New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Oct 23, 2017 at 6:23 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    I bet you smell like a whales vagina
    emelianenkov and BadDNA[QUOTED] like this.
  2. Oct 23, 2017 at 6:24 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    My mechanics coveralls took two trips through the laundry. I think I got the smell out.
  3. Oct 23, 2017 at 6:25 AM
    Jcyr
    Jack
    North east
    I wear tyvek throwaways for days like that
    tacobell007 and BadDNA[QUOTED] like this.
  4. Oct 23, 2017 at 6:26 AM
    dc welding
    dc welding Well-Known Member
    Dan
    Swansea Mass
    15 DCSB TRD Sport BRM / 2002 AC SR5
    We're actually going up Friday afternoon. I got a hotel for the night. But thanks for asking. I'm assuming you going up Saturday morning?
  5. Oct 23, 2017 at 6:27 AM
    dc welding
    Dan
    Swansea Mass
    You're probably going to be busier than a one legged man in an ass kicking contest. :annoyed:
    Cativelense[QUOTED] likes this.
  6. Oct 23, 2017 at 6:28 AM
    Jcyr
    Jack
    North east
    Yeah Saturday morning is likely the plan
  7. Oct 23, 2017 at 6:42 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    :rofl::rofl::rofl:
    52 total inbound emails so far...
    Jcyr likes this.
  8. Oct 23, 2017 at 6:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Make them throw in the trailer brake controller. It doesn't look like it has it and it's not included in the tow package for some stupid reason. Since you tow, you're going to want it. For bargaining purposes, you can buy the hardware yourself for under $200 and it takes them literally about 30 minutes to install and 5 minutes to active it. It shouldn't be a big deal for them at all and, honestly, the truck should come with it to begin with. Also, it says it has the 3:31 and 3:55 axle ratio in the description. Unless it has the 10 speed gear box, you'll want to make sure it doesn't have the 3:31 gears. That's too tall for towing if you have the 6 speed gear box, it's not an issue if it has the 10 speed.
    Supposedly, they all have the start/stop now, even the 5.0. I'd deactivate it, that's just a stupid feature and a really good way to kill a starter in my opinion. I'd rather have the engine warm up, stay warm and run like it's supposed to.
    I just filled up the 36 gallon tank yesterday from 1/4 full, and yeah, ouch.
    Honestly, I wonder if the diesel option will kill one of the ecoboost engines off (I'd guess the 3.5L). I don't think they'll get rid of the V8, there's no way they'll be the only full size truck without a V8 option. Everyone says the ecoboost is the engine to get for towing. Tow tests with the Land Rover 3L diesel (the same engine the F150 is rumored to get) are going very well. It seems to be a very capable puller and gets great MPGs doing it. I'm really curious to see what that engine is all about once it's finally released.
    ABA180 likes this.
  9. Oct 23, 2017 at 6:51 AM
    BadDNA
    Eammon
    Cabot, VT
    If I wanted to weld these on (SOS bolt on sliders), rather than have them as bolt-on, would I just need to have the frame plates cut down into smaller pads at the end of each leg and have somebody weld them on?
  10. Oct 23, 2017 at 7:03 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    If they can make it work, I'd be all about a diesel for my next rig. But honestly, my next truck purchase will likely be a 3/4 ton from out of state to put a V-plow on, so I'll probably go diesel for that.
  11. Oct 23, 2017 at 7:13 AM
    dc welding
    Dan
    Swansea Mass
    Tuesday after 5:00 or so I'll be out in the garage putting a power steering pump in my nephew's @03limitedyota 1st gen. And maybe his cb time permitting. If you're in the area and want to stop in feel free.
    Jcyr[QUOTED] likes this.
  12. Oct 23, 2017 at 7:13 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    That's pretty cool man! How long til the Russians can hack your Ferd? :spy: Asking for a friend....
    And YEEEEEEEP!!! 11mpg. I can watch the needle move as I drive. Some has to do with the tune I have on it, some has to do with the computer readings being off from not having cats, and some has to do with the up-stream sensors being bad (at least one of them is).
    I need to get this crap squared away.
    Subaru has CID numbers, going back years and years. Essentially, your computer software has a specific version number, which Subaru keeps track of. If you have any recalls or bulletin ECU reprogramming done, that number is submitted to Subaru.
    They also have a counter for mileage and key cycles. If we get a vehicle in with a rod knock, 45k on the clock, but only 4 key cycles and 20 miles, that's our red flag. On the other hand, if you have a severely dead battery, your key cycle/mileage gets reset in the ECU. Double edged sword.
    With turbo vehicles, Subaru always asks us to pull the CID. We don't know what the "good" number is, they just tell us yes it's been tuned or if it's good.
    That's the problem with the COBB tuners and stuff. Dyno tuning is ALWAYS the best way to go. Going with an off the shelf map, especially when you are talking about that much power, is stupid. You want to monitor all the conditions and hopefully see any issues before they cause damage.
  13. Oct 23, 2017 at 7:22 AM
    emelianenkov
    Alex
    NORTH POLE
    My STI requires 91/93 :notsure:
    I thought all turbo motors required that to prevent detonation... Makes sense. More octane, less boom boom.
    I love diesel in all shapes and sizes. I was really looking forward to a Tundra with that new 5.0 Cummins motor, but that still hasn't happened yet :(
    If I was to get a full size diesel, Ford would have my vote. I've driven a few of the 2017 F350 6.7's and I'm in love... :drool:
  14. Oct 23, 2017 at 7:22 AM
    Noelie84
    Noel
    Wales, Maine
    Alright, gym rats, who wants to come get a workout and finish this for me?
    I got this delivered on Saturday morning...
    And did this yesterday:
    Cut it into 4 foot cordwood lengths and moved them down into the lower lot where I've got my log yard.
    Still have this one to go, though. And hunting season starts on Saturday...And I'm stiff today. At a rough estimate I probably moved 8 tons of the 20 ton load yesterday.
  15. Oct 23, 2017 at 7:25 AM
    emelianenkov
    Alex
    NORTH POLE
    4' lengths? That's like the height of you @Noelie84. Must be hard to lug that around.
    Pugga likes this.
  16. Oct 23, 2017 at 7:27 AM
    Cativelense
    Nuno
    CT
    :rofl:
    :ohsnap:
    emelianenkov[QUOTED] likes this.
  17. Oct 23, 2017 at 7:31 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    :ohsnap:
  18. Oct 23, 2017 at 7:32 AM
    Noelie84
    Noel
    Wales, Maine
    o_O
    "My but your arse is grimy and black", said the short-ass kettle to the slightly taller pot...
    Edit- I will admit, though, it would have been easier if I was 6'4 and built like Chris Evans.
    emelianenkov[QUOTED] and Pugga like this.
  19. Oct 23, 2017 at 7:38 AM
    Noelie84
    Noel
    Wales, Maine
    My 2.7 is tuned from the factory for just regular 87 octane.
  20. Oct 23, 2017 at 7:39 AM
    Pugga
    Massachusetts
    I'd be lying if I said I haven't priced out a 2500 Ram with the Cummins and stick shift... :anonymous: I love that Cummins engine, it's just a shame that it's wrapped in a Dodge wrapper. Half tons are getting so expensive, I'm fairly confident that my next truck with be a 3/4 ton. If I'm going to pay that much, I'm getting some additional capacity out of it.
    The Ford ecoboost engines are all designed to be run on 87. None of them require 93. The SVT vehicles may be the exception to that, but I know none of the more base models require anything higher than 87.
    Have you seen how well the 5.0 Cummins is doing in the Titan? I started looking into them and it seems to have some issues. Cold starts are a nightmare and there are some other gremlins lurking in that engine.
    Check out the 3.0 Lion diesel in the Land Rover. That's likely the engine that the 2018 F150 will get.
