New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 16, 2012 at 7:41 AM
    #1181
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Did you wire to the battery or to a fuse ?
  2. May 16, 2012 at 7:43 AM
    #1182
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Yea i got sick of looking at all the rust buckets around here. I just figured I'd look where cars dont really rust out so i looked around Florida and found that. It is very nice but way too much $.
  3. May 16, 2012 at 7:48 AM
    #1183
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    IV had this tire balancing issue scince i got my new 33's. I thought it was a bent rim because i could see the driver rear wobbling at highway speed. I bought a new rim and just had it mounted... Samething. awful harmonic vibe at 50mph. I just did a good once over on the rear axle nothing i can see loose bent missing.:violent: I cant seem to figure this out. I hope my rear axle isnt bent.
  4. May 16, 2012 at 8:00 AM
    #1184
    johnnym
    john
    NH
    Wheel bearing :notsure:
  5. May 16, 2012 at 8:05 AM
    #1185
    eborgie
    eborgie No Yotas Here
    Erik
    Bellingham, MA
    2023 Bronco Sasquatch
    I tapped into the power for my radio accesories. There should be a small fuse on the power line that came with the radio.
    Check out some of the stuff from Maine. They have some cheap built rigs.
    I hate to say but sounds like a bent axle.
  6. May 16, 2012 at 8:26 AM
    #1186
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sadly i dont think so. I replaced that bearing about a year ago.
    I know i hope that is not the case. If it is i guess im just gunna have to live with a vibration lol.
  7. May 16, 2012 at 8:29 AM
    #1187
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Full lock going forward or semi-tight turns when reversing. It's done it a couple times but the first 2 times I thought it was just something loose in the cab (in the rear storage compartments). I secured everything and it did it again and I can replicate it so I know there's something moving that shoudn't. I'll check that everything is tight tonight and go from there.
  8. May 16, 2012 at 8:38 AM
    #1188
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Maybe just a bad tire. You should rotate the tires and see if the problem moves with it or not. Then you can start to figure out wheel/tire combo or axle.
  9. May 16, 2012 at 8:52 AM
    #1189
    Pugga
    Massachusetts
    Rotate the tires front to back and see if the problem stays on that axle or moves to the front. If it stays, you'll know it's not the rim, if it moves, you'll know it's the rim or the tire.
    Shit, Rob beat me to it...
  10. May 16, 2012 at 8:54 AM
    #1190
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Great minds thinking alike.
  11. May 16, 2012 at 8:55 AM
    #1191
    Pugga
    Massachusetts
    :cheers:
  12. May 16, 2012 at 9:21 AM
    #1192
    eborgie
    Erik
    Bellingham, MA
    He said he just put a new rim on and had the same problem. Did you have the rim and tire balanced or just the tire mounted to it?
  13. May 16, 2012 at 9:25 AM
    #1193
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Iv swapped tires in and out yada yada. The rim was kinda my last hope. Im probably going to put my old 31's on to see what happens. The Xterrains im running are pretty odd shaped and dont ride great to begin with. Maybe thats my problem but im kinda doubting it at the moment.
    Edit: iv gotten them balanced and double balanced lol. If the 31's solve my problem balancing powder might be the ticket.
  14. May 16, 2012 at 9:46 AM
    #1194
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Yeah that's it. Check out mototrials.us for more info. I'll be there for the weekend. I have a lot of friends that are competing. One is #1 expert from last year and the youth national #1.
  15. May 16, 2012 at 10:12 AM
    #1195
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
  16. May 16, 2012 at 10:23 AM
    #1196
    eborgie
    Erik
    Bellingham, MA
  17. May 16, 2012 at 10:31 AM
    #1197
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    I switched from 33x10s on stock rims to 33x12.5s cragar soft 8 steel rims.
  18. May 16, 2012 at 10:38 AM
    #1198
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I have a set of factory alloys for an '04 for sale if you want them. ;)
  19. May 17, 2012 at 4:59 AM
    #1199
    aidenhardcore
    aidenhardcore Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    I know you just replaced the lower control arms but it seems like thats it. Maybe they didnt tighen the bolt. That is what town fair didnt do it and thats why i had the noise. Lube it up and tighen it and you should be good to go. Thats what the shop in cape cod did and no sound now.
  20. May 17, 2012 at 5:19 AM
    #1200
    Pugga
    Massachusetts
    I did that and still making noise. I couldn't budge the LCA bolts so the shop did tighten them up. I also rechecked any other bolt that I touched during the process (spindle connection, shock bolt and all 4 LCA bolts). I'll mess with it some more tonight when I get home from work. It was nice this morning so I just left the truck and took the motorcycle in to work. :D
