New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Oct 19, 2017 at 6:46 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Yep - ordered everything 3 pulleys, belt, tensioner. I'm just going to replace the pulley on the tensioner - from what I read there is no need to replace the tensioner unless the shaft is bad. Hopefully its not bad but with my luck it is...
    That little black stub used to have a pulley on it...
  2. Oct 19, 2017 at 6:46 AM
    Bruce988jl
    Southern NH
    Well she always wanted to be a white girl...
  3. Oct 19, 2017 at 6:47 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Pulley ate its bearings for breakfast and the wheel jumped off of the shaft.
  4. Oct 19, 2017 at 6:48 AM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    OH! Damn thats weird.
    I guess I should look in my engine bay more often... :bananadead:
  5. Oct 19, 2017 at 6:49 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I always replace the tensioner when i do my pulleys
  6. Oct 19, 2017 at 6:50 AM
    Bruce988jl
    Southern NH
    Summed up perfectly. Thankfully I have the skid plate - it caught it otherwise the civic that was behind me the whole ride into work would have had a rude awakening...
  7. Oct 19, 2017 at 6:50 AM
    Bruce988jl
    Southern NH
    The entire tensioner arm? Isn't it a bitch?
  8. Oct 19, 2017 at 6:55 AM
    tacobell007
    Drew
    Western MA
    I dont know about the v6 but the 4 cyl is cake. I've done the water pump and islets/tensioner multiple times
    Cativelense likes this.
  9. Oct 19, 2017 at 6:59 AM
    Noelie84
    Noel
    Wales, Maine
    Yeah, that's always a surprise.
    What's your plan for getting home? Crossing your fingers that the belt holds up, or are you going to pull the shaft and nut and hope there's enough tension that the belt doesn't slip off? Unless I'm mistaken that's just an idler, so theoretically you could make it home without it.
    Not that uncommon. Modern vehicles are sound insulated well enough that people don't really hear the pulleys going bad until the bearings are REALLY bad. I used to see a couple of missing idlers a month when I worked at a shop. People who don't open their hoods would come in because their belts were squealing, though. Or they'd come in on the hook because the belt had disappeared and their car had died.
  10. Oct 19, 2017 at 7:59 AM
    Bruce988jl
    Southern NH
    Well I drove at least 10 miles with it like that.. I'm about 6 miles from my shop so I might drive there and leave the truck there overnight until the parts come in tomorrow AM.
  11. Oct 19, 2017 at 8:22 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    I thought you were gonna say compromised and bang bang at waterfall that shits romantic lmfao
    Spare Parts and emelianenkov like this.
  12. Oct 19, 2017 at 8:23 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    I replaced my tensioner pulley, not the whole arm. It was holding tension just fine. Made a world of difference. It's so quiet now!
    On the 4.0, the tensioner assembly is a pain in the dick. Gotta remove the AC compressor.
    tacobell007[QUOTED] likes this.
  13. Oct 19, 2017 at 8:30 AM
    Bruce988jl
    Southern NH
    Yea.... I really hope my tensioner arm is good... lol
    emelianenkov[QUOTED] likes this.
  14. Oct 19, 2017 at 8:31 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    woulda been a good time lol :notsure:
    tacobell007 likes this.
  15. Oct 19, 2017 at 9:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It's a PITA on the 4.0 V6. As Alex stated, you have to remove the compressor and I'm pretty sure it's hard piped so you run the risk of breaking lines / fittings. I bought the whole assemble when I did them for my Tacoma also, took one look at that mess and only replaced the pulley. You have to remove the A/C compressor because it's bolted to the tensioner base. So the compressor has to be removed before you can get at the tensioner bolts. I'd just replace the pulley and be done with it.
    emelianenkov and Bruce988jl like this.
  16. Oct 19, 2017 at 9:59 AM
    tacobell007
    Drew
    Western MA
    Yea i can see that being a pain. The 4cyl you have to take the alternator out. Then when you zap yourself and burn the skin off it really blows. Ask me how I know (only happened once)
    emelianenkov likes this.
  17. Oct 19, 2017 at 10:04 AM
    Noelie84
    Noel
    Wales, Maine
    o_O
    Y U no disconnect battery?!
  18. Oct 19, 2017 at 10:12 AM
    tacobell007
    Drew
    Western MA
    Cause I'm lazy when it comes to having to tune my radio and get the sub working again. Only did it once cause i was rushing out if the 4 times I've pulled the alternator. Tuning and such takes me about an hour and I have never really had issues leaving the battrty connected
  19. Oct 19, 2017 at 10:15 AM
    Noelie84
    Noel
    Wales, Maine
    Fair enough. I always disconnect mine, but I'm old school. Plus I'm never in a huge rush because I've got another vehicle I can use instead.
    Jcyr likes this.
  20. Oct 19, 2017 at 10:15 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I wrote down all of my radio settings before disconnecting the battery when I did my last tune up. When my original battery was on it's way out, I swapped it with a new one while the truck was running just to avoid losing my radio settings though.
