New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Aug 23, 2018 at 5:19 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I don't know if they will last as good as a Ford and I'm almost positive it won't be as trouble free as my Toyotas were but I like the body style and design of the GMC trucks the best out of any truck out there. Even so I like my '17 body style better than the new ones. The front looks good on the '19 but I'm not sure about the back yet:
    Cativelense likes this.
  2. Aug 23, 2018 at 5:19 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    Sounds like you two got a good deal! Congrats!!
    Cativelense[QUOTED] likes this.
  3. Aug 23, 2018 at 5:19 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Yeah... they had a new one inside the showroom, and the back looked "funky".
  4. Aug 23, 2018 at 5:21 AM
    Cativelense
    Nuno
    CT
    MEH... I'm sure it could have been better if we knew how to negotiate better, but the Mrs had a number in mind that she was willing to pay because the car was fully loaded, and even with 42k miles on it, so as long as she's happy I don't give a flying you know what.
  5. Aug 23, 2018 at 5:24 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    The new trucks all look wonky because of the aero stuff they're doing.
    Aha, spare time...never enough of it.
  6. Aug 23, 2018 at 5:41 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    They do, but unless you have the arctic package, they don't retain heat very well at all. When I go to Maine in October, I usually use the heater first thing in the morning just to get the chill out of the air, beyond that it's not really doing much. Still just have to layer up pretty good at night (which is fine with me, I love sleeping in the cold).
    I don't camp beyond October because I try to keep the camper out of the salt. My camper is cheap, so I'm sure the frame wouldn't fare well against salt. It needs to be touched up as is, which is sad considering the use it's seen.
    Do you have the arctic package on yours?
    Bridge4 likes this.
  7. Aug 23, 2018 at 5:51 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    I have the heater, but by all means none of the external pipes are wrapped or anything so my guess is no on that. The larger ones also get insulated and heated tanks.
  8. Aug 23, 2018 at 6:35 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    They fixed pretty much everything I've always hated about GM trucks in this generation.
    I don't like their engine lineup, though. The 5.3 is a pig, the new 2.7 isn't quite capable enough (I special ordered my Ford 2.7 with 3.73s to get the ratings up a bit, I felt with 3.55s it was a little low and the GM 2.7's max is lower than that), and the 6.2 is only an option if you spend big money on one of the highest trim levels. Also transmissions--why not just put the 10 speed in everything and be done with it?
    jpereira2 likes this.
  9. Aug 23, 2018 at 6:57 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Most cars and trucks used to have only a 3 speed transmission and when they went to 4 speeds it was a BIG deal! No reason to have more than 5 or 6 gears in the trans in my opinion, more than that it seems like it's for manufacturers bragging rights. I personally would rather have my trans locked up and make the engine pull rather than shifting ALL the time.
    Bridge4, tacobell007 and jpereira2 like this.
  10. Aug 23, 2018 at 7:09 AM
    js312
    Joe
    New England
    My 10-speed skips gears in normal driving, so I'll often see something like 1 - 3 - 5 - 6 - 8 - 10. I don't notice it shifting around a lot.
    Tow-haul mode always uses them all, so it's entertaining to accelerate and have it shift every few MPH like a big rig. I think that's where the big advantage comes in.
    Noelie84 likes this.
  11. Aug 23, 2018 at 7:19 AM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Any third gen folks get the TSB for the transmission? Where did you get it done? Did you get any pushback? 40mph-60mph is an absolute deadzone for acceleration during my commute.
    Bridge4 likes this.
  12. Aug 23, 2018 at 7:20 AM
    Noelie84
    Noel
    Wales, Maine
    Seconded. It's part of what lets a turbo'd 2.7 haul like a much bigger engine; with all of those gears to pick from the transmission can keep you in the power band regardless of speed (theoretically, if they've got it mapped correctly). Same as a 21 speed mountain bike.
    micwillia likes this.
  13. Aug 23, 2018 at 7:27 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Nobody ever uses all the gears on a 21 speed mountain bike. That's why they don't make them anymore
  14. Aug 23, 2018 at 7:28 AM
    Noelie84
    Noel
    Wales, Maine
    What?
  15. Aug 23, 2018 at 7:45 AM
    jethro
    Geoff
    Southern NH
    Everyone complains about the 5.3 but I love this motor, it's been awesome so far. I get much better mileage than my Taco did and tons more power.
  16. Aug 23, 2018 at 7:49 AM
    Noelie84
    Noel
    Wales, Maine
    The 5.3's seem like they're all over the map. My dad's '04 has one and it has plenty of power, over 150k and doesn't have any issues. A girl I know has one with over 300k in her Tahoe (2006?) and same thing; still tons of power and zero issues.
    On the other hand, all I hear about them is how oil-thirsty they are. But, to be fair, these are both pre-MDS motors, and most of the issues seem to involve the MDS trucks. :notsure:
  17. Aug 23, 2018 at 7:49 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    11 speed mountain bikes are the new standard
    On a different note. Foxboro has the car show both this week (tonight) and next. Anyone going?
  18. Aug 23, 2018 at 7:55 AM
    Noelie84
    Noel
    Wales, Maine
    Damn it, talking about camping has me excited for my trip back up to Aziscohos on Labor Day weekend. :frusty:
    tacobell007 and m603holden like this.
  19. Aug 23, 2018 at 8:07 AM
    jpereira2
    Massachusetts
    not going tonight but why both weeks? anything special?
  20. Aug 23, 2018 at 8:08 AM
    jethro
    Geoff
    Southern NH
    I may be across the street from you on Richardson. This weekend I'm in Pittsburg, next weekend Sebago, and Labor day Richardson. Lotsa fishing in my future.
    Noelie84[QUOTED] likes this.
