New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 9, 2018 at 5:00 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Damn. They're proud of their LEDS, aren't they? $800 for a pair of 3" work lights with the wiring and $1000-1800 for a light bar is definitely more than I'm looking to spend for something that would see limited use at best :laugh:
    Edit- Well, they've got some less expensive light pod offerings that I found. Still $200, but not as bad.
    Never noticed any noise out of mine. I had the offroad package, though, so maybe a different set?
  2. May 9, 2018 at 5:18 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Could be--I know the shocks are different, but I'm not sure if the springs are. Mine is a 3-leaf pack and seems to ride pretty stiff (which is a good thing).
  3. May 9, 2018 at 5:45 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Morning guys,
    This morning I got in my truck, put the key in, pushed the clutch cancel button, and turned the key to the start position and nothing happened (did not crank, click, or anything. I mean nothing)... the radio and headlights and dash lights were on though like they should have been. I turned the key again and it cracked for about half of second then stopped. I turned the key once more and the truck started fine and I drove to work. Anyone have any ideas? I'm thinking my starter is on the way out. Thanks
  4. May 9, 2018 at 5:57 AM
    Noelie84
    Noel
    Wales, Maine
    Does it still work correctly when you step on the clutch? Could be that your clutch cancel switch isn't getting a good contact and needs to be replaced. If you use it all the time it might just be worn out.
  5. May 9, 2018 at 5:57 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    Question: what were you doing when you heard them? When I had my F150, I thought there was a creak in the springs as I could hear an annoying squeak while driving every now and again. Turned out to be the tailgate squeaking on the latch post. I greased the pin and the squeak went away. Just a thought.
  6. May 9, 2018 at 6:04 AM
    redrelyt12
    redrelyt12 Well-Known Member
    Tyler
    2016 Tacoma TRD Sport DCLB
    Derped TRD Sport Grille BAK Revolver X2 Tonneau Cover mattgecko Waterproof LED Hood & Bed light kits Southern Style OffRoad Slimline Hybrid Front Bumper Baja Designs 20" S8 Light Bar Smittybilt X2O-10 Winch Blue 3/4" Shackles
    I was able to buy it with the bumper "used" (he changed his mind before installation) from a member for a yuge discount
    Noelie84[QUOTED] likes this.
  7. May 9, 2018 at 6:04 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Try unplugging and then plugging the button back in
    Cativelense and Sloth like this.
  8. May 9, 2018 at 6:08 AM
    Noelie84
    Noel
    Wales, Maine
    I guess he didn't 'know more about LEDs than the manufacturer', then.
  9. May 9, 2018 at 6:09 AM
    Blais03
    Nick
    Easthampton MA
    Im not sure. It started and I left lol ill have to see if it happens again and then skip the button and try it. I do use the button regularly
  10. May 9, 2018 at 6:09 AM
    Blais03
    Nick
    Easthampton MA
    Will try that. Have you had this kind of problem before?
  11. May 9, 2018 at 6:11 AM
    tacobell007
    Drew
    Western MA
    Yea the button wouldn't light up anymore and the plug wasnt seated properly anymore. I also had an issue that every 8 months to a year the radio fuse under the hood would back itself out just enough to keep the radio on til you shut the truck off, then the radio wouldn't turn on the next time you started the truck
  12. May 9, 2018 at 6:14 AM
    Blais03
    Nick
    Easthampton MA
    The light was on on the button when I pressed it this morning though. Ill take a look at the button anyway. I want to check my starter too and make sure they connections are tight too
  13. May 9, 2018 at 6:17 AM
    tacobell007
    Drew
    Western MA
    Could just have not had a good contact, check for corrosion on the battery and the starter positive terminals. Clean with baking soda and bottled water mixed and a brush if needed
    Cativelense likes this.
  14. May 9, 2018 at 6:19 AM
    Blais03
    Nick
    Easthampton MA
    I checked the battery connections this morning. Those were tight and the battery had no corrosion on it
  15. May 9, 2018 at 6:20 AM
    Noelie84
    Noel
    Wales, Maine
    I know that on my '99 the owner's manual said not to use the CC switch regularly to start it, that you should use the clutch for the day-to-day and only use the CC switch 'when the situation demanded it' while off-roading.
    So if I were to guess, the switch isn't designed for a lot of use like the clutch switch is, and it's wearing out.
    Jcyr and tacobell007 like this.
  16. May 9, 2018 at 6:22 AM
    tacobell007
    Drew
    Western MA
    I meant on the back of the switch for the connection
    Cativelense and Blais03[QUOTED] like this.
  17. May 9, 2018 at 6:28 AM
    Blais03
    Nick
    Easthampton MA
    Will do. Thanks drew
    tacobell007[QUOTED] likes this.
  18. May 9, 2018 at 8:46 AM
    js312
    Joe
    New England
    Getting out of the truck. Last time I heard it I was able to duplicate it by pushing down on the back bumper.
  19. May 9, 2018 at 9:47 AM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    vssman and BostonBilly[QUOTED] like this.
  20. May 9, 2018 at 10:20 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    You and me both
    bucktales[QUOTED] likes this.
