New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 9, 2018 at 2:35 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Morning .I think It's Friday...:pccoffee:
    tacobell007 likes this.
  2. Feb 9, 2018 at 2:37 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Good morning everyone. TGIF!
    tacobell007, Bridge4 and DrFunker like this.
  3. Feb 9, 2018 at 2:38 AM
    DrFunker
    DrFunker Well-Known Member
    :cheers:
  4. Feb 9, 2018 at 2:56 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Happy Friday all.
    DrFunker likes this.
  5. Feb 9, 2018 at 3:49 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Not yet.
  6. Feb 9, 2018 at 4:04 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Oh the joys you will have with that harness... I had my high beam indicator on, with the stalk set to low beams, and no headlights being on at all...
    Check the fuses and relay for proper fitment (sometimes my radio fuse backs out, or the headlight relay does) and see if that works. If not then it could be the stalk
  7. Feb 9, 2018 at 4:08 AM
    micwillia
    micwillia Nonstop Tinkerer
    Cental Masshole
    Turd gen Inferno Taco TuRD OR DCSB 6MT, '96 Mustang V6 Vert 5MT
    Cubby Covers, TRD Pro Exhaust, BAK RevolverX2, Pro Skid, Speaker Upgrade, OBA/W, CB, 255/85R16
    That's funny cause I've been to the dealership twice in the last 2 weeks for this issue and of course they come out with the tsb 2 days after I was in for the work. The tech told me the noise is characteristic of MT Tacos..... So they told either have to live with it:frusty:
    Definitely heading back in to have this done
    Spare Parts[QUOTED] likes this.
  8. Feb 9, 2018 at 4:11 AM
    micwillia
    Cental Masshole
    Lol I keep thinking the same thing but mine is just a relationship instead of marriage..so cheap.....sooo tempting
    Cativelense[QUOTED] likes this.
  9. Feb 9, 2018 at 4:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This doesn't sound like a relay to me. Relays are very simple, this sounds like something else going on. Unfortunately, you're going to need a test light to prove it out. My bet would be on the switch. The whine you hear at the relay is likely because the switch is feeding power to multiple parts of the relay so the relay is whining trying to figure out which way to go. I think your real issue is upstream of the relay.
    BadDNA[QUOTED] likes this.
  10. Feb 9, 2018 at 4:50 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Really what you need to ask yourself is which is more important to you: Sex, or suspension.
    Since you're married with an anklebiter running around, you aren't having sex anyway, so you might as well go with the suspension. :notsure:
    I agree; relays are a yes/no option. Typically when they go bad they don't cycle.
    But, you can do an easy test by swapping in a good relay; there should be an identical one for the low beams in that same box. No tools required and it's an easy way to eliminate the relay as a cause.
    Edit- Which relay did you pull? If I remember right from my '10, there should be a relay for high beams, a relay for low beams, and a relay labeled 'dim/dimmer' which is what controls the cycling from high/low.
  11. Feb 9, 2018 at 4:51 AM
    Cativelense
    Nuno
    CT
    Hit the nail right on the head about the no sex part.
  12. Feb 9, 2018 at 4:59 AM
    BadDNA
    Eammon
    Cabot, VT
    There's one relay, four fuses for the lights in the underhood fuse box. I looked but didn't find another identical relay to swap with. It's a cheap enough part of I can find it locally, I'm going out this morning to try. If swapping the relay doesn't fix it, I'll look into finding a replacement switch. It's Friday ,I should be able to get to a parts counter if I have to.
  13. Feb 9, 2018 at 5:01 AM
    Pugga
    Massachusetts
    Sounds like you're getting a new suspension then :D
  14. Feb 9, 2018 at 5:02 AM
    Cativelense
    Nuno
    CT
    FML. I need to take some deep breathes... I'm going to get myself in A LOT OF TROUBLE if I do it.
    Bridge4 likes this.
  15. Feb 9, 2018 at 5:03 AM
    Pugga
    Massachusetts
    We aren't the right group to be talking you out of it, just FYI... We're all living vicariously through you so I wouldn't plan on us to provide a good example.
  16. Feb 9, 2018 at 5:03 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Good morning! Missed the watch thread. When I was in Greece about 100 years ago I bought a very expensive Tag Hauer watch that now sits in my desk drawer. At the time jewelry and watches were much cheaper there, so I figured I'd buy one. Turns out I can't keep an expensive watch on my wrist for more than a few months without breaking the pins because I catch it on something. Worst use of $1200 quite possibly in my entire life. This is it... Anyone want to buy it? Just needs a pin and battery! LOL
    vssman likes this.
  17. Feb 9, 2018 at 5:04 AM
    Cativelense
    Nuno
    CT
    :rofl::rofl::rofl::rofl::rofl:
  18. Feb 9, 2018 at 5:04 AM
    Pugga
    Massachusetts
    I'll give you a $20 for it :D
  19. Feb 9, 2018 at 5:04 AM
    DrFunker
    True. :popcorn:
    Bridge4 and Cativelense like this.
  20. Feb 9, 2018 at 5:05 AM
    Noelie84
    Noel
    Wales, Maine
    Crap, maybe I'm thinking of my G1, then.
    There should still be a relay labeled "headlight" and one labeled "dim/dimmer" then. Which did you pull?
