New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 21, 2018 at 5:26 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    This.
    Pugga[QUOTED] likes this.
  2. May 21, 2018 at 5:29 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Newer circulators are very efficient now too. I replaced the one for my main zone with a Grundfos Alpha 2 and it draws about 1/5 the power the old one did. I'm tempted to replace the others, but I rarely use those zones so it's tough to justify.
  3. May 21, 2018 at 5:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Honestly, for the size you'd be looking for, I bet you could still find them. The people who panicked and ran to HD or Lowes bought the 4-8k watt generators that were sitting on the shelf for under $1,000. I doubt they were running out to buy a 12k watt behemoth for over $2k on a whim (I could be wrong though, there were a lot of people out of power for a long time so it's possible the shelves were cleared).
    Cativelense[QUOTED] likes this.
  4. May 21, 2018 at 5:36 AM
    Jcyr
    Jack
    North east
    Bridge4, Sloth and Pugga like this.
  5. May 21, 2018 at 5:41 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    I'll definitely check into it! You never know.
  6. May 21, 2018 at 5:43 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    I've only got a 4500 watt unit, but it kicks out enough juice to run both deep freezers, the fridge, boiler, water pump, and some lights. I don't usually bother dragging it out of the garage unless we've been a couple of days without power, though, since we're set up pretty well for outages; the only real difference is that we don't have running water or the electric range. :notsure:
    The wood stove keeps the house at 68-75 anyway. There's a hand pump rigged in the cellar that draws directly from the well, so we've still got water (and can flush the toilets!). And the Aladdin lamps keep the house almost as well-lit as electricity anyway.
    Bridge4 likes this.
  7. May 21, 2018 at 5:44 AM
    Pugga
    Massachusetts
    Jcyr[QUOTED] likes this.
  8. May 21, 2018 at 5:47 AM
    Pugga
    Massachusetts
    Wow... That's a lot for a 4,500 W unit! I calculated conservatively using the max draw for each device even though they will generally run at a much lower draw. With the max draw, I can run the fridge and the boiler with the circulation pump. In reality, I could probably run much more than that as long as they don't all try to start up at the same time. I also have 3 generators sitting around at the moment so I could improvise if needed :anonymous: We have propane for the cook top which is nice and, of course, the gas grille.
    Noelie84[QUOTED] likes this.
  9. May 21, 2018 at 6:11 AM
    Noelie84
    Noel
    Wales, Maine
    Never had any problems. But, like you said, they're not running at max draw at the same time. The freezers and fridge are only at max draw at the moment their compressors kick on, and even that's only around 400 watts per unit, max. Probably closer to 200-300 per while they're running. Boiler's the same way; the most electricity draw is at startup, since it's running the igniter and the oil pump at once. Since it's not running for heat for the house, so the circulator pumps aren't running; they'd probably push it over the limit.
    The biggest draw would be the electric water pump, since that's around 2000 watts while it's running.
    Just wait six months and buy one from Craigslist this fall, after people are tired of spending all summer tripping over the one they bought this week.
    jpereira2 likes this.
  10. May 21, 2018 at 6:59 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Hello
    I will be transporting a 24' ladder , and was wondering what the masses are using to protect the roof paint were a ladder will sit?
    Pics would help but not needed.
    Thanks'
    Sean
  11. May 21, 2018 at 7:01 AM
    Noelie84
    Noel
    Wales, Maine
    ....A rack. That way the ladder doesn't touch the roof.
    You can build a basic one for about $40 of PT that fits right into the stake pockets on the bed.
    Edit- Like so:
  12. May 21, 2018 at 7:02 AM
    Pugga
    Massachusetts
    If I had to do it, I'd use pool noodles with t shirts tied tightly around them where the ladder contacts the cab. Just make sure whatever is actually in contact with the cab is soft enough so where it won't scratch the paint. Also, don't cinch it down so tight that it dents the cab.
  13. May 21, 2018 at 7:03 AM
    Pugga
    Massachusetts
    Oh, actually, this, I forgot you have an F250 loaner with stake pockets! Hands down, that's the way to go!
  14. May 21, 2018 at 7:04 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    rolled towels
  15. May 21, 2018 at 7:05 AM
    smcgill
    Sean
    I was thinking the blue foam that you use for canoes .
  16. May 21, 2018 at 7:08 AM
    jpereira2
    Massachusetts
    so I should probably buy new bushings for these guys rather than removing the ones in the current leafs even though they only have like 13k miles on them. Anybody know of a good place to buy just the leaf bushings and if they have upgraded ones i should look into? They wanted the old leafs back I was told but didn't receive a return label or anything so I'm guessing I get to keep the old ones too. In which case I would probably use the current ones through the winter then replace them after all that damn salt is gone.
  17. May 21, 2018 at 7:15 AM
    Noelie84
    Noel
    Wales, Maine
    That always annoyed me about the G2 Tacoma; no stake pockets for a DYI rack system. I mean, it's a molded bed; there's no reason they couldn't have put a set in there and made it all neat & tidy looking, without losing the tie-down rails.
  18. May 21, 2018 at 7:24 AM
    Pugga
    Massachusetts
    I honestly had no use for them until recently. The tool box I put on the F250 is only temporary so I didn't want to drill into the bed. I just used some J-bolts and hooked them into the bed stake pockets instead. I do sort of miss the Tacoma bed rail system but, the Ferd has heavy tie downs in all 4 corners (which my 2007 didn't have from the factory) and the box link cleats for lighter tie downs. Realistically, that's all I'll ever need.
  19. May 21, 2018 at 7:31 AM
    Noelie84
    Noel
    Wales, Maine
    I'm cheap; having to buy a clamp-on Trac Rack for the Tacoma rather than just building one out of PT annoyed me :laugh:
    Edit- And constantly having to retighten the bolts holding it together annoyed me more, since the weird chalky lock-tite they put on them from the factory didn't work at all
  20. May 21, 2018 at 7:35 AM
    smcgill
    Sean
    If I remember right .. that rack can and will rub and dent the sheet metal around the stack pockets …. :annoyed:…. Why don't the make them the same size as a 2X4 ...:notsure:
