New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 20, 2017 at 1:26 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Monson just got back.
    tacobell007[QUOTED] likes this.
  2. May 20, 2017 at 1:31 PM
    jpereira2
    Massachusetts
    @Bruce988jl drove by a place called kaizen.. . .sushi and bar
    Bruce988jl likes this.
  3. May 20, 2017 at 3:35 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Plastidip it some silly loud color.
    I decided got the fuel line fixed in my lawn tractor and went to mow my yard. I don't know if I have dusty soil or if the design of the bagger on the tractor creates a weird vacuum, but long story short, it's now out front of my house with a $600 price tag on it (mega-optimistic). Sure, my push mower takes twice as long, but the frustration level is 1/4.
    When I do one pass on my yard and I can't read the safety instructions at my feet because of the dust/dirt kicked up, I'm done. My Mom's newer tractor with the mulching kit doesn't do that.
  4. May 20, 2017 at 4:16 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Late to catching up on here...
    I picked up a set of LCA's from @mach1man001 so I stripped them down last night and sprayed the inside with mavcoat to let it dry overnight. Today or this weekend the holes are going to be welded shut and around the external plate as well - then sprayed with epoxy based paint and then rustoleum over all of it. I didn't want to use the bottle-jack method of pressing the bushings out of the lca's so I used a bushing press tool in reverse to extend instead of compress. Toss a little heat on there while the bushing is
    Today I fixed my CB Radio issue - looks like the uniden 520xl has poor filtering for inline noise as I swapped in the unit Rebecca gave me and no more noise on the system when I turn on the exterior LED pods/bar. I even re-ran the whole harness with shielded wire with the shield grounded... on both ends...
    Also installed the birddawg mirror riser and techdeck heavy duty panel. The plan is to ditch the cell phone holder I have and switch to a RAM constructed setup.
  5. May 20, 2017 at 4:42 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Dusty yard is my guess. My front yard is bad like that. How old is it?
  6. May 20, 2017 at 4:59 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    20. I despise it tho.
  7. May 20, 2017 at 5:55 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I just did the opposite.
    I gave away my lawn tractor when I moved because a large part of my lawn is an enormous hill that isn't really mowable, or is at the bottom of the hill next to the river that you wouldn't get a riding mower down to anyway. A friend does landscaping on the side and he said he could use it for parts if I didn't want it. He came up after I moved in and was surprised I didn't want the tractor, said he hadn't done anything with it and would bring it back up if I changed my mind.
    I mowed it with a push mower once. That was enough. There's enough lawn that is mowable with a tractor where it saves a huge amount of time.
    Of course, my tractor is a franken-mower at this point. It's a Husqvarna, but the original Kawasaki engine failed and the hydrostatic transmission failed, so it's got a 19 HP Briggs V-Twin off an old Craftsman and it's on its second manual transmission.
  8. May 20, 2017 at 6:44 PM
    ABA180
    East Bridgewater MA
    My Murray is close to 20. My push mower even when brand new was very dusty whether I bagged or mulched so it is just the yard.
  9. May 20, 2017 at 11:49 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    What's the first part of the FJ getting some love?
  10. May 20, 2017 at 11:49 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    I like the plasti dip idea
  11. May 21, 2017 at 3:20 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Current plan is to put it on jack stands. Remove suspension from all 4 corners. At the same time I will be cutting out my frozen alignment bolts.
    I'll be dropping the trans to finally send the original 175k clutch to retirement. To drop the tranny, I've gotta pull of and straighten my skids.
    While my front skids are off, I'm going to fabricate frame braces for the stress and abuse of heavy winching. Straighten out my skids. I've got a lot to do
    smcgill, uurx and tacobell007 like this.
  12. May 21, 2017 at 7:59 AM
    Bruce988jl
    Southern NH
    Step22 gear released some coilover boots that velcro on. I wonder how well they hold up.... or if they just trap moisture in there....
    emelianenkov and jpereira2 like this.
  13. May 21, 2017 at 8:30 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Got the mower going yesterday, was just missing an axle key on one of the wheels. I would have thought that at least the one wheel that had the axle key would have moved.
    Lawn mowed, then fire at a buddies house.
    Annual burning of the Christmas tree.
    Pugga and tacobell007 like this.
  14. May 21, 2017 at 8:32 AM
    Edgeplay
    Edgeplay Well-Known Member
    Sean
    Connecticut
    13 DCLB MGM
    -Leather Seats -Weathertechs -LED map and dome -6K HID head lights, -Glove and Center Consol organizer -30" LED bar in lower valence
    Love the hose, case the fire gets out of hand.
    Spare Parts[QUOTED] likes this.
  15. May 21, 2017 at 8:35 AM
    Spare Parts
    Southern Maine
    Exactly. :rofl:
  16. May 21, 2017 at 8:50 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Wrap the coils in duct tape.
  17. May 21, 2017 at 8:51 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
  18. May 21, 2017 at 1:22 PM
    jpereira2
    Massachusetts
    Went to a pet adoption event this morning, and well we are adding to the family in a month or so
  19. May 21, 2017 at 1:28 PM
    Nicetacobro
    Nicetacobro Well-Known Member
    Adam
    Rhode Island
    2nd gen DCSB
    It's Taco time
    :worthless:
    DoubleRGirl and Spare Parts like this.
  20. May 21, 2017 at 1:55 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Mocked up some ditch lights using CBI mounts. I don't think I like them :( I feel like the truck is too stock to pull them off. My hope was to use the passenger side mount to house a 4' Firestik.
    [​IMG]IMG_1059 by Mike M, on Flickr
    [​IMG]IMG_1060 by Mike M, on Flickr
    [​IMG]IMG_1061 by Mike M, on Flickr
    Thoughts?
    Nicetacobro likes this.
