what's going on inside the transmission.
    Also, I partially agree with Noel. A lot of vehicles run their transmissions pretty cool, in the 170 range. Ford now runs theirs to more closely match the engine operating temperature, around 200. Most ATF isn't really in harm's way until you start seeing 230 and up though.
  5. Apr 6, 2017 at 12:46 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Army - Navy
    Noel is absolutely right. I didn't know the numbers so I looked them up. ATF doesn't start having a problem to the 220-240 range
  6. Apr 6, 2017 at 12:56 PM
    Noelie84
    Noel
    Wales, Maine
    Ford (and other manufacturers) is (are) running theirs warmer now because that's where transmission fluid is the most efficient. At the cooler temps that everybody used to run them at the fluid is thicker and costing MPG's. Because of the new push for higher mileage manufacturers are letting them run at the optimal point for good fuel economy without compromising longevity. They've added larger coolers to keep them from overheating, but control the flow through the coolers so that the transmission can actually warm up first.
    :thumbsup:
    As long as it's fresh. Old fluid is a crapshoot, obviously, which is why you should flush every 60-70k even if you're just using it as a DD & not working it hard.
    jpereira2 likes this.
  7. Apr 6, 2017 at 2:31 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Which is clearly the case in this example!!!
    emelianenkov likes this.
  8. Apr 6, 2017 at 2:33 PM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    are you talking about me???
  9. Apr 6, 2017 at 2:41 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    YUP!
    DoubleRGirl[QUOTED] likes this.
  10. Apr 6, 2017 at 3:33 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Whew!!! I thought it might have been me as I have a manual transmission too...
  11. Apr 6, 2017 at 3:41 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Sounds like a thunderstorm is rolling in...
  12. Apr 6, 2017 at 3:44 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Yup. You guys will be getting t-storms soon. There was pea sized hail down here just a little while ago.
  13. Apr 6, 2017 at 3:49 PM
    DoubleRGirl
    Rebecca
    Rhode Island
    wait what? hail???? do i need to cover my car?????
  14. Apr 6, 2017 at 3:50 PM
    replica9000
    2019 T4R ORP
    No hail here.
  15. Apr 6, 2017 at 3:51 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Storms, here, were moving mostly north so the hail that we had is going up toward MA.
  16. Apr 6, 2017 at 4:07 PM
    Pugga
    Massachusetts
    Nope, you actually know how to drive a manual. I'm referring to people who like to keep one foot on the clutch, you know, to really warm up the clutch to a good, toasty temperature.
    Yes, but was referring to different loose screws in this case :D
  17. Apr 6, 2017 at 4:08 PM
    DoubleRGirl
    Rebecca
    Rhode Island
    yer s'posed to smell the clutch to know if it's werking
    emelianenkov, Spare Parts and vssman like this.
  18. Apr 6, 2017 at 4:14 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Last 2 weeks haven't been able to shake this cold in my chest.
    DoubleRGirl likes this.
  19. Apr 6, 2017 at 4:16 PM
    DoubleRGirl
    Rebecca
    Rhode Island
    same. was sick a couple weeks ago. feel fine now but i still have lots of shit i'm coughing up
    ERMB[QUOTED] likes this.
  20. Apr 6, 2017 at 4:18 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Have you been taking anything?
