New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jul 19, 2017 at 2:58 AM
    DrFunker
    DrFunker Well-Known Member
    It is not bad. Not sure if it is just because I have gotten used to it now, but I do like it better without it on. I may, for shits n giggles, throw it back on with a relocate kit just to feel the difference. I am thinking it is going to feel too constricting for me.
  2. Jul 19, 2017 at 3:08 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy hump day.
  3. Jul 19, 2017 at 3:16 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Nothing wrong with a Mobil 1 filter at all except for the small size they recommend but you had already addressed that. I just get the Toyota filters because they are cheap and good. Usually I just tell them where I work and I get it for about $4 but last time I went in and told him where I worked the guy just threw one to me at no charge
    I know this ^^^ is what you said but after reading your reply's to what others have said I can tell you only want to do this once and do it right but not spend a ton of money doing it. I have personally run a few different setups in my truck. Each time was a big improvement. 5100's are a lot beefier than the factory TRD suspension but I do agree with Seth here. They seem to be designed to run so soft that they seem under dampened. The Old Man Emu setup over the 5100's honestly is like doing the suspension over again. They are so much beefier than the 5100's and they ride that way too (I have the original design). Mine are firm but not harsh and the control is very very good. They do make the sport (soft riding version) now too that is supposed to give the same handling but with a cushier ride.
    If it were me you were asking and only wanting to do your truck once and not worry about it for years to come then I would definitely recommend a full OME setup with Dakars or at least a ICON 3 leaf AAL setup, staying away from the single AAL. If you want a UCA then stick with a ball joint type like the Light Racings or Camburg BJ's
    Morning everyone
    vssman[QUOTED] and DrFunker like this.
  4. Jul 19, 2017 at 3:37 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Spent all last night in the wet oily engine bay of my 22ft formula...diagnosing then changing a starter on 350 mercruiser from the top is never fun. I also changed like 5 rotten wire terminals... but she purrs again so it was a good night
  5. Jul 19, 2017 at 3:58 AM
    Nicetacobro
    Nicetacobro Well-Known Member
    Adam
    Rhode Island
    2nd gen DCSB
    It's Taco time
    Ive got the 5100 all around with ome 885 and a aal in the rear. Works great for what i do and i wheel my truck occasionally, that being said the aal was shit and is failing less than 1 year in. Otherwise great lift for the money.
    vssman[QUOTED] likes this.
  6. Jul 19, 2017 at 3:58 AM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    I'll toss out to look at the Bilsetin 6112s if theres a little extra cash wiggle room. I didn't run the 5100s but I did have the OME and wasn't all that impressed with them and didn't get that many miles out of them.
    Also side note find out that if you miss one notification here by accident you become like 10 pages behind
    Sloth and vssman like this.
  7. Jul 19, 2017 at 4:03 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    Mine's similar, only I have 884s in the front and General HD springs in the rear. Wanted to keep it a little higher in the back rather than level.
    I blew my first set of rear 5100s because I think the springs were too much height and over-extended them a few times. They've settled a little since, though, so I put a new set of 5100s on the back and they've been fine.
  8. Jul 19, 2017 at 4:35 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Morning, everybody.
    Mike Mike Mike Mike Mike....
    Cativelense and vssman like this.
  9. Jul 19, 2017 at 4:37 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    Friday for me! :bananadance::bananadance:
    Noelie84 and vssman like this.
  10. Jul 19, 2017 at 4:51 AM
    Noelie84
    Noel
    Wales, Maine
    Yeah, well, you suck. :laugh:
    I've even got to work Saturday this week. :frusty:
  11. Jul 19, 2017 at 5:06 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Morning. Happy hump something day.
  12. Jul 19, 2017 at 5:06 AM
    morri89
    Brendan
    Hopedale MA
    2020 Rubicon
    Having to work Saturday does suck.
    GF and I rented a condo for 5 days in NH and we are having a ton of our friends up. We are doing a sort of combined bachelor/bachelorette weekend thing. I think they are called 'Jack and Jill' weekends..?
    tacobell007 and jpereira2 like this.
  13. Jul 19, 2017 at 5:07 AM
    Noelie84
    Noel
    Wales, Maine
    Cool. Where in NH?
  14. Jul 19, 2017 at 5:10 AM
    morri89
    Brendan
    Hopedale MA
    2020 Rubicon
    Lincoln. Not sure what we are doing since we only rented the condo and then the rest of the weekend was being planned by my brother and Lauren's bridesmaids.
    Noelie84[QUOTED] and tacobell007 like this.
  15. Jul 19, 2017 at 5:15 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Hey yall, if anybody needs something transported between CT and MA I am heading down to meet with @Cativelense saturday morning. I'll be leaving MA at approximately 5am.
    tacobell007 and Cativelense like this.
  16. Jul 19, 2017 at 5:23 AM
    Noelie84
    Noel
    Wales, Maine
    Sixty kilos of cocaine?
  17. Jul 19, 2017 at 5:24 AM
    Cativelense
    Nuno
    CT
    You buying or selling?
  18. Jul 19, 2017 at 5:25 AM
    jethro
    Geoff
    Southern NH
    Spare Parts and jpereira2 like this.
  19. Jul 19, 2017 at 5:26 AM
    Cativelense
    Nuno
    CT
  20. Jul 19, 2017 at 5:27 AM
    Noelie84
    Noel
    Wales, Maine
    Yes.
