New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 8, 2018 at 8:18 AM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    I think they have to cut it to keep the pumps from gelling up... I haven't bought diesel from the pump in a while, we have a tank that we get a drop shipment when we run low, in the winter we'll cut it with some kerosene
  2. Jan 8, 2018 at 8:20 AM
    jztacoma
    Upstate NY
    Semi Stockish
    switching the propane would work out if your boiler is up for replacement. but if you still have a lot of life left on it then it makes more sense to stick to the oil burner. out by us propane is a good amount cheaper but it'll take few years to offset the $5k or so to switch over
  3. Jan 8, 2018 at 8:21 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Oil heat is all I have ever had, I don't mind it.
  4. Jan 8, 2018 at 8:23 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Whenever I've looked here, the price is similar.
    I remember looking at a house that was almost brand new and had radiant propane heat. The realtor said their propane was "only" costing them $2500/year. Seemed insane to me--something had to be wrong there given I'll be under $1200 to heat a house from the 50s with the same square footage and oil this year.
  5. Jan 8, 2018 at 8:24 AM
    jztacoma
    Upstate NY
    Semi Stockish
    I like oil cause if you run into a situation where you run out, just pop over and pick up 10 gallons of diesel. Also if you have a leak its a tad more noticeable and easier to find then propane/gas.
    But the Engineer in me likes natural gas/propane cause its cheaper and cleaner burning.. also city natural gas will always be there.. everything has its pluses and minuses
    DoubleRGirl and morri89 like this.
  6. Jan 8, 2018 at 8:26 AM
    jztacoma
    Upstate NY
    Semi Stockish
    yeah that is odd... I think here propane is 25% less I want to say. Radiant heat is awesome though like I would always add it if i could. especially in garages. It does take a bit more to heat up though, and if they let the slab get to cold then it will really cycle that boiler. Radiant floors like to stay at a constant temp. Or they just undersized the boiler and its always running..
  7. Jan 8, 2018 at 8:37 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    No worries; I spent a good part of the day on the tractor anyway, stacking snowbanks up and back. Wanted to get them up and out of the way before they get rained on later this week, because once it gets cold again they're going to be there for the duration.
    smcgill likes this.
  8. Jan 8, 2018 at 8:41 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Lol! My own version of cement gray!
  9. Jan 8, 2018 at 9:34 AM
    jztacoma
    Upstate NY
    Semi Stockish
  10. Jan 8, 2018 at 9:42 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've been following the release of this for a while. They first started talking about this last summer and I've been eagerly awaiting the release (it's just in time for me to start looking for my next truck). This bit is disappointing though "Retail customers will be able to order the engine on Lariat, King Ranch, and Platinum trim levels on SuperCrew cabs with 5.5- or 6.5-foot beds or on Lariat SuperCabs with a 6.5- or 8.0-foot bed."
    That would take me out of the running, that'd put me at a $60k truck by the time you get a Lariat, tow package and a $4k adder for the oil burner. I also can't believe they're going to keep start-stop on a diesel. That sounds just plain stupid. I was really surprised to see that.
  11. Jan 8, 2018 at 9:48 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Start stop... Imagine pulling a max loaded trailer east out of PA on I84. Climbing the 2 mile hill that's at least 8% grade and then taking the exit at the top of the hill. Come to the stop sign and the red hot turbo looses oil pressure from the automatic stop... And this is coming from a Diesel fan too.
  12. Jan 8, 2018 at 9:51 AM
    jztacoma
    Upstate NY
    Semi Stockish
    so I would be in the same boat as you. only work around is to order it through the commercial or fleet service. I am able to go through that but makes finding the perfect truck little more difficult and might have to sacrifice an option or two. Depending how low I could get the fleet price might make it worth it in the end though. Might be able to ask around at the dealers to see if they have a fleet sales rep and could hook you up. I know some people were able to do that with their Tacomas actually
    The start/stop on a diesel is pretty stupid and really hope they have an easy off switch for that. $4k for the upgrade though isn't to bad considering in the super duty its just about $9k
  13. Jan 8, 2018 at 9:59 AM
    jethro
    Geoff
    Southern NH
    Holy shit, yeah, that's just crazy. Too much coin.
  14. Jan 8, 2018 at 10:00 AM
    Pugga
    Massachusetts
    If you're towing, none of the models will turn off the engine. That's what some people are using as a work around, they're plugging in one of those 4 pin trailer wiring testers and leaving it in. If the truck thinks there's a trailer attached, it deactivates start/stop. But in general, it's a stupid idea on any turbo charged vehicle in my opinion.
    There's a button on the dash that you can push to disable it but you have to press it every time you get in the truck. I've seen some youtube videos where they show you how to jumper out that switch, effectively permanently disabling the 'feature'. I'm sure there is a way to program it out if you have the right equipment.
  15. Jan 8, 2018 at 10:03 AM
    Pugga
    Massachusetts
    Agreed, especially considering you're now over the price of an XLT Superduty with 6.7 diesel at that price. Fuel economy won't be as good but you'd have a much more capable truck.
  16. Jan 8, 2018 at 10:06 AM
    jethro
    Geoff
    Southern NH
    They are gonna have to change up the F250 lineup to make that truck sell. I mean at that money you are in 1 ton territory for sure.
  17. Jan 8, 2018 at 10:07 AM
    Noelie84
    Noel
    Wales, Maine
    My 2.7EB has the stop/start and when you've got a trailer plugged in it's disabled. I'm sure that would carry over to the diesel as well.
    jztacoma likes this.
  18. Jan 8, 2018 at 10:16 AM
    Pugga
    Massachusetts
    I don't think they'll change a thing. The half tons are becoming a commodity item and the people buying them aren't even considering the 3/4 or 1 ton trucks. They're using them as a commuter basically and the drop in fuel economy alone when you jump to a HD truck will deter most. There is a push by the EPA to make the HD trucks more fuel efficient by I think 2025 and I'm really curious to see what that does to the truck market.
  19. Jan 8, 2018 at 10:26 AM
    jztacoma
    Upstate NY
    Semi Stockish
    as long as its an easy to get to button then I'm ok with that. Parents Jeep Grand Cherokee and Benz E350 have it and you just need to remember to hit the button every time you get in it. Its not a friendly feature when you are trying to pull away from a stop sign or light quickly that's for sure
  20. Jan 8, 2018 at 10:27 AM
    jztacoma
    Upstate NY
    Semi Stockish
    that's good to know, def make sense they would put that on every engine when your towing
