New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Oct 22, 2017 at 3:31 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Commute is 15-20 minutes! :)
    Those things aren’t helpful up here really. As the others pointed out, they help on diesels the most. I tried putting cardboard on my 4Runner and it actually ran colder for some reason.
    I was thinking about jumping it too. Or installing a toggle switch to engage or disengage the override.
    I have done some research myself. I found one system that was similar. You had to push the remote button, depress the clutch and brake, then engage the parking brake, then take your foot off the clutch to ensure it’s in neutral, then turn the key off and open the door. It has a safety setup so if someone opens the door, you have to repeat the activation process (because you can’t ensure someone didn’t put it in gear accidentally). Seems too annoying. I always leave my truck in neutral.
    That’s awesome. Do you have any more info? Did you install yourself?
    My FJ doesn’t have a chipped key.
    My truck gets 11mpg, you think I care about it idling for 15 minutes? :rofl: I’d rather be comfortable than worry about gas at $2.30 a gallon up here.
    So you got foreskin for your Ferd?
    In all seriousness, that sounds cool. What can you adjust about the vehicle?
  2. Oct 22, 2017 at 3:35 PM
    emelianenkov
    Alex
    NORTH POLE
    You’ve gotta be able to save a baseline tune/map/file somehow. That way you can revert.
  3. Oct 22, 2017 at 3:42 PM
    emelianenkov
    Alex
    NORTH POLE
    Swapped rear coils on my FJ today. Took out my 2” icon rear coils and installed 3.5” progressive metal tech springs.
    Gotta put spacers on top of these springs too. I lost 1.5”!!!!
    With icons I was 25.5” from fender to center of hub.
    With metal tech I’m at 24”.
    My trusty little hammer (to adjust coilovers with a punch). Also, osha approved footwear always. :thumbsup:
    Also dropped the coilovers as much as I could to even out the ride height.
  4. Oct 22, 2017 at 3:55 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Ripping around a few dirt tracks today also playing with a 250$ camry :rofl::burnrubber::mudding:580BAF47-9161-4093-A8F5-CB24D19B1698.jpg 942B7AD7-9C9C-4FC0-A9F1-D2CAF3982B48.jpg 82C356B1-48DE-4181-9EEF-A7FC042ADB39.jpg
  5. Oct 22, 2017 at 4:33 PM
    Jcyr
    Jack
    North east
    Some more dirt fun honestly wish I was running a sway bar today because the dirt tracks were insanely fun and fast but I had a f-ton of sway :notsure:F0B50B08-CBC3-4116-8BC9-14A93F5F1F89.jpg
  6. Oct 22, 2017 at 4:44 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I can adjust pretty much anything. As long is has he hardware to physically get it done and the ECU can control that function, I can modify it. People have programmed in a fog light anytime mod, disable chimes and speed limiters, one guy messed with the HVAC controls and had his vents blowing fog the air was so cold.
    That's the beauty of it. I saved a base line, which is the as built file. With this program, I can reload the asbuilt and erase any trace that the truck was ever tuned. I don't intend to mess with my truck, frankly it scares me. I'm sure if you change the wrong line of code, it could be catastrophic to the truck. I'll stick to lighting and the tunes I purchased through reputable tuning shops. If I had downloaded this a long time ago, I could have activated my own remote start module and trailer brake controller rather than requiring a dealer to do it. Then, rewrite the asbuilt to make it look like it came that way from the factory.
    BTW, 11 MPG from your FJ?!?! WTH are you doing to that thing??? I can almost get that dragging a 5k lb sail behind my V8.
    emelianenkov[QUOTED] likes this.
  7. Oct 22, 2017 at 5:24 PM
    dc welding
    dc welding Well-Known Member
    Dan
    Swansea Mass
    15 DCSB TRD Sport BRM / 2002 AC SR5
    Wow, that corolla looks so familiar. My next door neighbor ( his son ) I think, picked up a cheap toyota to play with on a dirt track. It looks like his son driving. I'm pretty sure it's green too
    Jcyr[QUOTED] likes this.
  8. Oct 22, 2017 at 5:25 PM
    Jcyr
    Jack
    North east
    That is your neighbor and his son Grady
  9. Oct 22, 2017 at 5:26 PM
    Jcyr
    Jack
    North east
    It’s his Toyota if he doesn’t blow it up by thanksgiving I’ll be shocked kids a hot shit
  10. Oct 22, 2017 at 5:26 PM
    dc welding
    Dan
    Swansea Mass
    Holy shit, I thought so. Cool. Looks like he's having a ball.
    tacobell007 likes this.
  11. Oct 22, 2017 at 5:27 PM
    Jcyr
    Jack
    North east
    He honestly ripped it up kids a great little driver
    dc welding[QUOTED] likes this.
  12. Oct 22, 2017 at 5:29 PM
    dc welding
    Dan
    Swansea Mass
    Kids been on a dirt bike since he was like 3. If your ever there and you see my garage open usually means I'm out there. Feel free to stop in
    uurx likes this.
  13. Oct 22, 2017 at 5:37 PM
    Jcyr
    Jack
    North east
    Which house is yours I’m that way a bit the halls are good friends
  14. Oct 22, 2017 at 5:44 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Do Fords have the "checksum" problem that some tuned vehicles have in that the ECU keeps count of how many times it's been flashed? Back in my Subaru days there was always a back and forth of whether or not those cars had a checksum that a tech's computer could see. I forget what the ultimate belief was, but it was interesting to debate.
    emelianenkov likes this.
  15. Oct 22, 2017 at 5:47 PM
    dc welding
    Dan
    Swansea Mass
    Right next door on the driveway side. Gray house with a gray garage.
  16. Oct 22, 2017 at 6:05 PM
    Pugga
    Massachusetts
    They do, but if I'm reading correctly, if you recreate the asbuilt file and upload it, you can erase that bit. Right now, you can see how many times my truck has been tuned, I'm still researching but it seems like I can return it to stock, upload an asbuilt file and erase any alterations that have ever been made to the truck. At this point, I'm not sure why I would ever need to do that. It's tuned, out of warranty and running fine. When I trade it, I'll return it to stock and sell the tuner, at that time, I don't care if the next tech to look at it can tell it was tuned in the past but I can see that being a useful feature to someone still under warranty.
    This is still all new to me, I'm just starting to research it.
  17. Oct 22, 2017 at 6:12 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    With the warranty gone it's a non-issue. Where I've seen it come into play is when people flash cars that still are under warranty and try to flash back to stock prior to going in for service.
  18. Oct 23, 2017 at 2:47 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Happy Monday. Hope everyone had a great weekend.
    Back to the grind.
    DrFunker likes this.
  19. Oct 23, 2017 at 3:04 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning boys and gal
    tacobell007 and Cativelense like this.
  20. Oct 23, 2017 at 4:10 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    Morning. The fog at the pats game last night was insane!
