New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Nov 1, 2017 at 5:51 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    If you just want a trail beater, does it have to be street legal?
  2. Nov 1, 2017 at 5:58 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Depends on what you want perfect body lines=big money
    Close enough that requires some modifications can be way cheaper than steel replacements and you can add high quality fiberx cloth with a high flex epoxy lam on the insides of the panel that will add a ton of flexibility and crack resistance. For a while I was making surfboards with poly decks and epoxy bottoms. The boards would bend like crazy before any damage. There’s just so much potential in the composite industry. And if wasn’t almost impossible to mass produce it would be used in place of steel for everything structural on a car
  3. Nov 1, 2017 at 6:20 PM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    He's broken so many blinds....
    emelianenkov and Jcyr[QUOTED] like this.
  4. Nov 1, 2017 at 6:22 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Maybe they're just heading in for warmth? If you house is balloon framed, the attic could just be the first spot the can get out of the walls which is why there aren't droppings in the living space.
  5. Nov 1, 2017 at 6:26 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    No, but I will be driving it down the street from my house so nothing too noticeable as far as "hell that doesn't belong on the road" honestly I'd love a cheap rav4
  6. Nov 1, 2017 at 6:30 PM
    tacobell007
    Drew
    Western MA
    Well then it wouldn't be a bad deal then, fix the frame up some with your welding you are learning, and a few bucks to get it running
  7. Nov 1, 2017 at 6:40 PM
    Pugga
    Massachusetts
    That thing looks like it's been in salt water though. Sooo much rust! Maintenance and working on it in general would be a bitch, everything is just caked with rust. As someone else said, even the throttle body is rusted. You can only fix so much, that thing looks like it would need a lot of replacement parts that would cost some decent money. I think it'd end up being a money pit.
  8. Nov 1, 2017 at 6:41 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Anyone else doing the Fenway Spartan this weekend?
  9. Nov 1, 2017 at 6:41 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Welp swapped out the bad wheel bearing with the used spare I had. Did it in 30 minutes too with my new extra long 17mm wrench, deep 6pt impact sockets and my electric impact gun. Rides much quieter and smoother. Minimal vibes and I think the vibe I have at about 66mph only under accel might be the driveshaft. Going to keep the new driveshaft I have and take my old one out, rebuild it and box it for a trail spare.
    Ready to head to NJ Friday to grab my new to me tepui from @CaliDevilDoc!
  10. Nov 1, 2017 at 6:51 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Nice. How was getting the axle nut off? That's the only thing I had trouble with wheni swapped mine onto a non bent spindle
  11. Nov 1, 2017 at 6:53 PM
    tacobell007
    Drew
    Western MA
    Those motors always look corroded up here, not nearly as bad as some ive seen or worked on. I'm saying to get it driving and going down trails would not be ridiculous money. If you wanted to make it into a minty fresh daily driver, then sure it would cost you an arm and a leg
  12. Nov 1, 2017 at 7:04 PM
    tacobell007
    Drew
    Western MA
    Thankfully, I think I got the heat fixed in my blue truck
  13. Nov 2, 2017 at 2:47 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Good morning everyone. Happy Friday eve.
    Still no internet since the storm... Fucking frontier sucks ass. Made an appointment on Monday, for Wednesday since that was the earliest they could come out, to put the phone line back up. Not fixed. No call. Nothing. Take it up with them and they say they called my wife since she's the one that made the appointment and gave them her info. She has no missed calls from anyone. What the fuck! They really suck service wise. Ever since AT&T left and handed it over to them it's been nothing but problems. I need to find a different provider. They told me I have to reschedule... At that rate I'll be without service for over a week by the time they come out, IF they even come out and don't do the same bullshit they did yesterday.
    I'm so fucking pissed.
  14. Nov 2, 2017 at 2:53 AM
    DrFunker
    DrFunker Well-Known Member
    Good luck Nuno. Have always had issues with my Verizon service too. It is like they know that they are making enough money and poopoo the customer service. Very frustrating. I feel your pain.
  15. Nov 2, 2017 at 2:55 AM
    tacobell007
    Drew
    Western MA
    Thankfully Westfield G&E is offering a bundle deal now under Whip City Fiber. Probablybwill habe better customer service than Comcast we Have now
  16. Nov 2, 2017 at 2:57 AM
    DrFunker
    Nice.
    I always had great service from WG&E, when I was a customer.
    Lucky duck! Fiber. :( Will never see fiber here. Not enough $ in the county.
    tacobell007[QUOTED] likes this.
  17. Nov 2, 2017 at 3:01 AM
    Cativelense
    Nuno
    CT
    Same here... I don't think we'll ever get fiber... Not at the rate frontier is going/doing.
    And to make it even worse, there is a frontier "service hub" in Danbury, which is the next town over... You'd think I'd be able to get this fixed quicker, but no... Never have in all of the issues I've had since they took over.
  18. Nov 2, 2017 at 3:04 AM
    DrFunker
    :annoyed: frustrating!
  19. Nov 2, 2017 at 3:57 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
  20. Nov 2, 2017 at 4:19 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Normal platform frame.
    I'm really convinced they get up from the garage. It'd be very easy to get in there. The garage is as tall as the roof of the house, then they can easily hop over to the house attic from there.
    It's also the only place I may not notice mouse activity right away. Lots of places for them to hide there. I found a large mouse nest in the garage rafters when I bought the house, too, so historically they have been there.
