New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Dec 10, 2017 at 8:48 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    I've got the General altimax on my 92 2wd and they have been great. I'd buy them again for sure.
  2. Dec 10, 2017 at 8:56 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Anything "small" so far that you found, that you're psyched about? Or just a lot of junk?
  3. Dec 10, 2017 at 8:57 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    No problem. I should clarify that all of mine were studded also. The Firestones are better for deep snow, they have much more aggressive tread.
  4. Dec 10, 2017 at 9:03 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Yup! I found a box of underbody rock light stuff, but each little box was just like a rubber bracket and empty, then the last 4 boxes actually had them in there so those will be installed at some point, as well as keeping some fluids, some other random parts, and a completely new set of aftermarket tail lights. there is soo damn much, the only thing i am not looking forward too is having to take pictures of it all, but there will be stuff listed for free that I just wont take pic off probably. There's is just way more here than there should have been.
    Cativelense[QUOTED] likes this.
  5. Dec 10, 2017 at 9:10 AM
    Hunter.415
    Hunter.415 Well-Known Member
    Pete
    Western mass
    2012 Tacoma short bed 4x4
    Cooper t/a 3
    Looking to add some weight in the bed, just wondering what some of you are using. I'm thinking of either flat cement blocks or tube sand.
  6. Dec 10, 2017 at 9:15 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    In 35 years of driving 4WD pickups, I've never added weight to the bed for traction. If you do, go with sand tubes or similar. Concrete blocks would hurt in an accident.
  7. Dec 10, 2017 at 9:16 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Old cast iron radiator FTW just strap it down.
  8. Dec 10, 2017 at 9:25 AM
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    You must drive on pavement, it's still hunting season here and have to park where it's not plowed. Plus old wood road are not plowed.
  9. Dec 10, 2017 at 9:27 AM
    Pugga
    Massachusetts
    I like tube sand because you can use the sand in a pinch if needed. In the past, I've used steel tractor weights also. Now, the cap gives me plenty of weight. Whatever you use, make sure you secure it, you don't want it to become a projectile in the event of an accident.
  10. Dec 10, 2017 at 9:27 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Very true! On pavement only.
  11. Dec 10, 2017 at 9:27 AM
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    Those are hard to find. But also take up to much space.
  12. Dec 10, 2017 at 9:28 AM
    Pugga
    Massachusetts
    For unplowed roads, I wouldn't want the extra weight. I'd rather be empty and aired down.
  13. Dec 10, 2017 at 9:34 AM
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    I have have had trucks before and with snow off road driving. Weight in the bed make a big difference
  14. Dec 10, 2017 at 9:38 AM
    jpereira2
    Massachusetts
    how good are polyurethane bushings? wondering if i should keep some more parts lol
  15. Dec 10, 2017 at 9:43 AM
    Pugga
    Massachusetts
    If you don't mind swapping them in, I'd do it.
    jpereira2[QUOTED] likes this.
  16. Dec 10, 2017 at 9:46 AM
    jpereira2
    Massachusetts
    Well I have all the text laid out for this insane listing, now to just get all the damn pictures lol
  17. Dec 10, 2017 at 9:57 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I have a horse mat from tractor supply in my bed. Bought it more to keep things from sliding around the bed, but it's also not light either.
    Bruce988jl and Pugga like this.
  18. Dec 10, 2017 at 10:18 AM
    Pugga
    Massachusetts
    I have one of those, they are awesome! Damn thing is like 3/4" thick.
  19. Dec 10, 2017 at 10:23 AM
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    I have the small horse mats, works great for keeping stuff from sliding. I picked up 2 tube sand bags at Home Depot.I can remove these easy when I don't need them and store them in the shed.
  20. Dec 10, 2017 at 10:26 AM
    replica9000
    2019 T4R ORP
    Think it weighs 100lbs. When I bought it, I was going to put it in the back by myself. A bit too heavy and awkward for that.
