New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 1, 2018 at 11:41 AM
    micwillia
    micwillia Nonstop Tinkerer
    Cental Masshole
    Turd gen Inferno Taco TuRD OR DCSB 6MT, '96 Mustang V6 Vert 5MT
    Cubby Covers, TRD Pro Exhaust, BAK RevolverX2, Pro Skid, Speaker Upgrade, OBA/W, CB, 255/85R16
    Did you get the TSB for the diff howl? It fixed it on mine at least, I've heard some say that it didn't work as well as they hoped. For me it made a world of difference since it seemed like I am always driving at the speeds it happens.
    Edit: Saw your other post about the TSB not covering '18s. I couldn't remember what your Taco was for certain
    Bridge4[QUOTED] likes this.
  2. May 1, 2018 at 12:06 PM
    BananaPeelOut
    BananaPeelOut Well-Known Member
    Ben
    NH
    2005 silver access cab TRD Off-Road
    Kenwood Headunit, CB radio setup, wind deflectors.
    I thought it made sense for the front tires to be inflated more, since theyre always carrying the weight of the engine? Unless the thinking is that if youre driving a HD truck then you probably have more weight in the bed?
  3. May 1, 2018 at 12:11 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    That's why. 2400lbs of payload potential vs 500lbs or so of engine. When I put a plow on this winter I may need to bump the PSI a bit up front, since an 8.5 Fisher V runs around 950lbs.
  4. May 1, 2018 at 12:14 PM
    BananaPeelOut
    Ben
    NH
    Ahhh makes sense. 30 psi difference seems like a lot though. have you gotten a V plow yet?
  5. May 1, 2018 at 12:19 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
  6. May 1, 2018 at 12:21 PM
    Noelie84
    Noel
    Wales, Maine
    No, not yet. I'm waiting to see if a good deal pops up on Craigslist over the summer, but really I'd rather buy a new one for the warranty coverage. If I go that route I'll end up picking one up in the crate and assembling it myself rather than paying the dealer to do it.
  7. May 1, 2018 at 12:22 PM
    BananaPeelOut
    Ben
    NH
    I didn't even know that was an option lol.
    Noelie84[QUOTED] likes this.
  8. May 1, 2018 at 12:23 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  9. May 1, 2018 at 12:29 PM
    BananaPeelOut
    Ben
    NH
  10. May 1, 2018 at 12:33 PM
    Noelie84
    Noel
    Wales, Maine
    Yeah, assembling one is pretty straightforward. Basically it's just installing the center pin for the two blades, putting the pins through the holes for the rams & pivot points, connecting hydraulic hoses, and filling it up with fluid. I helped the GF's dad do his when he upgraded to an XV2 a couple of years ago and it took the two of us about 2 hours, including mixing up the hydraulic hoses for the rams and having to take them off and start over :laugh:
    BananaPeelOut[QUOTED] likes this.
  11. May 1, 2018 at 12:51 PM
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
    AWESOME! I’m glad you’ll get some good use out of it! Thanks for checking for the bit. It must be around somewhere then
    tacobell007 likes this.
  12. May 1, 2018 at 12:57 PM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    To be honest it was a really bumpy ride home and through the county so it could have fallen out on the ride. Hopefully you find it in your garage though.
    LivinLoud[QUOTED] likes this.
  13. May 1, 2018 at 1:03 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You have the same axle code as me so it should be 3.73.
    Edit: nvm, you have 4.10 gears, I bet that thing tows like a damn train.
  14. May 1, 2018 at 2:22 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
  15. May 1, 2018 at 3:17 PM
    Dgibson529
    Dgibson529 Well-Known Member
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Price point and mpg are big to me. I used to get 18-19 in my tacoma but I’ve been seeing 16.5 according to Fuelly
  16. May 1, 2018 at 4:39 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    The electronic stuff is the problem people are running into with the C5s now. The body control modules for the earlier cars are out of production so when they fail a used one is your only option which has driven up the price on the second hand market to over $1,000. You can run the car without it but you lose ABS and TCS.
    The problem isn’t with the software but the hardware. It’s no longer in production and was proprietary to begin with so there aren’t any options.
    The same issue creeps up with the steering wheel position sensor and that can effectively make the car undeliverable depending on the specifics of the car.
    Luckily with trucks there are simply so many it’s a much wider pool of parts.
  17. May 1, 2018 at 4:41 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    I also like to believe Toyota puts out a tad better hardware than chevy. Time will tell but I really hope yotas don’t start having those problems
  18. May 1, 2018 at 4:57 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    What do you guys think 5 new 285 70 17 KO2 could sell for? I haven't decided for sure yet but thinking about selling the original 33's ti help soften the expense of new tires
  19. May 1, 2018 at 4:58 PM
    yellow_bandit
    yellow_bandit Well-Known Member
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I'd be interested except I'm running 265/65/17 and I think that size will give me rubbing on the stock suspension.
    BostonBilly[QUOTED] likes this.
  20. May 2, 2018 at 1:57 AM
    BostonBilly
    Easton
    Morning, woke up to the wife yelling and banging on the window last night. I went running but it was only a raccoon trying to get in the trash. Popped him with the pellet gun after 15 minutes of listening to him trying to get in.
