New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Nov 14, 2017 at 6:57 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I think they look terrible aesthetically both inside and out. The only style I've seen that I like is the cassette style I have in my office at work as it looks like a big ceiling vent, but at $5,000 it does nothing for me.
    Cativelense likes this.
  2. Nov 14, 2017 at 7:07 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Fair enough. My parents got one put in by the wood stove. They got it with some massive rebates (I think like $1,500 worth) but they got it more for cooling the house
  3. Nov 14, 2017 at 7:27 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Order some new suspension components from @Wheeler's Off-Road Inc today! Getting antsy about suspension upgrades. Good bye spacer lift :yes:
  4. Nov 14, 2017 at 7:45 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Spacers and drop brackets are the enemy.
  5. Nov 14, 2017 at 7:49 PM
    Blais03
    Nick
    Easthampton MA
    Honestly nothing wrong with a spacer lift. It does it’s job. I just need to replace shocks so I’m gonna do coils and such now too
  6. Nov 14, 2017 at 7:52 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Damn... do you have a 5.7 stuffed into that thing?
    For a small room, they make small oil radiators that use an electric heater element. It's just a stand alone radiator, looks like a forced hot water one and will heat up and stay warm like a standard radiator also.
  7. Nov 14, 2017 at 10:09 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    Are you my neighbor? they have a dog that bays all day long while they are gone. Stops when she hears their car coming home. I'm sure they think their dog is fine alone too.
    I finally gave up & gave away my plants. I'm not home enough for plants.
    I married my tacoma likes this.
  8. Nov 14, 2017 at 10:17 PM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    Sound about right, not knowing the quality of the unit.
    Generally you can save some money by draining the old heater before the plumber gets there - it could save you/him/her an hour of labor shutting it down, hooking up a hose, draining it most all out, ....
  9. Nov 14, 2017 at 10:25 PM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    I have forced air & keep the T-stat @ 63F year round.
    An important question not asked is construction materials. In my case the walls are lath & plaster with no insulation, so it's actually cheaper to consistently run the heat at 1 temp to keep the walls heated. Assume your ranch has drywall & insulation which would allow for adjusting the temp w/ occupancy & sleep patterns.
    My furnace runs off city gas & looks to be of about 1930 - 1950 vintage. Maybe not so efficient?
    Cativelense[QUOTED] and ABA180 like this.
  10. Nov 14, 2017 at 10:38 PM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    I think the common earlier radiant heat was done with electric grids in/under the floor. Modern interpretation is hot water in a pex like hose running under the floors. Not so expensive if the basement ceiling is open, costs more if they need to make holes to get the system up. There are some systems you can lay into the flooring when tiling a floor so the tiles will be warm under foot (think bathroom & kitchens).
    Cativelense[QUOTED] likes this.
  11. Nov 14, 2017 at 10:42 PM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    Only a cast iron radiator pre-heats your coat before you go out & dries your hat & mittens when you come in. I'll take radiators any day!
    bucktales likes this.
  12. Nov 14, 2017 at 10:47 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Same way the homes I mentioned were.
    A neighbor at my parents' old house had a similar system as the flooring you mentioned for the driveway.
  13. Nov 15, 2017 at 3:57 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Not with 325,000 on the od ...... next truck maybe
  14. Nov 15, 2017 at 4:00 AM
    eborgie
    eborgie No Yotas Here
    Erik
    Bellingham, MA
    2023 Bronco Sasquatch
    Nope, it has the 6.4
  15. Nov 15, 2017 at 4:13 AM
    smcgill
    Sean
    Morning :pccoffee: I thinks it's Wednesday
  16. Nov 15, 2017 at 4:18 AM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    I'm not your neighbor!....my dogs stop baying eventually. I think..
    Spare Parts and tacobell007 like this.
  17. Nov 15, 2017 at 4:18 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Lol. Morning, first cup of coffee down.
    mach1man001[OP] likes this.
  18. Nov 15, 2017 at 4:22 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Think I'll stay home today....jk, I'm all out of time after all these doctor visits relating to the alien living inside my wife
    MikeyMcFly, Spare Parts and smcgill like this.
  19. Nov 15, 2017 at 4:23 AM
    Pugga
    Massachusetts
    Unless you have a concrete slab, that type of radiant heat in the floor is only but so effective. If you do a concrete placement and put the lines in the concrete, it will heat up the entire mass and make the house feel warm and cozy!
    Only 1? You still starting early?
  20. Nov 15, 2017 at 4:32 AM
    BostonBilly
    Easton
    Yeah in the city for 6am.
