New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Dec 13, 2017 at 12:50 PM
    TacoTut91
    TacoTut91 Active Member
    2012 Tacoma TRD Spruce
    None....yet.
    Only wen I am turning slow like pulling in a parking spot. When I break sometimes my truck vibrates depending on how hard I break.
  2. Dec 13, 2017 at 12:50 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Are your CV boots spewing grease?
  3. Dec 13, 2017 at 12:50 PM
    TacoTut91
    None....yet.
    Goffstown! And yes. only in reverse.
    BananaPeelOut[QUOTED] likes this.
  4. Dec 13, 2017 at 12:51 PM
    TacoTut91
    None....yet.
    I haven't looked but I can tomorrow.
  5. Dec 13, 2017 at 12:53 PM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    That's what she said
  6. Dec 13, 2017 at 12:55 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    woot woot!
  7. Dec 13, 2017 at 12:56 PM
    jpereira2
    Massachusetts
    That sounds yummy! I do like rum n coke! It's just about all i had when i went to puerto rico
  8. Dec 13, 2017 at 12:57 PM
    Noelie84
    Noel
    Wales, Maine
    The 'only in reverse' is unusual, but CV's that are going bad are usually what will make a clunking/clicking noise during a tight corner. The boots fail, they spray their grease out, and then the joints go bad. The worse they get, they more noise they make.
    Edit- If the CV boots look good, my other guess without actually seeing your truck would be that the sway bar bushings are shot and they're letting the bar shift.
  9. Dec 13, 2017 at 1:36 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    It's awesome down there. Where you thinking if heading to?
    Lol yes. Or Chick-fil-A at every corner. Wanna grab me a case of Cheerwine and some grits while you're down? Lol
    DoubleRGirl[QUOTED] likes this.
  10. Dec 13, 2017 at 1:36 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Hi!
    How long have you owned the truck? When you drive 20MPH and slam the wheel back and forth does it click? When did it get inspected?
    I would suspect
    tie rods(would have been inspected)
    Ujoints (would not have been inspected)
    Wheel bearing (might be inspected)
    Sway Bar links
    Loose Lug nuts but you would hear that anywhere
    And As others said a CV.
    I would start by putting the truck in neutral and wiggling both Dshafts back and forth. Any clunking and slop is bad. Then lift the front two tires off the ground. Wiggle each wheel side to side and up and down. Wheel should be tight on hub and the tie rods should have minimal play no clunking.
    Cv shaft is the hardest to diagnose as you can’t really feel the play in it. What you can do to determine the side is have someone drive your truck in the manner to make it clunk while you walk and listen/ put your hand on the fender feel for the shudder. Good luck.
  11. Dec 13, 2017 at 1:57 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    X2 but also did you truck get an alignment recently?
  12. Dec 13, 2017 at 1:58 PM
    DoubleRGirl
    Rebecca
    Rhode Island
    I’ll see what I can do
    tacobell007[QUOTED] likes this.
  13. Dec 13, 2017 at 2:18 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    I would probably look to have some good eats in Charlotte and Charleston, and play rounds of golf in Myrtle Beach. Where do you recommend going to?
  14. Dec 13, 2017 at 3:45 PM
    tacobell007
    Drew
    Western MA
    Thank you!
    I hangout in the Charleston area. Its very nice and lots of things to do and places to eat. If you are in the area there go to Sewee Outpost in Awendaw, great country store, my buddy use to work there. If you want to play golf look at Mt. Pleasant and Hilton Head Island both in SC
    MadRiverTaco[QUOTED] likes this.
  15. Dec 13, 2017 at 4:38 PM
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    just dropped truck off to get 20% tint. second guessing myself and might call to get 35 and play the safe route. what do you guys think? just wondering with the new inspection laws
  16. Dec 13, 2017 at 4:47 PM
    loki32687
    loki32687 Matt
    Peabody, Ma
    17 TRD Sport Inferno
    I'd like to get my truck ceramic coated but holy shit is it expensive.
  17. Dec 13, 2017 at 4:52 PM
    jpereira2
    Massachusetts
    35, good luck otherwise
    tacoburrito[QUOTED] likes this.
  18. Dec 13, 2017 at 4:54 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    A guy a work said it cost him a little over $400, but lasts for 2 years or more.
  19. Dec 13, 2017 at 5:01 PM
    jpereira2
    Massachusetts
    I had bantam cider, adult apple juice :D
    mach1man001[OP] likes this.
  20. Dec 13, 2017 at 5:05 PM
    tacobell007
    Drew
    Western MA
    Go 35%. And even that is considered illegal. 35% is hard enough to back up at night without my 25w LED bulbs and 2 flush mounts
