New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jul 26, 2017 at 6:25 PM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    I visited a small company today the had legit "Tundra Parking"... the best part was that the spots were about 1.5x the norm and all closest to the door.
    Thought it was interesting
  2. Jul 26, 2017 at 6:28 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Sweet, what kind of company is that?
  3. Jul 26, 2017 at 6:43 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    X2
    Moved campgrounds from Hershey Park to twin Grove today.
    Question for you camping folks. Why does my hot water smoke out a bunch of soot when I first light it? I originally thought it was just because of how long it had been but it did it again when we got here and it was being run for days before
  4. Jul 26, 2017 at 7:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That likely means there's something in the exhaust that shouldn't be there. Try blowing it out with compressed air to make sure the exhaust path is clear. You shouldn't get soot from that. Also blow out the fuel pipe, after the nozzle. Make sure there aren't any spider webs in there.
  5. Jul 26, 2017 at 7:34 PM
    Pugga
    Massachusetts
    Rob, either that or your air fuel mix is off. Check the collar to make sure it didn't move during transport. When the heater is on, it should be a nice, blue flame. If it's orange, you're not getting enough air in the mix and that can cause the black soot also. Don't let that go too long, that's not normal at all.
  6. Jul 26, 2017 at 8:08 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I can see the flame all the way up to the exhaust side when I 1st light it and yes its a yellow flame but after a little while the flame changes to blue
  7. Jul 26, 2017 at 8:25 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    I'm fucked... The wife is gonna divorce me after this for sure. I'm getting that HomerTaco grille with the white surround. Looks like I'll be able to take the insert off and snap it onto my existing black surround... I think. So, I'll have a Pro Grille and a white surround to try and sell to hopefully make some money back and make the "hit" for buying the HomerTaco grille not as bad.
    Haven't really put any thought into the price of the Pro though...
  8. Jul 27, 2017 at 3:03 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Homer's aren't glued together so it does come apart with the screws and clips. You should be good there. I wish you the best on the castration... :D
    Morning all!
  9. Jul 27, 2017 at 3:35 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    There is an alien living inside my wife!
  10. Jul 27, 2017 at 3:41 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Good luck!
    jpereira2 likes this.
  11. Jul 27, 2017 at 3:45 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    One of them is older, pre-hdmi. Think it's an Optimus. The other is an Onkyo tx-sr...something that needs $1 worth of parts and soldering (plenty of YT how-to videos)
  12. Jul 27, 2017 at 3:46 AM
    Pugga
    Massachusetts
    If it's just a quick puff of black smoke, then the flame turns blue and no more soot, that shouldn't be an issue I wouldn't think. I would check the fuel mixture tube to make sure nothing is in there, same with the exhaust. If both are clear and the flame is blue, I don't think you have anything to be concerned about. I'm camping this weekend, I'll pay closer attention to what happens when I first light mine.
  13. Jul 27, 2017 at 3:53 AM
    Cativelense
    Nuno
    CT
    LOL. Geez, thanks a lot. ;)
    Congrats Jason! Hope I didn't scare you with my crazy rant when you were here on Saturday. :D
    Good morning and happy Friday eve everyone!
    jpereira2[QUOTED] likes this.
  14. Jul 27, 2017 at 4:19 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Yeah my biggest problem is getting compressed air to the camper that is already set up. No biggie when I'm not camping but a pain right now. Think a can of compressed air would work? Also i will check the mixture tube to see if that works.
    Morning from PA once again everyone!
  15. Jul 27, 2017 at 4:23 AM
    Pugga
    Massachusetts
    I would think a can of that keyboard cleaner stuff would do the trick. Start with the mixture tube first to make sure there aren't any of those spider web or moth cocoons in there blocking your air flow. Then blow air in from the exhaust in short bursts to see if anything loosens up, maybe a leaf or something in the exhaust. If neither of those work, it could just be nozzle adjustment issue. Maybe it's not that it's not getting air but that it's getting too much fuel.
  16. Jul 27, 2017 at 4:24 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    A can of air should work. If the flame turns blue quickly, I wouldn't think there would be spider webs blocking the air adjustment.
  17. Jul 27, 2017 at 4:29 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    It's a 46" cut. It's very close, but I can't quite make it.
    I had a 42" at one point and I could just barely drive it right in, which is odd considering the width between the wheel wells is supposedly 41.5"
  18. Jul 27, 2017 at 4:33 AM
    js312
    Joe
    New England
    Anyone ever get a weird rattle noise from somewhere under the middle/back of the truck over bumps? It used to only happen on really rough terrain, but now it seems like it's any larger bump. It's a weird noise. Almost like the sound of a spring letting go inside a steel drum. Fairly quiet too. If the radio is on at all I won't hear it.
    I've crawled under the truck with a creeper and hit things and nothing moves or rattles at all, so I'm stumped.
  19. Jul 27, 2017 at 4:38 AM
    js312
    Joe
    New England
    I think I'm going new this time. The price difference between a '14 or '15 and a '17 isn't significant. Beyond that, the price difference between a loaded SR5 TRD Off Road (bucket seats, larger fuel tank, etc.) and a Limited TRD Off Road was not a whole lot more than if I added leather and heated seats myself and then I still wouldn't get the auto climate control or the power rear window.
    I'd really like it if they do a Limited TRD Sport for next year. No chrome, but would still have a nice interior. Not like the Tundra has a locker anyway, so you don't lose anything worth mentioning off the Off Road.
    tacobell007[QUOTED] likes this.
  20. Jul 27, 2017 at 4:59 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Morning everybody! Happy Friday! :bananadance:
    Tomorrow the broilers go into the freezer! :bananadance: I've got 6-7 of them that turned out to be cockerels and they're learning how to 'crow' but it just sounds like somebody strangling a regular rooster. Add in my layer roo (who crows a legit 'cock-a-doodle-doo' and at 4:30 in the morning it gets pretty loud around my house.
    https://www.youtube.com/watch?v=Q2RWKTLkLFg
    Certainly looks like a Vagburster. Congratulations/my sympathies.
