New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Apr 8, 2018 at 3:21 PM
    DrFunker
    DrFunker Well-Known Member
    I like beer. :cheers:
  2. Apr 8, 2018 at 3:30 PM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    Why not just replace the whole LCA? Once you do the bushings and ball joint must be kind of close in price, plus rust and any possible stressed steel
    BostonBilly likes this.
  3. Apr 8, 2018 at 3:36 PM
    DrFunker
    Exactly what I am doing. Got an extra set from @Doogz
  4. Apr 8, 2018 at 3:38 PM
    demo243
    demo243 Well-Known Member
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    Android/Samsung users what are you using for an aux in cord on the newer 2nd gen Tacoma?
    My I phone I could use any usb/lightning cable and it connected with my jbl head unit... but now I've got a Samsung galaxy s7 and the head unit doesn't recognize it with the stock usb cord the phone came with... charges it,but won't connect
    Bluetooth works but then the volume is so much lower...
  5. Apr 8, 2018 at 3:41 PM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    I have a 3rd gen but I had to change settings for bluetooth and then it made it loud like everything else. I'd check around the settings a bit.
    tacobell007 likes this.
  6. Apr 8, 2018 at 3:41 PM
    jztacoma
    Upstate NY
    Semi Stockish
    My fear is when trying to get them off to do the alignment cams everything is gonna be seized and will have to replace everything as well
  7. Apr 8, 2018 at 3:44 PM
    demo243
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    I'll check into that...
    But trying to get it to play through the usb aux in cord
  8. Apr 8, 2018 at 3:44 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Most of the time they are seized so you have to cut them off. I did the same with my truck a year or two ago - bought a spare set of LCA's from @mach1man001 and then pressed in whiteline bushings and proforged lower ball joints. Worked mint - better steering response than stock and a lot better than the MOOG replacements as far as longevity. I also greased the shit out of everything and break them loose every season and regrease them. I replaced all the hardware as well with OEM bolts/nuts/cam hardware.
    I also sandblasted and had some of the parts welded to make the LCA stiffer. They etched it, primed it, painted it then treated the inside of them with Mavcoat and then fluid film... I have some minor rust on the outside from rocks scraping it but other than that they're mint still.
    I have two spare sets of LCA's right now - the worse one is with @tacobell007 if anyone needs a hot swap pair - they'll need a very good sandblasting though. The other set I have I'll be doing some modifying and then rebuilding them.
  9. Apr 8, 2018 at 6:11 PM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    How did you end up getting the ball joints out of the arms? I'm working on a pair and the ball joints are in there impossibly tight.
  10. Apr 8, 2018 at 6:20 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Did you take the C clips out? Otherwise balljoint press with an impact, or a shop press
  11. Apr 8, 2018 at 6:24 PM
    Bruce988jl
    Southern NH
    A big 20 ton press.... and a lot of cursing
    Getting them out was a lot easier than finding a shop that could press the ProForged knurlled ball joints in... I almost said f'ck it and machined down the knurls until I found a dealership that could do it.
    DrFunker likes this.
  12. Apr 9, 2018 at 2:06 AM
    DrFunker
    Yes. I pretty much have everything for two LCAs ready to go. Anything I don't use will be passed along to someone looking to do the same (could be you? :D).
    LivinLoud and jztacoma[QUOTED] like this.
  13. Apr 9, 2018 at 2:36 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone. Back to the salt mines again. :annoyed:
  14. Apr 9, 2018 at 3:02 AM
    DrFunker
    :wave:
    mmmmsalt :homer:
  15. Apr 9, 2018 at 3:02 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning all.
    Yup, where are you digging today? :rolleyes: :D I'll be right beside you...
    Cativelense[QUOTED] and DrFunker like this.
  16. Apr 9, 2018 at 3:12 AM
    jztacoma
    Upstate NY
    Semi Stockish
    Haha thanks! I might pick up the cam bolts and I’ll look maybe getting some bushings. The “premium” LCA from Rock Auto is $100 each. I’m at 57,xxx miles, if I was closer to 100k I would just replace it
    DrFunker[QUOTED] likes this.
  17. Apr 9, 2018 at 3:42 AM
    BadDNA
    Eammon
    Cabot, VT
    Yeah, got the c clips out but my 12 ton press isn't making them budge. Ball joint press with an impact will be my next step, though that might be moving backwards. After that, on to a shop.
    tacobell007[QUOTED] likes this.
  18. Apr 9, 2018 at 4:11 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Morning all. A quick question, how much does all the parts and pieces cost to rebuild the control arms and how much is a complete arm, all set ready to just bolt in?
  19. Apr 9, 2018 at 4:38 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Morning ... :pccoffee: ...60's to 70' this Friday..Sat..:militarypress:
    Bridge4 and Hunter.415 like this.
  20. Apr 9, 2018 at 5:08 AM
    jztacoma
    Upstate NY
    Semi Stockish
    You guys have any good front brake replacement options? Pads are getting a little low (almost through the center dust line) and rotors are getting little crispy around the edges.
    I do tow a lot, not looking to break the bank, but something above NAPA
