New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Aug 31, 2017 at 9:47 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Self etching is what I would recommend from those I think. Don't know about primer sealer
  2. Aug 31, 2017 at 9:50 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Was thinking the same after writing that and got me a can of it.
    They told me the bamf should be done tomorrow morning, so I might be putting it on tomorrow. Have to get the bolts I need to attach it to the truck first.
    tacobell007[QUOTED] likes this.
  3. Aug 31, 2017 at 10:00 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    If they didn't specify, go grade 8.
    tacobell007 likes this.
  4. Aug 31, 2017 at 10:02 AM
    Cativelense
    Nuno
    CT
    They didn't say... what does that mean?
  5. Aug 31, 2017 at 10:05 AM
    Noelie84
    Noel
    Wales, Maine
    Grade 8 is stronger (and in my experience, more rust resistant)
    tacobell007 and Cativelense like this.
  6. Aug 31, 2017 at 10:06 AM
    Cativelense
    Nuno
    CT
    Gotcha. Going to give them a call in a bit then, to find out/request, hopefully.
    EDIT: Are you talking about the primer, or the sandblasting?! :confused:
  7. Aug 31, 2017 at 10:18 AM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    Grade 8 is a type of bolt
    EDIT: Like the strength of the bolt. So grade 8 is almost the strongest level
  8. Aug 31, 2017 at 10:26 AM
    Cativelense
    Nuno
    CT
    AH HA! Gotcha. He's talking about bolts. Cool, good to know.
    Thanks for all the help and info peeps. Really appreciate it. Seriously!
  9. Aug 31, 2017 at 10:30 AM
    jztacoma
    Upstate NY
    Semi Stockish
    no worries! yeah I could see how you got mixed up since mainly were talking about coating and said you need to find some bolts.
    Grade 8s are harder and stronger then Grade 5, and also have a gold/yellow color to them since they have a different coating compared to the grad 5 zinc coated bolts. The Grade 8s are a hair more corrosion resistant but not entirely.
    Since its just a light bar going in you can get away with Stainless Steel hardware. This will keep the corrosion at bay, and they are actually fairly strong to. Worst case is just paint over the bolts if you cant get SS ones.
  10. Aug 31, 2017 at 10:31 AM
    BananaPeelOut
    BananaPeelOut Well-Known Member
    Ben
    NH
    2005 silver access cab TRD Off-Road
    Kenwood Headunit, CB radio setup, wind deflectors.
    I think its a HD thing, revving them unnecessarily.
  11. Aug 31, 2017 at 10:32 AM
    Cativelense
    Nuno
    CT
    Was actually thinking about that, painting the bolts after I put it all on, especially since my radiator is already painted black so the bolts would stick out way too much.
  12. Aug 31, 2017 at 10:35 AM
    jztacoma
    Upstate NY
    Semi Stockish
    yeah not that bad idea. Do recommend using Ny-Lock nuts for all of this. Radiator support does get a lot of vibrations so will help keep everything from loosening up. And couple drops of blue loctight will help to
    Cativelense[QUOTED] likes this.
  13. Aug 31, 2017 at 10:36 AM
    Cativelense
    Nuno
    CT
    If I use locktite, it'll basically make it never come off, right?! Not sure if I want to do that route, just in case.
  14. Aug 31, 2017 at 10:39 AM
    Noelie84
    Noel
    Wales, Maine
    Yeah, I was recommending Grade 8 bolts for the corrosion resistance, not for the strength, in this case. SS works too (obviously they're corrosion resistant, lol) but is expensive
    jztacoma, tacobell007 and Cativelense like this.
  15. Aug 31, 2017 at 10:39 AM
    tacobell007
    Drew
    Western MA
    Na blue is medium strength which can be broken with hand tools. There's also 2 variants of red. You can also get lock washers, I use them on my light bar with flat washers and rubber washers without issue
    jztacoma and Cativelense[QUOTED] like this.
  16. Aug 31, 2017 at 10:40 AM
    jztacoma
    Upstate NY
    Semi Stockish
    Red yes, blue no. Blue you can break with a breaker bar or just little more ass on the wrench. Red you need heat typically to get it to break loose. You can also get weaker Blue as well. I usually will do a ny-lock and a lock washer if I don't have any blue lock tight. Slightly overkill but sometimes rather not worry bout it
  17. Aug 31, 2017 at 10:40 AM
    Cativelense
    Nuno
    CT
    Well... I think the bolts for the drop down brackets have nylock nuts already. The bolts that are going to bolt the bamf bar to the truck don't take nuts, I don't think, so I don't think I need/can use nylock nuts there.
  18. Aug 31, 2017 at 10:41 AM
    jztacoma
    Upstate NY
    Semi Stockish
    lock washers will work there then
  19. Aug 31, 2017 at 10:42 AM
    Cativelense
    Nuno
    CT
    Cool. Going to try and get lockwashers then instead of regular washers for those bolts then.
  20. Aug 31, 2017 at 10:43 AM
    jztacoma
    Upstate NY
    Semi Stockish
    you'll still need a flat washer. So order is flat washer, lock washer, bolt.
    You want the flat washer to be touching what ever you are bolting to, then the lock washer, and then the bolt
    Breakfast Taco and tacobell007 like this.
