New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jul 19, 2017 at 1:20 PM
    eborgie
    eborgie No Yotas Here
    Erik
    Bellingham, MA
    2023 Bronco Sasquatch
    Clear the drain line coming out of it. Prob some clear plastic tubing out of the low part of the pan.
    jpereira2 likes this.
  2. Jul 19, 2017 at 1:30 PM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Should there be a line ? this is flat with no drain in it
  3. Jul 19, 2017 at 1:37 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Yes there should be a drain that runs outside.
  4. Jul 19, 2017 at 2:01 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    John's right, either clean the hose that drains the pan or, if there isn't a drain, then run one yourself. Absolutely silly for there not to be one. If that pan doesn't have a drain, it might be an emergency catch pan or an overflow pan. The unit itself may have a means to drain condensate and that one may be clogged, causing that secondary pan to overflow.
  5. Jul 19, 2017 at 3:16 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Messy, sure, but my experience with it has done nothing but impress me. I went through (4) New England winters and my frame was effectively spotless outside of where the factory finish was chipped off by rocks / road debris. My best friend bought an Xterra the same time I bought mine and didn't coat his frame and the difference was night and day (not apples to apples, but Nissans aren't known for frame issues like Toyota). I checked out a few 2012-2013 trucks to compare to mine and it was world's different.
    Is it cumbersome to work on the frame with the coating, sure, but I'm confident my frame would have lasted significantly longer than the average Tacoma frame because of all the FF I sprayed on it. I just wore gloves when I did my suspension that I tossed when I was done.
    Dirtridercrf250 likes this.
  6. Jul 19, 2017 at 4:07 PM
    Dirtridercrf250
    It must be an emergency drain because i do have a float sensor. When the water gets too high it shuts the ac off thus no more water. No drain has me on my nerves
  7. Jul 19, 2017 at 4:13 PM
    Alattaack
    Alattaack Well-Known Member
    NE
    2011 Tacoma TRD Sport
    So I was just reading some of the posts from a little while ago, what do you guys suggest I should do to prevent rust on my brand new 5100's?? Thanks
  8. Jul 19, 2017 at 4:15 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Not much you can do. Get some 3m vinyl coating on then maybe. Otherwise fluid film The crap out of them, especially in the winter.
    Alattaack[QUOTED] likes this.
  9. Jul 19, 2017 at 4:16 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    And the rust doesn't mean they went perform as designed. The zinc coating is actually meant to rust (anode) so the base metal doesn't corrode. It does look dumpy though
    Alattaack and Dirtridercrf250 like this.
  10. Jul 19, 2017 at 6:46 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    I'm going to give the mavcoat a try this winter and see how that works out with the Kings.. which might not even work out at all since I might be buying a beater for the fall. haha
  11. Jul 19, 2017 at 7:25 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I'd get neoprene covers for the Kings. Maybe cover with fluid film before wrapping in the cover for extra piece of mind
  12. Jul 19, 2017 at 9:11 PM
    Bruce988jl
    Southern NH
    Everyone I know that's run the covers only had moisture trapped inside them and it made it worse. (these sleeves have been around for years in the tuner scene)
    tacobell007 likes this.
  13. Jul 20, 2017 at 1:40 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Morning peoples.
    Anyone here make a 40+ minute commute to work everyday? Wondering if I should make the taco more MPG friendly, or buy an eco-beater.
  14. Jul 20, 2017 at 1:49 AM
    Pugga
    Massachusetts
    I'm over 40 minutes each way. I've done the math out a few times and an eco beater just doesn't make sense. By the time I buy a vehicle, insure it, keep fuel in it and even leave out the maintenance costs (figuring that if I'm maintaining that, the truck would be sitting), the math doesn't work. I don't drive enough miles to even make me break even in a relatively reasonable amount of time. For my calcs, I'm using 18 MPG for the truck and figuring 30 MPG for a beater car.
    replica9000[QUOTED] likes this.
  15. Jul 20, 2017 at 3:08 AM
    replica9000
    2019 T4R ORP
    Maybe I'll throw on some P-rated AT tires and leave the beefier tires for the trail.
  16. Jul 20, 2017 at 3:31 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    I'm right there at 40 minutes each way. I don't think it's horrible, but my point of comparison is a commute to Waltham that was easily two hours each way.
  17. Jul 20, 2017 at 3:34 AM
    Nicetacobro
    Nicetacobro Well-Known Member
    Adam
    Rhode Island
    2nd gen DCSB
    It's Taco time
    I drive about 40-75 miles a day. Was driving the taco everyday but the E load MT tires are far from highway spec. Bought a $400 POS corolla and been driving it for the past 6 months. Much happier!!
    jpereira2 and tacobell007 like this.
  18. Jul 20, 2017 at 3:35 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Damn I thought my 30 minutes to the last shop I worked at was somewhat long. Sometimes I would have a 6 hour drive, sometimes longer, (when they had their machinist travel with their trailer with a lathe, Bridgeport and small blast cabinet :D ) like Niagara Falls, and a few other places
    Nicetacobro likes this.
  19. Jul 20, 2017 at 3:36 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    I did that calculation once when I was looking at a mighty commute for a job I ultimately didn't get. At the time the price of gas was significantly higher and I was using the STi with premium fuel as my base point. I used the $9,999 MSRP Nissan Versa Base 1.6L as my beater car and the math sorta worked when it was $4.xx / gallon, but otherwise it didn't work.
    For what it's worth, I never found much of a MPG difference between my BFG ATs and my highway tread snow tires. I know that winter fuel causes a bit of a MPG drop, but for 1-2 MPG, the math would take a long time to prove out a second set of tires.
    Sloth likes this.
  20. Jul 20, 2017 at 3:52 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    One benefit to a second set of tires is how cheap they are... I have a set of 29" tires for when I used to commute my truck and I could buy two tires for the cost of one of my 33" tires
