New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Oct 21, 2017 at 9:27 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Thank you sir!
    DrFunker[QUOTED] likes this.
  2. Oct 21, 2017 at 9:35 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    :pccoffee:
    Got way too :drunk: yesterday...
    Cativelense likes this.
  3. Oct 21, 2017 at 9:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just ordered belts and pulleys for the Ferd. I thought it was going to be cheap until I realized there are 2 belts.... which means double the idlers and tensioners. Looks like I have to rip half the engine bay apart to get at them also, looks like next weekend will be fun. But at least they didn't bolt the A/C compressor to the tensioner like some manufacturers :stirthepot:
    Bruce988jl likes this.
  4. Oct 21, 2017 at 9:40 AM
    emelianenkov
    Alex
    NORTH POLE
    Yeah, enjoy your multi-belt setup, jackass lol
  5. Oct 21, 2017 at 9:45 AM
    Pugga
    Massachusetts
    oh, I will. Once I get the shrouds off, I'll have lots of room between the radiator and the front of the engine to work with. And everything bolts directly onto the front of the engine.
  6. Oct 21, 2017 at 9:49 AM
    emelianenkov
    Alex
    NORTH POLE
    Must be nice.... :rolleyes:
  7. Oct 21, 2017 at 9:59 AM
    emelianenkov
    Alex
    NORTH POLE
    Anyone have any experience with installing a remote starter on a manual vehicle?
    I'm thinking of adding one to my FJ because winters up here are cold.
    I was thinking of running a safety switch to my transfer case shifter, so the remote starter will only engage when the t-case is in neutral. That way it's kind of a fail-safe.
    uurx likes this.
  8. Oct 21, 2017 at 10:43 AM
    Pugga
    Massachusetts
    It's a trade off, they set the engine pretty far back in the engine bay. The front is really accessible but the back would be a bitch to work on. I'm guessing changing plugs won't be an easy task.
    emelianenkov[QUOTED] likes this.
  9. Oct 21, 2017 at 10:58 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    big trucks up by you run these things often, how far is your commute now?
    http://www.autoanything.com/winter-driving/fia-grille-covers
  10. Oct 21, 2017 at 12:23 PM
    dc welding
    dc welding Well-Known Member
    Dan
    Swansea Mass
    15 DCSB TRD Sport BRM / 2002 AC SR5
    Have to override the clutch start switch also. Some people just jump it out.
  11. Oct 21, 2017 at 12:51 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I don't have one but had been looking at them. They typically have a shut down sequence that you have to follow which is looking for ebrake being engaged and, I believe, the clutch switch not being activated prior to shut down to verify your in neutral.
  12. Oct 21, 2017 at 1:04 PM
    Pugga
    Massachusetts
    Those things are useless on a gas engine, at least in the temps seen in upstate NH. I'd consider a block heater as it would help during a cold start. Once it's running though, you don't need anything like that on a gasser.
  13. Oct 21, 2017 at 1:06 PM
    Pugga
    Massachusetts
    On an older manual, I had the ebrake freeze overnight. Ever since then, I always just kept my manual trucks in gear when parked. That was enough of a deterrent to look into remote start for me. It took a while to get it freed up, and it let go with a very loud thud. I can't believe nothing broke in the process.
    emelianenkov and vssman[QUOTED] like this.
  14. Oct 21, 2017 at 1:17 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I always keep my vehicles in gear as well. I will engage the e-brake, but that is something to think about given it does get cold around here. My driveway is on a bit of an incline so I'm reluctant to put the extra stress on the gearbox.
    Heated seats help a great deal to combat not having a remote start. I absolutely miss it, but I much prefer the 6MT. The baby ruins my easy out ability at home though. Since the wife is a teacher she'd typically get all the super snowy days off, often the night before any snow fell. I'd put her Jeep outside on the side yard and then park my truck in the garage. Since she'd not need to go out, I'd just power through the snow in the AM and then worry about cleaning the driveway when I got home. Unfortunately with the baby I cannot in good conscience trap her at the house, so I think from now on I'll just need to dig myself out and either let the truck warm up or rely on the seat heaters to keep my somewhat toasty while the truck warms up.
    emelianenkov likes this.
  15. Oct 21, 2017 at 1:31 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    And that's why I didn't have one installed. I'd only use it to warm up the truck when leaving work/clear the windshield on snowy days and that's the last place I want the ebrake to get stuck on!
  16. Oct 21, 2017 at 2:15 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Man this drive back sucks
  17. Oct 21, 2017 at 2:36 PM
    Cativelense
    Nuno
    CT
    How far into it are you?
  18. Oct 21, 2017 at 2:42 PM
    tacobell007
    Drew
    Western MA
    6 hours lol
  19. Oct 21, 2017 at 2:43 PM
    Cativelense
    Nuno
    CT
    LOL. Dang man. Still a ways to go then.
  20. Oct 21, 2017 at 2:50 PM
    tacobell007
    Drew
    Western MA
    Oh yea, its actually 7 hours. Still in VA
