New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jul 27, 2017 at 11:31 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Sounds like mine. It's only about 30 feet deep, but the water level's never dropped below 15 feet or so since we've been there. Even during that ridiculous dry spell that we had last year we always had a ton of reserve capacity.
    Ouch.
    Power outages aren't a big problem for us during the winter, since we heat with wood and we've also got the old wood-burning cookstove w/reservoir for cooking on and for hot water. But for outages during the summer it takes a long time to boil a pot of water for dishes (or humans) on the side burner of the grill. And cooking in a pouring rain becomes annoying, lol.
  2. Jul 27, 2017 at 11:37 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Anybody ever buy a salvage car from copart? tempting to find a 4runner, tundra, or tacoma
  3. Jul 27, 2017 at 11:45 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I have to replace my well pump eventually because it has a very slow leak. I'm worried about priming it, but this spring I pulled the cover off the well the water level was higher than the pipe going into the house. Guess that would make priming a non-issue. :rofl:
    I think it is a little lower now.
  4. Jul 27, 2017 at 11:57 AM
    Noelie84
    Noel
    Wales, Maine
    Where's the leak? Just a check valve that lets it bleed back, or is the pump itself leaking out into the cellar? Because a check valve is an easy swap, and you can rebuild those pumps pretty easily.
    The 'crazy survivalist' in me actually kind of likes having a shallow well; I've got a hand pump rigged up the basement for when we lose power, which wouldn't work with a deep drilled well. When the power goes out I just shut the valve on the pipe going to the electric pump and open the valve on the pipe going to the hand pump. Prime the hand pump once and we're in business.
  5. Jul 27, 2017 at 12:07 PM
    Noelie84
    Noel
    Wales, Maine
    As a fun aside...
    Go to google and type "the owner of the New York Jets" into the search bar
    :laugh:
    Spare Parts, Pugga and morri89 like this.
  6. Jul 27, 2017 at 12:14 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    :rofl::rofl::rofl::rofl:
  7. Jul 27, 2017 at 12:29 PM
    js312
    Joe
    New England
    The pipe connections into the cast iron housing appears to be where the water comes from. The housing has rusted badly, though, so I want to try to replace everything. I honestly think that's a lot of where the iron in my water comes from, assuming the inside looks anything like the outside.
  8. Jul 27, 2017 at 12:43 PM
    Noelie84
    Noel
    Wales, Maine
    I'd be surprised if you were getting much iron leaching into the water from the cast iron in the pump housing; cast iron is really, really slow to corrode. The water would have to be sitting in there for quite a while to pick up anything.
    Now, iron bacteria on the other hand...those little buggers are a pain. They can really build up in a hurry, and they look like iron stains/deposits. You can kill them off with chlorine, though.
    http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/agdex1142
    I had to do this with my well when we first moved in. I pumped the well down as low as I could get it using the pump in the house and a borrowed sump pump, then poured the shock treatment in. Once the well had filled back up a little bit I pumped the solution into every pipe in the house, then let sit for 12 hours and drained everything out and emptied the well again. Haven't had any problems with them since.
  9. Jul 27, 2017 at 1:03 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Could you PM a pic or two of it?
  10. Jul 27, 2017 at 1:44 PM
    js312
    Joe
    New England
    Interesting. I'm wondering if that's what it is. The first filter turns red within a day or two and there is loads of what looks like rust on the pump housing. The second filter takes two months to start looking bad (they are in line with one another).
  11. Jul 27, 2017 at 1:46 PM
    Noelie84
    Noel
    Wales, Maine
    It's a strong possibility. Either that or you've got a mild steel fitting in the bottom of your well that's in pretty rough shape :laugh:
  12. Jul 27, 2017 at 2:06 PM
    js312
    Joe
    New England
    I just assumed my pump housing was made of the same stuff old Tacoma frames are! :rofl:
    Spare Parts and Noelie84[QUOTED] like this.
  13. Jul 27, 2017 at 2:14 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Sure. It'll be a couple days before I get to it though.
    I'm pretty sure the Onkyo is a TX-SR707. The fix is replacing 3 capacitors on the board.
    I'm not sure what model the older one is.
    tacobell007[QUOTED] likes this.
  14. Jul 27, 2017 at 7:25 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That's awesome!
  15. Jul 27, 2017 at 8:55 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Where was my invite?
  16. Jul 28, 2017 at 3:08 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning NETW'ers
    Cativelense and tacobell007 like this.
  17. Jul 28, 2017 at 3:50 AM
    Cativelense
    Nuno
    CT
    Good morning. Happy Friday.
    jethro, vssman and morri89 like this.
  18. Jul 28, 2017 at 3:55 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    Morning. Looks like today is going to be wicked nice!
    jethro, Cativelense and vssman like this.
  19. Jul 28, 2017 at 4:53 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Happy Friday to youse all
    Cativelense likes this.
  20. Jul 28, 2017 at 4:58 AM
    MTyota86
    MTyota86 Well-Known Member
    Haverhill, MA
    09 TRD Off-Road
    Airaid Intake, Magnaflow Exhaust, Diff Breather, SOS Concept Sliders, OME 3" Lift, SOS Concept rear bumper, Plasti-Dip grill and Badges.
    Happy Friday all
    So I have to replace the rear rotors/pads in my daily driver and pads in the Tacoma. Was wondering what you guys do for sourcing parts. Do you stick with OEM, go to Pep Boys or Autozone, or find something from the interwebs? I'm probably overthinking this, just figured I'd see what other do.
    mach1man001[OP] likes this.
