New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jun 1, 2017 at 5:53 AM
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    Ahh okay.
    same exact line.
  2. Jun 1, 2017 at 5:54 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Do they snap or rub through?
  3. Jun 1, 2017 at 6:08 AM
    First one had a bend/ crease that blew out, I'm guessing this one will be the same, haven't gotten under her yet
  4. Jun 1, 2017 at 6:13 AM
    tacobell007
    Drew
    Western MA
    In the soft line?
  5. Jun 1, 2017 at 6:14 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    For all you guys that are doing brake lines, even doing a +4" in the front is total overkill and will most likely rub tires or the frame. When you do a simple lift on our front ends you are not changing any of the amount of suspension travel, you are only making it sit higher in it's same amount of suspension travel so no extended brake lines are needed. For the guys that put in extended length coilovers and UCA's you are only gaining about 1" of travel so the most you need to add is 1" extended front brake lines.
    If you're doing a long travel (LCA's & UCA's) suspension or a drop bracket suspension lift then those are different and should be done as needed.
    Jcyr and tacobell007 like this.
  6. Jun 1, 2017 at 6:19 AM
    tacobell007
    Drew
    Western MA
    Thanks Rob, I wasn't really sure and kinda thought +4" might be overkill
  7. Jun 1, 2017 at 6:22 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Phew, makes me feel much better. Thanks Rob.
  8. Jun 1, 2017 at 6:22 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Good morning everyone. Happy Friday eve.
  9. Jun 1, 2017 at 6:24 AM
    No, the hard line
  10. Jun 1, 2017 at 6:24 AM
    tacobell007
    Drew
    Western MA
    I have remote resi coilovers up front with uniball UCAs with stock lines and have no issues
    johnnym and mach1man001[OP] like this.
  11. Jun 1, 2017 at 6:24 AM
    So I'm not stretching my lines and I have some other problem destroying my brake lines? Fantastic
  12. Jun 1, 2017 at 6:25 AM
    tacobell007
    Drew
    Western MA
    Are you getting them too long or too short?
  13. Jun 1, 2017 at 6:25 AM
    What do you mean? I'm getting the OEM line
  14. Jun 1, 2017 at 6:30 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Get a new OEM hard line and get +1" soft lines and be done with it. Sounds like the line may have been tweaked during some service or when a lift was installed
  15. Jun 1, 2017 at 6:32 AM
    tacobell007
    Drew
    Western MA
    Ah you go to Toyota for it? I usually get premade ones and bend them myself
  16. Jun 1, 2017 at 6:43 AM
    Nicetacobro
    Nicetacobro Well-Known Member
    Adam
    Rhode Island
    2nd gen DCSB
    It's Taco time
    just in case people didnt see this [​IMG]
  17. Jun 1, 2017 at 6:44 AM
    Yeah, no reason not to. Looks like I need to get my hands on some +2 softies though.
    tacobell007[QUOTED] likes this.
  18. Jun 1, 2017 at 6:49 AM
    Nicetacobro
    Adam
    Rhode Island
    2nd gen DCSB
    It's Taco time
    yessir. i think @DoubleRGirl was in the market also if i remember correctly
    Byb127 and tacobell007 like this.
  19. Jun 1, 2017 at 6:52 AM
    Cativelense
    Nuno
    CT
    Question for you peeps, who might know more about this than myself.
    Trying to help a friend who lives in France, and is coming to NYC in July. He's looking for something along the lines for Air BnB, to find a place to stay, but is asking if there are other options, or sites, for that sort of stuff.
    Anyone know of anything that I could pass along to him?!
  20. Jun 1, 2017 at 7:03 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    vrbo.com and homeaway.com are sites similar to airbnb.
    Also HotelTonight is a good last minute hotel app. You can't book out very far, its basically hotel rooms that are unsold that you can book last minute for cheap
    Cativelense[QUOTED] likes this.
