New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Mar 12, 2018 at 2:55 PM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    2k would be the stuff that requires a respirator, right? They sell that too. EDIT: went and looked, it is 2k SprayMax urethane clear that they sell.
    My secondary plan is some light gray uv-stable bedliner to match my wheels, on the flares and lower body for a two-tone look.
  2. Mar 12, 2018 at 3:10 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I buy my materials at a local automotive paint jobber. The only reason I'd suggest the SprayMax aerosolized clear is that I don't know what equipment @BadDNA has. If he has a HVLP spray gun and a compressor big enough to handle it, then go with a quart of clear for the flares. Also use disposable water filter "bombs" at the spray gun.
    All paint requires proper PPE - respirator is a must with a new set of correct filters regardless if 1k or 2k (catalyze D). I also wear Tyvek coveralls when painting a larger area.
    tacobell007 likes this.
  3. Mar 12, 2018 at 3:16 PM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
  4. Mar 12, 2018 at 3:19 PM
    BadDNA
    Eammon
    Cabot, VT
    That's another option too (quarts from a local shop). I don't have any fancy gear, just a cheap hvlp gun that came with my compressor and very little experience with it, compared to years of rattle canning stuff of all shapes and sizes.
    vssman[QUOTED] likes this.
  5. Mar 12, 2018 at 3:19 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
  6. Mar 12, 2018 at 3:29 PM
    BananaPeelOut
    BananaPeelOut Well-Known Member
    Ben
    NH
    2005 silver access cab TRD Off-Road
    Kenwood Headunit, CB radio setup, wind deflectors.
    No way.
    I embrace Creed, with arms wide open.
  7. Mar 12, 2018 at 3:30 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Napa sells the same stuff Sherwin Williams Automotive sells. Give them your paint code and you can get a quart or however much of the color matched paint. Everything is measured in weight as well
    vssman likes this.
  8. Mar 12, 2018 at 4:12 PM
    BadDNA
    Eammon
    Cabot, VT
    A quart should do the flares, right? Adhesion promoter and primer are fine from rattle cans, right?
  9. Mar 12, 2018 at 4:18 PM
    tacobell007
    Drew
    Western MA
    The primer will be, thats how we use to do it. Quart will be plenty, you will dedinitely have left over paint from a quart jug as you mix it with hardener I believe. I cant remember iff the top of my head if their stuff was with hardener or reducer
    vssman likes this.
  10. Mar 12, 2018 at 6:02 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    well im ordering my wheels! getting the black and grey pro comps! now to figure out tires/size/brand/type. I love my st maxx's but kinda want something lighter since the wheels are gonna be about 5lbs heavier each
  11. Mar 12, 2018 at 6:22 PM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    What sizes are you thinking? You going 17” wheels?
  12. Mar 12, 2018 at 6:33 PM
    jpereira2
    Massachusetts
    yup 17s. Currently looking at 265/70/17 and 275/70/17. Thought about 33s but not sure itd be worth it due to towing heavy. Plus I don't want to remove mudflaps or trim
  13. Mar 12, 2018 at 6:36 PM
    jztacoma
    Upstate NY
    Semi Stockish
    Check out 255/75R17 as well. It’s the wrangler rubicon stock tire size so there’s a few AT options for it. The StMaxx actually comes in a C load in that size. I’m kind of looking at it for my next set since it’s more of a 32” tall versus the 265/70R17 and you’ll probably get better MPG compared to the 265s
    jpereira2[QUOTED] likes this.
  14. Mar 12, 2018 at 6:39 PM
    jpereira2
    Massachusetts
    Anybody know which lug nuts I need? lol never bought wheels before
  15. Mar 12, 2018 at 6:44 PM
    Fishinbum802
    Fishinbum802 Well-Known Member
    Massatwoshits
    2022 Chevy 1500 RST
    I know, I know, but I needed a half ton.
    I ran 265/75/16 duratracs for 4 years. The size was good for a mix of towing and some off roading. No rubbing issues and they didn’t feel like they robbed power towing my dads boat.
  16. Mar 12, 2018 at 6:45 PM
    jpereira2
    Massachusetts
    thats the size i have now but for st maxxs i think they are like 55lbs each. but now im going to a 17 inch wheel and by all means i can feel the difference in stopping/accelerating vs the much lighter stock setup. Stock tires i think were like 33lbs each.
    Fishinbum802[QUOTED] likes this.
  17. Mar 12, 2018 at 6:49 PM
    Fishinbum802
    Massatwoshits
    2022 Chevy 1500 RST
    Yea I definitely noticed a difference when I jumped up to 255 st Maxx.. I think it was more of the tire size vs the weight increase that feels like it slows me down.
    jpereira2 likes this.
  18. Mar 12, 2018 at 7:13 PM
    tacobell007
    Drew
    Western MA
    Yea rotational force will do that. Going to my Mastercraft MXT's 35x12.5x17 they weigh 1lb more each than my old General Grabber AT2's in a 33x12.5x5x17 but definitely more power loss due to rotational forces
  19. Mar 12, 2018 at 7:17 PM
    jpereira2
    Massachusetts
    so I should probably stick with a 32 then
  20. Mar 12, 2018 at 7:19 PM
    tacobell007
    Drew
    Western MA
    Not a bad idea
