New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Nov 15, 2018 at 4:58 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    I'm not entirely sure I do know the diodes have yellow instead of amber, either seem to function pretty good to me.
  2. Nov 15, 2018 at 5:01 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    The bit about yellow / amber is it removes the lower part of the light wave, which is the blue wave and is also the more reflective wave. The further you cut the lower section of the wave off, the further you can throw the light in rain and dust because it's not being refracted and also you don't have glare. Both the yellow / amber are easier for the eyes to process.
    Skierrichy and Bruce988jl like this.
  3. Nov 15, 2018 at 5:08 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    That's what I'm talking about. Too many options. Another problem with Ford too is that they will make different parts depending on the options. You should see the sheer number of ECM's available for those trucks. Only 3 or 4 engine choices but 55 to 60 computer's. Wiring harnesses change depending on options too. Ford needs to learn to KISS method.
    Chevy has 1 computer per engine and only 1 wiring harness per cab configuration. If you don't get an option its just an empty plug. Simple
    Skierrichy likes this.
  4. Nov 15, 2018 at 5:10 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Getting ready for a shit commute tomorrow.
  5. Nov 15, 2018 at 5:11 AM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    I get that.
    It wasn't until recently, that the yellow/Amber thing has been a factor for me.
    I've pretty much used selective yellow. Better than the harsh white in crap conditions.
    Even makes a difference in beach driving when the mist is rolling in off the gulf, etc.
    BUT, if the Amber visually is better, in particular the snow/,hard rain/fog... I'd be inclined to lean that way.
  6. Nov 15, 2018 at 5:11 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    Not sure what Ford will be doing for the ECM/wiring situation, but at least like you said, the Ranger will have the Base, Mid, High tier as the only trim options.
  7. Nov 15, 2018 at 5:13 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Haha yeah, I do that as well. I actually want to put some spot lights on the back of my truck for the tailgating types.
    Anywho, I have the sideshooters as well and put some Rigid amber covers on them. All I had to do was file down the 4 plastic moldings on the inside of the covers to give them a snug fit. Size and shape are identical otherwise.
  8. Nov 15, 2018 at 5:14 AM
    m603holden
    Marteeen
    New England
    Like I've mentioned before , I have bad astigmatism. So glare can basically make the road disappear on me. I've had yellow fogs before and they made a huge difference considering how my eyes are prone
  9. Nov 15, 2018 at 5:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What's funny is, even though they have all the different ECMs, it's likely 1 ECM per engine but with different codes selected for different options. I used ForScan on the F150 and I could plan around with a lot of the options and configurations in the ECM. Anything you install, even though the wiring is there for an option, you plug it in and then you have to have the dealer 'activate' it.
  10. Nov 15, 2018 at 5:24 AM
    Bruce988jl
    Southern NH
    Interesting - I'll have to look into this more.
    MadRiverTaco[QUOTED] likes this.
  11. Nov 15, 2018 at 5:27 AM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    I find the Jimmy Dean sausages to be the best of the pre-cooked sussages...We get them at BJ's real cheap. The box of like 30 at BJ's is cheaper than the box of 12 at the grocery store.
    Love this...
    https://m.youtube.com/watch?v=f4RNb3tt0LM
    "... A little plump scotch girl"
    Spare Parts and Cudgel[QUOTED] like this.
  12. Nov 15, 2018 at 5:35 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I like that they're configurable. It's one of the things that steered me away from the competitors. Building trucks from most of them is infuriating.
    Yeah, I think I could pretty easily give my truck lots of the high end options by just plugging them in and changing the config in ForScan.
  13. Nov 15, 2018 at 5:46 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Price on the 6 inch wide LED bars? I am looking at a tube bumper this weekend and hoping to do a similar amber/yellow setup as yours. Nice looking front end! :thumbsup:
  14. Nov 15, 2018 at 6:00 AM
    m603holden
    Marteeen
    New England
    Ps. Breakfast
    Fitzwilly, Skierrichy and zjcas like this.
  15. Nov 15, 2018 at 6:20 AM
    Bruce988jl
    Southern NH
    160$ is MSRP on the pair of amber/yellow 6inch bars. I have had mine on for about 18k miles and they are just the paint is starting to chip off from the rocks and salt/etc but I have yet to have any moisture in them or even had one fail. Black friday they normally have a 20% off sale.
    https://www.diodedynamics.com/ss6-stage-series-6-amber-light-bar-pair.html
    Boston10Taco and Skierrichy like this.
  16. Nov 15, 2018 at 6:59 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I think the ForScan is just a basic part of the ECM. They most certainly are not the same part with different numbers. If you do not get the exact correct one they do not fire the engine, even with programming at a dealership
    But not cool when you need a part that they make 75 different part numbers for and I'm talking about only 1 part that they made for only 1 year on 1 model
  17. Nov 15, 2018 at 7:01 AM
    m603holden
    Marteeen
    New England
    Well. Use caution when buying from realtruck. Even when you try to verify stock Screenshot_20181115-082207.jpg Screenshot_20181115-094828.jpg Screenshot_20181115-094838.jpg Screenshot_20181115-094849.jpg Screenshot_20181115-094908.jpg Screenshot_20181115-095041.jpg
    TreeFortRichard likes this.
  18. Nov 15, 2018 at 7:03 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I think of it as
    Base
    Good
    A little bit better than good
    Better
    Nice
    Nice +
    One below the best but a little bit better than the Nice + one
    Best
    It's ridiculous and most of it is overly redundant. Ford needs to fix it
    Sand Dog and Bruce988jl like this.
  19. Nov 15, 2018 at 7:12 AM
    jethro
    Geoff
    Southern NH
    Ford's pricing layout and trim levels are exactly why I have a GMC right now. I wanted an F150 but to get real rear doors and a 6 foot bed was basically an impossibility unless I was spending 50k or more.
  20. Nov 15, 2018 at 7:14 AM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    You have a connection for diod dynamics correct? Interested in DOT amber fogs.
    Also, are you interested in selling that spare light bar? :D
    jpereira2 likes this.
