New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 6, 2018 at 4:01 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Only two more days in indy!!!
  2. Feb 6, 2018 at 4:36 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    What'd you get for kicks?
  3. Feb 6, 2018 at 4:43 AM
    Jcyr
    Jack
    North east
    Adidas super gettho :rofl::cool: jk they look comfy and pretty clean boss
    Cativelense likes this.
  4. Feb 6, 2018 at 4:45 AM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Looking for some advice. I know a lot of you go camping and have campers. Im looking at buying a pop up camper this year. I’m tired of tenting. I’m not looking to spend a shit load of money but want something in good shape.
    What are some things to look out for good and bad? What are some items that you must have when looking. Also is there like a kbb for campers ?
    Blais03 likes this.
  5. Feb 6, 2018 at 4:58 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    These:
    MikeyMcFly and uurx like this.
  6. Feb 6, 2018 at 5:00 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    I should consider a new pair of shoes at some point; my summer shoes will be 5 or 6 this spring, I think. But, I just had them resoled last spring so the rubber is still like new. The leather is starting to show its age a bit, but I hate breaking in a new set.
  7. Feb 6, 2018 at 5:02 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I think NADA has used camper values. You can find decent pop ups for under $2k but sometimes it takes a little bit of shopping around. The things I check for in any camper is look for signs of water leaks. If you notice any soft spots on the floor or walls, water stains on the ceiling, just walk away. Pay special attention to the ones that have a 2-part top with a center seam. If they've been properly stored and maintained, they're generally very simple units with not a lot that goes wrong. My last pop-up, the one Rob now owns, was great. It had a side slider, dual propane tanks, running hot water, a propane fridge and heat. As I said to Denis the other day, check for signs of water stains/leaks, run your hand around the cap and feel for any wet or rotten plywood. Check to see that the canvas is in good shape, no tears. Otherwise, if you do a quick walk around, you can generally tell how it's been maintained.
    jpereira2 and johnnym[QUOTED] like this.
  8. Feb 6, 2018 at 5:04 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    All this shoe talk has me thinking. I need to order a new pair of running shoes, have just about 200 miles on my current pair. My knee starts having pains around 225/250 miles. My current running shoes will then be washed and scrubbed of smell and become my weekend shoes. My current weekend shoes will become my yardwork shoes. I just continue to rotate my running shoes in that order and then toss them after they are my yardwork shoes.
  9. Feb 6, 2018 at 5:34 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    Check all sections of the floor for any soft areas. The corners are great places to step and see how much squish you are getting. As Pugga said, if you find any signs of water damage, walk away - you can repair them and think everything is OK, but you will lose your mind trying to track down any and all points of entry.
    Also look for any signs of rodents. Mice can get inside and make quite a mess - look at the fuse box to see if there is any signs of water damage or burnt fuses.
    johnnym[QUOTED] likes this.
  10. Feb 6, 2018 at 5:39 AM
    johnnym
    john
    NH
    Thanks mike :thumbsup:
    I figured id start looking now before the prices shoot up in the spring.
  11. Feb 6, 2018 at 5:51 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    :thumbsup:
    John @johnnym and Denis @64Wildcat my camper may be for sale sometime soon
    Pugga[QUOTED] and jpereira2 like this.
  12. Feb 6, 2018 at 5:59 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Good morning folks. I hope your day is going well. Just sitting here enjoying my coffee and watching the snow fall.
  13. Feb 6, 2018 at 6:01 AM
    johnnym
    john
    NH
    shoot me a txt with some info and price.
  14. Feb 6, 2018 at 6:03 AM
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
    I’m not sure if this is a serious question or a typical TW smart question. So I’ll answer anyways. I am not a black smith I was referring to gunsmithing, and I’m not that either. I do have some experience with firearms and am able to do a few things. However I have a close friend who is very competent with firearms and can address most issues or part replacements
    Bridge4[QUOTED] likes this.
  15. Feb 6, 2018 at 6:09 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    going bigger?? :D
  16. Feb 6, 2018 at 6:14 AM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    Morning y'all! Busy week from me, so I probably won't be on here much.
    Been thinking about what to do with the truck next. Bouncing around between sliders+skids, lights, wilco tire gate, and a CB. Probably will go in roughly that order though. Who knows.
    Everyone stay healthy!
  17. Feb 6, 2018 at 6:20 AM
    Pugga
    Massachusetts
    Is that my old one? Are you going with a travel trailer or a newer pop up?
    If so, John and Denis, in my opinion, that one has a great layout. It has a side slide out so you have a lot of floor space. It's on the heavy side for a pop up so it tows well also. It's an older model but was in good shape.
  18. Feb 6, 2018 at 6:24 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    :thumbsup:
    Will do. At lunchtime
    I think so
    Yes. Your old one. It does tow very well. I think some of it has to do with the torsion axle too
    Pugga[QUOTED] likes this.
  19. Feb 6, 2018 at 6:29 AM
    jpereira2
    Massachusetts
    Go big or go home! did you go to the boston show? see something you liked? details details lol
  20. Feb 6, 2018 at 6:31 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Yup we went to the Boston show and were going to the Springfield show in a couple of weeks. Depending on what kind of deal we can get we may be purchasing a bunkhouse TT
    ERMB, BadDNA and jpereira2[QUOTED] like this.
