New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 16, 2018 at 11:17 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    TBD as of right now. Waiting on it actually getting to me first... also trying to figure out if I need to do anything to the rear, since apparently it doesn't give you any lift in the back, only in the front. Figuring out if I need an AAL or not, or what the best option is since I have an ARE cap.
    tacobell007 likes this.
  2. Feb 16, 2018 at 11:18 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Just volunteered for jackstand duty. :stirthepot:
  3. Feb 16, 2018 at 11:19 AM
    BananaPeelOut
    BananaPeelOut Well-Known Member
    Ben
    NH
    2005 silver access cab TRD Off-Road
    Kenwood Headunit, CB radio setup, wind deflectors.
    Just go for it. Mostly because my inexperienced opinion says you'll need it to make it look just right and if you're gonna walk on ice you might as well dance!
  4. Feb 16, 2018 at 11:20 AM
    Cativelense
    Nuno
    CT
    :rofl::rofl::rofl:
  5. Feb 16, 2018 at 11:21 AM
    BananaPeelOut
    Ben
    NH
    As in being the jackstand? I guess I'll start doing some squats
  6. Feb 16, 2018 at 11:22 AM
    Noelie84
    Noel
    Wales, Maine
    Yep. Better get on it.
    :curls: :militarypress:
  7. Feb 16, 2018 at 11:39 AM
    BananaPeelOut
    Ben
    NH
    On an unrelated note your sig is from Top Gear right? The quote I mean, I know the .gif is.
  8. Feb 16, 2018 at 11:48 AM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
  9. Feb 16, 2018 at 11:57 AM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    You mean most extreme elimination challenge
  10. Feb 16, 2018 at 12:00 PM
    BananaPeelOut
    Ben
    NH
    mxc ? what an absolutely wonderful show
  11. Feb 16, 2018 at 12:05 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Ya MCX is the one I'm thinking about
  12. Feb 16, 2018 at 12:14 PM
    BigMacMcCoy
    Braedon
    Vienna, VA
    You could throw a Deaver AAL in, which should give you a couple inches I think. What's the lift on the front? Usually you want X-1" on the rear to get it level.
    HeadStrong OffRoad may be able to get it here in time, I know my order shipped pretty quick!
    Otherwise I wouldn't worry about it. You may have some bro-lean, but that's easily fixed in the future.
    Cativelense[QUOTED] likes this.
  13. Feb 16, 2018 at 12:16 PM
    Cativelense
    Nuno
    CT
    From what I saw/read, the front lift would be 1.75
    Someone suggested the 3 leaf AAL from Headstrong, so kinda thinking about that... reached out to Marie by PM to get her input/opinion, and then go from there.
  14. Feb 16, 2018 at 12:20 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I'd check the specs on the rear shocks and make sure the compressed/ extended lengths will work with any sort of lift. It would suck to blow the shocks. I know the regular 5160s can accommodate around 2" of lift, not sure about the PRO variant though.
  15. Feb 16, 2018 at 12:21 PM
    Cativelense
    Nuno
    CT
    Not a bad idea. I think I may need to wait to get it in to check all of that... I think. We'll see.
    BigMacMcCoy likes this.
  16. Feb 16, 2018 at 12:21 PM
    BigMacMcCoy
    Braedon
    Vienna, VA
    Not a bad idea! So by my reckoning (which may be wrong), you're looking at your front end being 3/4" higher than you're rear. I don't think you'll really notice the difference!
    You could always put a few PSI more in your rear tires and it'll level out haha
  17. Feb 16, 2018 at 12:23 PM
    Cativelense
    Nuno
    CT
    Yeah... my concern now is the sagging over time, making it worse. Which is what "triggered" me questioning what/if anything can be done. Figured if that is an "issue" or a possibility, thinking it would just be worth doing it right now, rather than fixing it later.
    BigMacMcCoy[QUOTED] likes this.
  18. Feb 16, 2018 at 12:27 PM
    BigMacMcCoy
    Braedon
    Vienna, VA
    I hear you. When we did my lift the rear was so much easier than the front, so if you decide to wait and see you'll definitely be able to add a leaf or three fairly easily down the road.
    Plus, at barely 4 years old with a new cap I doubt you'll see much sagging yet. Down the road a few years maybe.
  19. Feb 16, 2018 at 12:28 PM
    Noelie84
    Noel
    Wales, Maine
    Yes to both. The quote is from a review Clarkson did on the Ford Focus RS.
    BananaPeelOut[QUOTED] likes this.
  20. Feb 16, 2018 at 12:29 PM
    Cativelense
    Nuno
    CT
    Yeah, that's a good point right there, and I thought about that as well. Thinking that with brand new shocks, it hopefully wouldn't be a "problem" just yet. And, with the cap on it now and 50K on the current stock/crappy oem shocks, it doesn't look uneven to me... at least not that I can tell.
