New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jun 30, 2017 at 9:51 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Hold on guys!!!
    I recall seeing something on Animal Planet that they were more partial to dogs instead of cats...
  2. Jun 30, 2017 at 9:52 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Yeah, that's really not the best version of "bring a girl home so you can eat some pu..."
    Never mind.
  3. Jun 30, 2017 at 9:57 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Most Asian girls I know have dogs for pets. Unless they're just going to fatten them up first....
    Spare Parts and tacobell007 like this.
  4. Jun 30, 2017 at 10:00 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I equate this to me being partial to steak but I wouldn't turn down a pork chop.
    Spare Parts and vssman[QUOTED] like this.
  5. Jun 30, 2017 at 10:07 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    LOL
    No but it still works!
    tacobell007 likes this.
  6. Jun 30, 2017 at 10:10 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Looking forward to the report. I'm looking at temps in the 225-235 degree range when I get into the hills up north and I'd like to bring them a little lower. I'm considering an additional cooler or something like what you're doing.
  7. Jun 30, 2017 at 10:16 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Hey! Hey! Hey! Take this over to the technical section! This thread is all about off color discussions! :D:p:rolleyes:
  8. Jun 30, 2017 at 10:20 AM
    Noelie84
    Noel
    Wales, Maine
    Fun fact- I've still been averaging 19.5 mpg's and less than 200 degrees towing the boat through mixed terrain. And interestingly, even in Toad Hall mode the truck still utilizes 6th gear (which is a double overdrive) and still doesn't go over 200. I can manually lock it out of 6th, 5th, etc. using the gear selector, but so far it doesn't do it on its own. Probably it monitors the transmission temps and if they climb past a certain point it'll automatically lock out of top gear. :notsure:
    Edit- Also, the locking rear diff has been super handy loading and unloading el boato, since you can lock it in even in 2-hi right from the factory. I've had a couple of slippery ramps that I've locked it in for and it's been great. Helps make up for the crappy street slicks I've got on there, lol.
    Oops...
  9. Jun 30, 2017 at 10:35 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Hopefully it goes well, I got up to 240 when I was bumper to bumper on a steep incline. However I got up to 200 just driving around without a trailer the other day.
  10. Jun 30, 2017 at 10:52 AM
    Pugga
    Massachusetts
    I think you're giving tow/haul mode too much credit. It will not lock out certain gears but should hold lower gears longer. One of the things I really like about the tune that I'm running is it acts more like a stick shift. It holds those lower gears longer and is much more willing to downshift under load. Under normal operation, it tries to hold 5th, starts to bog, then drops to 3rd, revs the shit out of it, then back to 5th and repeat. The tune will drop to 4th more quickly and the truck generally has plenty of power to use 4th to power up the hill and hold it's speed.
  11. Jun 30, 2017 at 11:07 AM
    Noelie84
    Noel
    Wales, Maine
    The shift points are different, and it engine brakes aggressively (like, if I'm going down any sort of incline and I let my foot off the gas it'll downshift if my speed increases by even 1mph). I don't notice any issue with it 'searching' for gears when I'm going up a hill, but I'm not towing a huge load (2500lbs or so, definitely nowhere near the max rating) so it's obviously less of an issue. I push on the throttle approaching a hill and it kicks down a gear or two (depending on my speed) and holds it all the way up, until I let back off the gas.
    Edit- I'm surprised that Tow/Haul doesn't lock out 6th, though, because the GF's dad's GMC locks out of OD when you engage Tow/Haul. Also the 3/4 ton Dodges I've driven over the years have done the same thing; push the 'Tow' button and you're locked out of OD. :notsure:
  12. Jun 30, 2017 at 11:13 AM
    Pugga
    Massachusetts
    I agree there are other aspects to tow haul mode. Mine will do the same with the more aggressive engine braking. The gear hunting got obnoxious though but it's really only an issue when towing through mountains with long, steep grades. Before the tune, I would put it in manual mode and just do the shifting myself (which I still do at times even now). I like having control and knowing exactly what the truck is going to do. I sometimes really miss having a manual transmission.
  13. Jun 30, 2017 at 11:17 AM
    replica9000
    2019 T4R ORP
    I don't own an F-150. Can I still post here? :D
  14. Jun 30, 2017 at 11:17 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    :pout: someone has to know neon! He was here a ton back in the day! Find him for moe recipies!
  15. Jun 30, 2017 at 11:18 AM
    jpneely
    Charleston, SC
    Damnit... Wrong thread. Damn fat thumbs on a small smart phone. Carry on!
    mach1man001[OP] and Pugga like this.
  16. Jun 30, 2017 at 11:19 AM
    Pugga
    Massachusetts
    NO!
  17. Jun 30, 2017 at 11:21 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    So what do you have, a Jeep? :D
  18. Jun 30, 2017 at 11:21 AM
    Noelie84
    Noel
    Wales, Maine
    Only on Taco Tuesdays.
    This is F150 Friday :p
    Well now I want to know who neon is, and get some of these recipes...
    Spare Parts, DoubleRGirl and vssman like this.
  19. Jun 30, 2017 at 11:21 AM
    replica9000
    2019 T4R ORP
    :pout:
  20. Jun 30, 2017 at 11:23 AM
    replica9000
    2019 T4R ORP
    Whoa sir! No need to use four letter words around here!
    vssman[QUOTED], Nicetacobro and Pugga like this.
