New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Dec 5, 2012 at 12:32 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Factory 5 Cobra kit
    2000 Jaguar XJ8
    2005 4Runner
    1953 Willys Wagon
    I miss the Jag. Tempurpedic seats with a 400 HP V8. Fun, big, long car
    I also miss the Cobra. Nothing like a big block V8 roadster
  2. Dec 5, 2012 at 12:54 PM
    eborgie
    eborgie No Yotas Here
    Erik
    Bellingham, MA
    2023 Bronco Sasquatch
    1992 Toyota Camry LE
    2000 Mitsubishi Eclipse GT
    2008 Toyota Tacoma TRD Sport
    1994 Honda Ngihthawk 750
    2006 Suzuki SV1000S
  3. Dec 5, 2012 at 1:40 PM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    75 chevy laguna 350ci
    93 grand am 3.8 v6
    01 dodge dakota quad cab 3.9 v6
    07 mazda3 5door 2.3 I4 5 speed
    10 tacoma
    I miss my mazda i had zero issues with that and i beat the shit out of it. i put the mazdaspeed short thorw shifter in it and it was a blast
  4. Dec 5, 2012 at 2:12 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Any of you guys use the no spring compressor method when changing out the front coilovers?
  5. Dec 5, 2012 at 2:15 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That method scares me. I bought my coils assembled but if I hadn't, I would be taking the old shocks and new shocks to a shop and have them do a quick swap using their machine. They should be able to do it quickly and cheaply.
  6. Dec 5, 2012 at 2:19 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Not reccomended there is alot of stored energy in those springs and then there is the issue of putting them back together
  7. Dec 5, 2012 at 2:20 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Never done it that way but I have a spring compresser if you feel like borrowing it drive up to mass :)
  8. Dec 5, 2012 at 2:21 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    That was my plan at first. Just wondering if anyone had any experience with that method. Someone told me its easy, and it looks like he knows what he is doing. Probably above my skill level to try it this way, but there is a youtube video of someone doing it and it looks simple.
  9. Dec 5, 2012 at 2:23 PM
    BostonBilly
    Easton
    This is the way to go, pull them out drive up in a friends car with the old and new swap them at John and done nice and safe
  10. Dec 5, 2012 at 2:23 PM
    Pugga
    Massachusetts
    It is simple, it uses the truck as a counterweight to keep the coils compressed. The part that scares me is when you put it all back together. I don't see how you can get the top nut through the holes without having to put your fingers or something to guide the top of the shock lined up. You now have your fingers in or very close to a compressed shock that's not really held in place by anything. That's that part that scares me about it. Especially because lift coils are stiffer than the stock coils.
  11. Dec 5, 2012 at 2:27 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Thanks for the offer. The gas might be more expensive compared to just bringing the coilovers to a shop. Although i would like to learn how to do it. Why cant you guys live in western mass! Boston area is a hike for me.
  12. Dec 5, 2012 at 2:29 PM
    johnnym
    john
    NH
    It's cheaper just to go buy a compressor set and do it yourself . I think I paid $60 for mine . I've used it 4 times and I let my boss borrow it to do his wife's car last month .
  13. Dec 5, 2012 at 2:30 PM
    Pugga
    Massachusetts
    You won't learn much just swapping the spring over, it's just compress the spring, remove the nut and top plate, replace them on the new shock, retighten the nut and you're done. Literally, one nut. The bulk of the work is the tear down and reassembly on the truck.
  14. Dec 5, 2012 at 2:30 PM
    BostonBilly
    Easton
    I wasn't thinking about that I was thinking out of the truck. I have seen guys just let them fly :eek:
  15. Dec 5, 2012 at 2:33 PM
    johnnym
    john
    NH
    Although I believe you said you were doing ome springs ? My compressor won't work on those . I tried when I installed Miguel's lift . Or I should say we installed it was a group effort .
  16. Dec 5, 2012 at 2:34 PM
    Pugga
    Massachusetts
    Oh... yeah, don't do that method, that's extremely dangerous and idiotic. I assumed he was talking about the method where you put the jack under the LCA, jack up the truck, loosen the top nut, put a jack stand under the frame and as you let the LCA jack down, you release the tension on the coil.
  17. Dec 5, 2012 at 2:35 PM
    Pugga
    Massachusetts
    Why won't they work on OME coils?
  18. Dec 5, 2012 at 2:37 PM
    johnnym
    john
    NH
    The coils are to thick and close together for my tool to fit .
  19. Dec 5, 2012 at 2:38 PM
    johnnym
    john
    NH
    Worked on my eibachs but couldn't get it between the coils on the ome
  20. Dec 5, 2012 at 2:40 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    I am looking at some now. Anything you would recomend? Also can you guys think of any other specialized tools i might need or that might make things easier for me? So far i have picked up a 250 lb tourque wrench, breaker bar, metric impact sockets (i will use my buddys electric impact in areas i can get it) i have a good assortmet of metric sockets and open ended wrenches (5-19mm) also just got a pair of jackstands that extend up to 23" and a craftsman floor jack.
