New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jun 21, 2017 at 7:40 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Mine is from 1986, which is the last year they made it. They apparently stopped parts production about 10 years after that. He told me for a lot of things, he could fabricate something that would work. He also said the burner itself is a Riello so it's easy to get parts for. Just an issue if something obscure goes with the boiler itself.
    The last people just ran it and never even had it cleaned. He cleaned it really well, resealed some parts, changed a nozzle because he said the one on the burner was wrong, got it so he was happy with all the numbers.
    He had a lot of praise for the unit itself. He said if I were to replace it, I'd need another Pensotti, a Buderus, or similar triple pass low mass boiler to be in the same league as far as quality and efficiency goes.
    DrFunker[QUOTED] likes this.
  2. Jun 21, 2017 at 7:55 AM
    js312
    Joe
    New England
    If I had ended up with the house I looked at with 20 acres, I'd definitely be burning wood. My parents had a big Fisher wood stove in the basement and would go through about 3 cord a year.
    Where I am now, I'm just happy I have oil instead of Propane. People praise propane, but I don't think it's ever worked out better economically. There's less energy in a gallon of propane and it always seems to be more expensive than oil.
  3. Jun 21, 2017 at 8:08 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I have propane and oil in my house. Oil for the heat and hot water and propane for cooking and the dryer. I like the forced hot water baseboard heat but would swap that out for radiators in a heartbeat.
    My parents have a wood stove with a blower box behind it and it does a good job keeping the place warm. The blower is key.
  4. Jun 21, 2017 at 8:31 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    She had a pipe crack or something like that so she's been working on that for the last like week.
    tacobell007 likes this.
  5. Jun 21, 2017 at 8:34 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    OUCH. That sucks. The "joys" of home ownership.
  6. Jun 21, 2017 at 8:52 AM
    js312
    Joe
    New England
    Mine is hot water baseboard oil for heat. I had an aqua booster off the boiler for hot water, but I tore it out and put in an electric. A tempering valve was shot on it and the tank was 40 years old and had signs of corrosion so I didn't want to keep running it. Oil hot water is probably great in the winter since you're running the boiler anyway, but it seemed like I was going to burn through a tank of oil in the summer just to heat water. My electric bill only went up about $25 with the electric hot water, so I think I came out ahead.
    It'd be nice to have natural gas for everything, but I'm in a rural area so that's not an option.
    I wish I had a propane stove. Mine's electric, as is the dryer. Glass cooktops are easy to clean, but cooking over a flame is so much nicer. I do have a propane fireplace insert in my office, so I'll probably fill the tank before winter so I can use it if I want to. It's just about out now.
  7. Jun 21, 2017 at 9:38 AM
    Fitzwilly
    Fitzwilly Well-Known Member
    Bill
    South Central Mass
    2018 JKU "Golden Eagle" Edition
    Our last house was 1300 sq feet and we heated it with a harman p68 standalone. Was playing with different hardwood/softwood blends first few years but the last two years we were there; we burned okanagon golds and platinums. Lots of heat and very little ash.
    Just cut a slice off some of the logs that I could get to: 965C1B8A-9E44-4290-9183-A40E3432D0EB_c7d73258f8f4c1e66cea70496e53c2c550d02887.jpg
  8. Jun 21, 2017 at 9:40 AM
    js312
    Joe
    New England
    I had a Quadrafire Castile standalone upstairs and an older Whitfield downstairs. The Whitfield could burn anything and not care. The Quadrafire was a little pickier. Probably because the Quad had a firepot that could fill up and the Whitfield burned over a grate that would drop ash directly into the pan.
  9. Jun 21, 2017 at 9:42 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Is all of this talk about stoves & heating because today is the longest day of the year and from here on out the days are getting shorter bringing on Winter? :devil:
    Spare Parts and tacobell007 like this.
  10. Jun 21, 2017 at 9:45 AM
    Fitzwilly
    Bill
    South Central Mass
    Nah, I was/am trying to get rid of a stack of trees that were delivered for firewood before we bought our house.
    vssman[QUOTED] and tacobell007 like this.
  11. Jun 21, 2017 at 9:48 AM
    Pugga
    Massachusetts
    When I bought my house, the stove and dryer were electric but there wasn't any room left in the electric panel. They also had a 120V full sized dryer which I'd never seen. I yanked out the 240 for the oven and the circuit for the dryer, bought propane appliances and redistributed the power throughout the house. They only had one 14 ga wire running the entire upstairs, lights, outlets, everything. No way I was going to try running window A/C units off of that.
  12. Jun 21, 2017 at 10:05 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Won't be long now, the days are getting shorter and shorter.
  13. Jun 21, 2017 at 10:15 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    YES, bring on winter!
    uurx and Jcyr like this.
  14. Jun 21, 2017 at 10:18 AM
    Pugga
    Massachusetts
    I love winter, but shush you, it's motorcycle season!
    :bikewhoops:
  15. Jun 21, 2017 at 10:49 AM
    js312
    Joe
    New England
    My house was built in '57, but it's a 150A service and all breakers are at least 20A. There's also a lot of room left in the panel, so they clearly thought ahead, but some of the stuff they did is just stupid.
    The entire garage is on a 20A circuit. Lighting, door, outlets, everything. The garage and the breezeway room that I use as my office were clearly additions, so I don't understand why they didn't run more circuits in there or a sub panel. Now it'd be a pain to do because there is no access to the space above the breezeway room and it's on a slab so the basement ends before that room starts. And there's a pergola out back that it appears they ran power to by double-tapping into a 20A breaker with 14 gauge wire. Have to pop a 15A breaker in and split that off. The rest of the wiring is all 12 gauge, so no idea why they did that for that one spot.
    I've started by fixing lighting. The garage lighting situation was useless, so I replaced everything with recessed can lights and 75w equivalent LED bulbs. Want to do the same to the basement to get rid of the tons of florescent fixtures. They also have front and rear flood lights that are directly wired without a switch, so they rely on the motion sensors.
  16. Jun 21, 2017 at 10:49 AM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    Ugh. No please! I'm not ready!
  17. Jun 21, 2017 at 10:58 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I am so jelly of your sled!
    jethro[QUOTED] likes this.
  18. Jun 21, 2017 at 10:59 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
  19. Jun 21, 2017 at 11:52 AM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    I had a sewage backup in my basement/garage. I highly recommend finding out who owns your clean out pipes and getting them scoped and insured. This def could have cost me thousands more, and luckily insurance is covering the demo, sanitation, and rebuilding
  20. Jun 21, 2017 at 11:53 AM
    DoubleRGirl
    Rebecca
    Rhode Island
    @Sloth just finally met Patrick in person
